Contact Heatit for integration with SmartThings
Introducing the Heatit Z-TRM2fx / Z-TRM3 electronic thermostat device handler (DTH)
RBoy Apps is the official SmartThings partner for Heatit products
Heatit Z-TRM2fx is a Z-Wave Plus electronic thermostat for electrical floor heating and cooling. The thermostat has a built-in Z-Wave Plus chipset, with two external temperature sensors (Floor Sensor and Room Sensor). Heatit Z-TRM2fx is equipped with a single pole switch and it fits most System 55 frames (Elko RS16, Schneider Exxact, Gira, Jung etc.). The thermostat can withstand a load of max 13A /2900W at 230V.
Heatit Z-TRM3 is a Z-Wave Plus electronic thermostat for electrical floor heating, designed to be mounted in a standard flush box. Heatit Z-TRM3 is equipped with a single-pole switch and fits into System 55 frames. The thermostat can withstand a load of max 16A /3600W at 230V. The thermostat may be used for water based heating if the thermostat is linked to the Heatit Z-Water.
WHERE TO BUY THE THERMOSTAT
The Z-TRM3 can be purchased from Heatit and Thermo Floor.
The Z-TRM2fx can be purchased from Heatit and Thermo Floor.
Device Handler Screenshots
Classic App
Key Features of the DTH
- Supports
- Z-TRM2fx - Eco, Heat and Cool modes
- Z-TRM3 - Heat mode
- Reports current thermostat temperature (separately) and:
- Z-TRM2fx - Floor Sensor, Room/External sensor
- Z-TRM3 - Internal Sensor, Floor Sensor, Room/External sensor
- Configure different sensor modes
- Z-TRM2fx (F, A2 and A2F)
- Z-TRM3 (F, A, AF, A2 and A2F)
- Reports load details
- Power (W)
- Voltage (V)
- Consumption (KWh)
- Setpoints for Eco, Heat and Cool mode
- Toggle display mode on thermostat (Setpoint or Temperature)
- Configure display and button brightness
- Configure temperature sensor offset
- Configure mix/max operating temperature
- Support for C and F temperature scales
- Support for new and Classic ST app
INSTALLATION INSTRUCTIONS
Device handler installation instructions can be found here. Once the device handler is installed, pair the device with the hub:
PAIRING INSTRUCTIONS
- Make sure the device is within 5ft of the hub and sometimes rebooting the hub helps before pairing and keep the ST mobile app open
- Press the center button until the thermostat show OFF
- Press the down arrow button until the screen shows Con
- Press the center button and the screen will show On
- Press the center button until ON starts flashing
- Pair using S2 mode for improved reliability, from the new ST app, click
âDevice
â SelectGeneric Z-Wave Device
from the list and then follow the instructions. You can find the S2 pairing QR code/DSK key code on the device box or on the rear of the device if required. - When it pairs successfully it should say INC on the thermostat screen and within 30 seconds the device should show up on the ST app. If it doesnât show up, reset the thermostat, reboot the hub, bring the device closer and try again
EXCLUSION INSTRUCTIONS
- Start the device removal or exclusion process on the SmartThings app
- When it excludes successfully it should say ECL on the thermostat screen. If it doesnât exclude, try to reset the thermostat
FACTORY RESET
- Keep the Right and Center buttons on the thermostat pressed simultaneously for about 20 seconds
NOTES
- When in Cool mode use, the External/Room temperature sensor as the floor sensor displays an incorrect value on the thermostat screen
- Firmware versions TRM2fx (3.06 and 3.04 ) and TRM3 (4.00) do not support resetting energy consumption over z-wave. This feature has been added for future firmware updates which may support energy resets over z-wave. The only way to reset energy consumption on these firmware is to exclude and re-pair or factory reset the thermostats.
You can also check out the following climate and thermostat management apps
[RELEASE] Motion Sensor Thermostat with Remote temperature sensors, Presence detection and Schedules
