[RELEASE] Improved Mobile Presence (Android only)
I have personally been using this since 2017 and everything works great for me.
If you have any problems, I’m happy to help :slight_smile:
Hi again, I’m not sure to have correct understand. Now the smartapp work only with wifi and Bluetooth?
Do I need to be connected to the home WiFi network to be located at home? (or a selected Bluetooth device) Did I understand correctly?
The easiest way to use this is to select your home wifi networks. When your phone is connected to any of those networks then you will be marked as at home. Make sure you have “home location” checked if that location is home. That checkmark defines the presence attribute on the device.
Thank you, now I understand. Unfortunately this is nota best solution for my situation, becouse the wifi in my house is not all time good and sametime. The wifi is not good and sometimes i don’t use it even if i’m in ac, so i would be located elsewhere. This is as true for me as it is for my wife. I was hoping there was some sort of location linked to GPS or GSM. Thanks anyway for your work
