I was working with @saosinx88 on a DTH, and no matter what I did in the DTH, his device always polled every 6 minutes. I don’t actually have one of these devices to test with, but you’re more than welcome to take these DTH’s I tried:
Mine was behind a fridge and didn’t want to start messing around with it. @Smartphi’s Frakenstein appears to work well, on/off like before, and now the 6th end plug works, which is quite masterful! So I’m happy with that, will monitor for a few days. Tried yours @johnconstantelo and it only came up as a generic “Switch” single device, the children weren’t created. Still had to use Z-Wave tweaker to get rid of the LED flashing every 60 seconds.
It’s hard working on a DTH if you don’t have the device in front of you, @saosinx88 i think you should send one to Mr Constantelo I’m also stuck with 6 orphan devices I’m unable to delete at all now, need support to delete them for me.
Yeah, I can’t remember all the changes that were made because there were so many and I was focused on trying to nail down specific issues one at a time. I tested with a “virtual device” and also had orphaned child switches, but I was able to eventually delete them in the IDE after a while.
I ran into a problem not being able to force remove it as well, but had to go into IDE, delete all the child devices first, and then I could delete the parent.
I think the way to go is first delete all children manually, then exclude the parent device, turn on exclude and tap the switch, THEN the parent finally disappears. It’s not the easiest device to work with in the world! But any future work should be based on Frankenstein, he’s added the sixth plug, and deleted the defunct USB child devices. Power reporting must be possible because one of the 4 original Greenwave parameters has per cent of power report.
the main switch does in fact turn all the child switches on/off but you need to go into the main devices settings/cog wheel in the smartthings mobile app and choose 500 or greater in the 'Main Switch Outlet Delay" user options.
*disabled = no delay but this results in commands not executing
Not sure if anyone will see this as its an old thread. However seems to be the most current.
GreenWave 6 port switch.
I added the parent and child DTH which worked great in ST. I have the 6 ports and the master. They all function independently, and the master. However in the current ST app does not show the current “port status” they always look “ON”, when you click on the tile itself it and go into the screen where it shows power meter, it lets you toggle the device connected to the port on or off.
From the main screen in ST while they all show “on”, it does turn a port off (but the icon never changes) with a tap, but it wont turn it back on with a tap, you have to go into the port itself to turn it back on.
Does this make any sense?
SmartThings Version 1.6.51-435
Actually after watching it for a few hours, its just extremely slow to catch up, can range from minutes to hours, to never.
Hi all. I had a PowerNode 6 that I tested with ST Classic and it worked great but now in the new ST ecosystem these aren’t working. I’m using the DTH and child DTH that were posted on June 2 by @Smartphi.
The parent and its children all show up, but on new ST, the children are all gray with no control ability. In ST classic I can control them however my understanding is ST is killing classic soon plus I’ve already migrated my system to the new ecosystem.
Wherein the author of the Zooz DTH on which the Greenwave PowerNode 6 DTH is based can be seen to have written
Nope…
I believe the issue is that you joined the device prior to 8/16/2020 and the only way you’re going to solve the problem with the child devices not working in the new mobile app is to delete them and save the settings so that when they’re re-created they won’t have a componentName or componentLabel.
Update: That’s based on the assumption that you’re getting a network error when you attempt to control the child devices in the new mobile app…
in response to a user witnessing nearly the identical problem with his Zooz as we are with our GreenWaves.
Then, I had to Exclude and re-Include the GreenWave device, but once that was done the master device plus all the individual outlets all appeared and once again were controllable, and accurately indicated status, from both the overview and the details screens.
