I’ve been having some issues with SmartThings not updating the status of a sensor properly, or rather it sees them stuck in an open state, when they are in fact closed. Actuating them again sometimes reset them, but it’s not long before they get seen as stuck again.
It’s been happening mostly with my doors, but I’ve also seen it happen with some windows and even a motion sensor. I confirm that the EVL or Vista is not seeing these in a perpetual open state, so the problem must be with SmartThings not getting the message.
I am seeing a lot of “[stnp] Notify error: Error: connect ETIMEDOUT 192.168.1.21:39500” in my past logs and the console if I run it within there. Not sure if that has anything to do with my issue.
I just tried restarting my stnp service and will try to reset my sensors back to normal and see if this happens again, but it’s been quite annoying
edit:
i restarted STNP, verified it was running, then tried opening my door. it showed as opened right away in ST and on my panel keypad, and then i closed it which is reflected in this log, and in my panel, but ST still shows it as opened.
[2020-05-21T16:26:34.026Z] [stnp] SmartThings Node Proxy listening at http://:::8080
[2020-05-21T16:26:34.059Z] [stnp] Loaded plugin: envisalink
[2020-05-21T16:26:34.066Z] [evl3] Connected to Envisalink at 192.168.1.40:4025
[2020-05-21T16:26:42.308Z] [evl3] {"type":"partition","partition":1,"state":"ready","alpha":"****DISARMED**** Ready to Arm"}
[2020-05-21T16:27:53.718Z] [stnp] ::ffff:192.168.1.53 GET /favicon.ico
[2020-05-21T16:27:53.720Z] [stnp] Authentication error
[2020-05-21T16:28:09.805Z] [evl3] {"type":"zone","partition":1,"zone":5,"state":"open"}
[2020-05-21T16:28:09.808Z] [evl3] {"type":"partition","partition":1,"state":"notready","alpha":"FAULT 05 GARAGE DOOR"}
[2020-05-21T16:28:12.868Z] [evl3] {"type":"zone","partition":1,"zone":"5","state":"closed"}
[2020-05-21T16:28:12.870Z] [evl3] {"type":"partition","partition":1,"state":"ready","alpha":"****DISARMED**** Ready to Arm"}
[2020-05-21T16:28:49.560Z] [stnp] Notify error: Error: connect ETIMEDOUT 192.168.1.21:39500
[2020-05-21T16:30:17.077Z] [stnp] Notify error: Error: connect ETIMEDOUT 192.168.1.21:39500
[2020-05-21T16:30:20.117Z] [stnp] Notify error: Error: connect ETIMEDOUT 192.168.1.21:39500
[2020-05-21T16:30:20.118Z] [stnp] Notify error: Error: connect ETIMEDOUT 192.168.1.21:39500
