rhoffer
(Ricci Hoffer)
January 25, 2017, 3:55am
540
Smart lights is in the ST recommends section in the marketplace under smart apps or under lights and switches. When installed it will be called smart lighting. It is pretty straightforward.
A little on local processing
Ever unplug your hubs ethernet and see just what it can locally process?
One would think it would process SHM (Smart Home Monitor), ensuring your alarm and designated lights would trigger during an invasion, water leak or smoke… Nope, nothing triggered… Even with ethetnet connected, V2 SHM no longer triggers alarms or lights during a smoke alarm or co2 test, V1 did, only way to test is to actually force a real alarm.
How about a remote control or wall controller? Nope…
Maybe a common ST SmartApp like Double Tap, No again…
Logging? Nope… App use? Nope…
How about a simple motion detector turning a light on, Yes, finally…
Maybe another switch able to trigger another device, yes…
Automatically turn a device off after a specified amount of time, yep…
Simple light triggering is the only…
This wiki will get you what is being processed locally.
http://thingsthataresmart.wiki/index.php?title=FAQ
