SmartThings Community
[RELEASE] Insteon Hub 2244 and 2245 Dimmer and On/Off Plugs/Switches/Bulbs
dth_lighting
insteon
dth_misc
(Scott Kuester) #142
@millsjq The ip address for your hub should be the local address, so based upon your example that looks correct. Make sure that you specify the port (25105 by default) and use the username and pass from the Insteon app. This is NOT the email and password that you use to login, but inside the app got to Settings->House and its the ‘Hub username’ and ‘Hub password’ at the bottom of the page.
#143
kuestess, Thanks .
I was using the correct port and IP, but wrong username and password. I have edited the hub Device Handler, should there be any edits in the switch handler, I did not see anywhere needed. I must be daft as I still do not have any devices showing, after correcting, saving and publishing the handler should I use the smarthting app “add a Thing” or something else.
Should I have a device in the handler as 3A.A6.2B or AA6C?
(Scott Kuester) #144
@millsjq No need to edit the DTH directly. Easiest way is to use the IDE - after you login, go to the ‘My Devices’ tab and click add new. In the resulting page, select the DTH from the dropdown in the ‘Type’ field. Fill out all of the other required info and click ‘Create’. In the next screen, edit the preferences to add deviceid, username, pass, etc. Save that and you should be good to go.
#145
Scott, Obviously I was way off. I have added a new device, selected hub, and assuming this device if the hub put in the Insteon ID for the hub, selected the DTH for the hub. Then I edited the ip, port, username and password. Then I added a device for the switch, added the Id for the switch etc. Apparently I still missed the boat as I still can see any devices in SmartThings app, believe it should just show up, but have
(Scott Kuester) #146
@millsjq Sounds like you’re doing everything correctly. If the device doesn’t even show up in the app, you might try going to ‘Add a thing’ in the app (at the bottom of ‘Things’) to force it to refresh. Mine usually shows up without doing that, but it sometimes needs a refresh. The device should show up, even if its configured incorrectly.
#147
I am going to re copy the DHL incase I screwed up something when I went in a edited the hub info manually. One additional question when adding a device in the IDE for the Insteon Hub, after I select Insteon hub for the type, in the bub section do I leave blank or select SMARTHINGs from the drop down.
#148
I have put myself in circles. I realize I was using finik DHL not yours, I deleted everything and started over with your Insteon Dimmer switch and Plug, dated 2017-12–30. I used the device ID for the switch on both the added device and when editing the hub info. I now show the device, but it shows always on and will not turnoff and has no effect on the switch. The IDE logs show ( below) show the Command is timing out, so I tried my local and external IP in the URL field in the edited portion of the add device.
Should I be using a different DHL version and start again, I am obviously over my head on this but keep thinking I am one edit away from success and then trying another.
2b701312-f08d-45f3-b761-c74468a52979 10:09:28 AM: error org.apache.http.conn.ConnectTimeoutException: Connect to 192.168.1.17:25105 [/192.168.1.17] failed: connect timed out @line 163 (getStatus)
2b701312-f08d-45f3-b761-c74468a52979 10:09:18 AM: debug [uri:http://user:pass@192.168.1.17:25105/3?02623AA62B0F1900=I=3]
2b701312-f08d-45f3-b761-c74468a52979 10:09:18 AM: debug Polling…
2b701312-f08d-45f3-b761-c74468a52979 10:09:08 AM: error org.apache.http.conn.ConnectTimeoutException: Connect to 192.168.1.17:25105 [/192.168.1.17] failed: connect timed out @line 125 (sendCmd)
2b701312-f08d-45f3-b761-c74468a52979 10:08:58 AM: debug Sending Command
2b701312-f08d-45f3-b761-c74468a52979 10:08:58 AM: debug Turning device OFF
10:07:46 AM: info Waiting on events…
10:07:46 AM: info For past logs for individual things go to the My Devices section, find the device and click on the Events link on the device information page.
10:07:46 AM: info This console provides live logging of your SmartThings.
(Scott Kuester) #149
@millsjq You may want to edit the last post as it has your hub user/pass in it :slight_smile:. It looks like the DTH is working, but not connecting to the hub for some reason. To figure out what the problem is, paste the commands below into a terminal window (sub in your user/pass). It should give you an error message indicating what the issue is. If these work ok, then we need to look elsewhere.
Turn on:
curl[user]:[pass]@192.168.1.17:25105/3?02623AA62B0F11FF=I=3
Turn off:
curl[user]:[pass]@192.168.1.17:25105/3?02623AA62B0F1300=I=3
#150
Scott, Thanks again. I inserted my hub name and password to match the app, and I get, no match.
Tried resetting the Insteon Hub, now with different local IP. No dice, changed my hub name and password and still get no match.
I went into IDE and changed the device to match the new IP, etc. the thing in ST stays as “on” but on a curious note when I did this my Insteon app would not work, with message that something was wrong. I went to the device and put in a bogus (the old IP) the Insteon app resumed working. Something must be happing but beyond my technical ability.
