I don’t have a developer account with Apple. Last time I checked it was like $100 just to register. Besides that I don’t even have an iPhone to test on. So unless I get a developer account and an iPhone to work with, no iOS support.
Hey Robin, wouldn’t they still need a password to get into the dashboard? Or does it have to have continued accessibility for the Presence to work? I’m asking for another person who has some of the same use case scenarios. Not installing ST app on person phone and then only giving them access to specific devices via ActionTiles.
So I have the app installed on my Android and I just attempted to open it up and it wants a code. My Presence functionality will still continue to run and be active even though I can’t open the dashboard right now because it wants a code. Is that a true statement?
I get to the point where I’m putting my device ID into the ST device and when I hit Save, it just keeps saying “please fill out all required fields” but everything is filled out.
Sorry for the late reply. Didn’t see the notification. I had that issue a while ago but it’s an issue with SmartThings. Try and remove the device and add it back again.
John - I appreciate your continued development on this app. I’m having the same issue reported by multiple folks (mark2k, DrChops) above, re: presence sensor app detects me leaving my home WiFi network, but isn’t automatically notifying the server. With status and error messages turned on in the app, I see no notifications when connecting and disconnecting from WiFi. The location icon in Presence Sensor turns from blue to gray, so it seems like the app knows that I’m coming and going, but it isn’t automatically posting the activity. Using the manual refresh button in the app, I get the expected “Update successfully posted to server” notification. After using the manual refresh button everything seems to work fine for a while, and then the app reverts to the aforementioned unexpected behavior. I’m experiencing this issue on 3 android phones all running version 1.5 of the app on two different SmartThings locations. Let me know if I can forward any data to assist in working this issue. Thanks again for your help!
That is an issue with Android 8.1. Are you having that issue on anything other than 8.1? I’m working on it but I don’t have any devices with 8.1 to test on.
Yes, sure did. The only permission it asks the user for is “Location” but it’s getting all of these additional requirements as well:
view network connections
connect and disconnect from Wifi
change network connectivity
view Wi-Fi connections
full network access
run at startup
android.permission.REQUEST_I
Also of note - I’m running the app with error notifications enabled and I don’t get any errors during the periods of unexpected behavior. It seems as though the app is functioning normally as far as detecting if I’m home or away based on my WiFi connection. It just isn’t automatically posting the update to the server.
Thanks for working on the device handler for the community. It has been working great for me since you released it. Although, like others posting recently it’s been erratic lately. The gf has a Galaxy S6 with 7.0 (pretty sure). Looking at the logs whenever I try and manually update the device via the ST app tries to poll the device location status and there are many errors.
Response has error: Failed to complete. Message was: Connection refused: st.callahtech.com/68.51.51.173:443
Thanks a ton for attempting this, as I find it much better than the default method like others have mentioned. I am having some trouble getting the app working and in an attempt to solve these issues I updated to 1.5 by signing up to the “Beta test” in the play store, as well as reinstalling the app. Unfrotunately this has put me in a dead end as there seems to be no way to add a network in 1.5 unless I am missing something. There is just the default location “Home”, which after selection gives me the bar to edit the locations name, the “Home Location” check box, and the text that says “Check the networks that you would like to include in this location”, but there are no networks shown below that and no way to add any as far as I can tell.
Before this on 1.4 everything was entered with no problem: New device with type “Improved Mobile Presence” added (coming from the github server) in ST, and the “device ID” option under the settings for the device set to the ID generated in the Presence Sensor app; however, the device seemed to perpetually be marked as “Home” in the Smart Things app with only two notifications at the same time stamp saying “[Name] Arived” that happened when I first pressed the refresh button. Pressing the refresh button every other time after this simply gave a “Update successful” notification and turning off the Wi-Fi resulted in a serious of “Update error #2” notifications, all the meanwhile the device status in ST still showing “Home”.
I was never asked for any kind of permissions, nor did any appear as an option under the application manager for 1.4. In 1.5 I have ticked off the “Location” permission.
I am not sure if I will still have the same issues under 1.5, since as I mentioned before I seem to be stuck without anyway to use the app. I am not sure if an pop-up is supposed to appear that isn’t showing itself, or if there was an oversight in 1.5 for people that reinstall (relying on the networks added in 1.4 or something). Either way I would love to see if I can get this method working so let me know what you think when you get a chance.
They WiFi networks should all have been put into the home location after updating. Do you see anything listed in there at all? When you open it up, it might take like 10 seconds for networks to come up since its scanning.
Did you enable to optimization white list? If not then that can cause Android to block network connections in the background. What do the errors say after “Update error #2”?
