When you are viewing your Add-Ons, if you view the Add-On details, it should be displayed on the screen:
I’m running confluence and all I see is the type, author, version and summary
What addon are you trying to work with?
I’m trying to setup that Security Cam Overlay. Right now I’m screwing around on my android tablet but plan to use this on my android tv boxes as well.
It’s documented in the link @Luvien provided: script.securitycam
You can also modify the addonid in the XML file and install multiple copies if you have multiple cameras (reference).
Download the Zip file, and modify line 2 of the addon.xml
to change the addon id from script.securitycam
to script.frontdoorcam
like so:
<addon id="script.frontdoorcam"
name="Security Cam Overlay Front Door"
version="0.1.0"
provider-name="Ryan Melena">
And on [line 8](https://github.com/RyanMelenaNoesis/XbmcSecurityCamOverlayAddOn/blob/master/script.securitycam/default.py#L8) of the `default.py` change the `ADD_ON_ID` to `script.frontdoorcam` or whatever copy you are making.
Here's the link directly to the Security Cam Add-on source code:
And the Zip file for the plugin to be installed:
https://github.com/RyanMelenaNoesis/XbmcSecurityCamOverlayAddOn/archive/master.zip
Thanks again Joshua… I got RM updated and I see all the commands. Very cool. Can you help with the string to load a playlist? I’ve been using this in Eventghost…[{“file”:“special://profile/playlists/music/4+ Stars.xsp”}]
I tried it just like that with no luck…I’m using parameter type: String I’m not sure how this would translate to a playlistid from below.
playPlaylist(playlistid) - starts playing the specified playlist (by ID) (0: Music, 1: Video, 2: Pictures)
Thanks again
Instead of playPlaylist()
, does playFile()
work?
Command: playFile
Parameter 1 Type: String
Parameter 1 Value: special://profile/playlists/music/4+ Stars.xsp
Yep. … that works!! Thanks.
Hello Joshua,
Everything is working great! Thanks for your work!
LJ
Oh. My. Stars. And. Garters! Thanks Joshua!!!
I’m glad you are enjoying the code! Thanks for the shout-out!
Joshua, can I still use the apps for pause dim lights and play turn off lights and stop go full if I don’t have rule machine? Looking for simple way to do those 3 things with my harmony elite remote or are these just working from the smart app inside of smartthings
Hey @AnthonyJS02 have you seen the CoRE yet? I have an issue open with the dev for CoRE and we’re reaching out to @joshua_lyon to see if he can give us the info needed to have CoRE handle the dimming of the lights
Here is the issue https://github.com/ady624/CoRE/issues/4
and here is CoRE
@TheFuzz4 I replied to the CoRE GitHub issue. Can’t CoRE use the switch
attribute from the Kodi DTH?
@AnthonyJS02 you will need some sort of SmartApp to be able to react to the state changes in SmartThings. The Harmony SmartApp doesn’t have rule or reaction logic, but as @TheFuzz4 indicated, you could use this with CoRE when the hooks are in place.
Thank you very much @joshua_lyon
@AnthonyJS02 what I do currently with RuleMachine and ultimately CoRE is I have rules that monitor the Kodi devices play status. When they change it triggers different light levels
With CoRE with the advanced features turned on I’ll have a Then If Piston that looks like this
If mode is night
and
Kodi status changes
Then If
If kodi status is playing
Then Dim lights to 5%
If kodi status is paused
Then Dim lights to 50%
If kodi status is stopped
Then Dim lights to 100%
I hope that this helps once the correct attributes are added to CoRE
So I have this working with CoRE (like @TheFuzz4’s example) to allow on/off/dimming of lights depending on the status of Kodi. It works perfectly fine IN the Things screen for my Kodi device. However, I can’t seem to get it to work with my Harmony remote (Harmony Companion w/ hub). Is there something I’m just not doing right?
Have you tried the steps in the second post? Specifically the item about events not working:
The previous run time on any of the instances is always blank. Next run time is within 20 minutes. I’ve done the manual update before. A little more info on my setup:
Kodi is running on a Nexus Player. Harmony remote controls Kodi and the Nexus Player just fine. My lights (GE Link) will turn on/off/dim based on Kodi status just fine IF I hit play/pause in the Device screen in the ST app. So the setup is mostly working. I just can’t get the “rules” to trigger when I use the Harmony remote.
