[Release] Google Assistant Relay V2.0 - Google Home Audio Notifications!
tts
requires_server
googleassistant
googlehome
(Greg) #42
That seems like you have an old build since Speaker is still there
Can you try downloading the latest build from here:
and try again?
(Steve) #43
Still getting errors with the install, this is exactly what I did:
(THANK YOU!!!)
pi@raspberrypi:~ $ wget https://github.com/greghesp/assistant-relay/archive/v2.0.tar.gz
–2018-09-18 11:17:25-- https://github.com/greghesp/assistant-relay/archive/v2.0.tar.gz
Resolving github.com (github.com)… 192.30.255.112, 192.30.255.113
Connecting to github.com (github.com)|192.30.255.112|:443… connected.
HTTP request sent, awaiting response… 302 Found
Location: https://codeload.github.com/greghesp/assistant-relay/tar.gz/v2.0 [following]
–2018-09-18 11:17:26-- https://codeload.github.com/greghesp/assistant-relay/tar.gz/v2.0
Resolving codeload.github.com (codeload.github.com)… 192.30.255.120, 192.30.255.121
Connecting to codeload.github.com (codeload.github.com)|192.30.255.120|:443… connected.
HTTP request sent, awaiting response… 200 OK
Length: unspecified [application/x-gzip]
Saving to: ‘v2.0.tar.gz’
v2.0.tar.gz [ <=> ] 282.33K 1.23MB/s in 0.2s
2018-09-18 11:17:26 (1.23 MB/s) - ‘v2.0.tar.gz’ saved [289106]
pi@raspberrypi:~ $ tar -xzf v2.0.tar.gz
pi@raspberrypi:~ $ cd assistant-relay-2.0
pi@raspberrypi:~/assistant-relay-2.0 $ npm install
speaker@0.4.1 install /home/pi/assistant-relay-2.0/node_modules/speaker
node-gyp rebuild
make: Entering directory ‘/home/pi/assistant-relay-2.0/node_modules/speaker/build’
CC(target) Release/obj.target/output/deps/mpg123/src/output/alsa.o
…/deps/mpg123/src/output/alsa.c:19:28: fatal error: alsa/asoundlib.h: No such file or directory
#include <alsa/asoundlib.h>
compilation terminated.
deps/mpg123/output.target.mk:108: recipe for target ‘Release/obj.target/output/deps/mpg123/src/output/alsa.o’ failed
make: *** [Release/obj.target/output/deps/mpg123/src/output/alsa.o] Error 1
make: Leaving directory ‘/home/pi/assistant-relay-2.0/node_modules/speaker/build’
gyp ERR! build error
gyp ERR! stack Error: make failed with exit code: 2
gyp ERR! stack at ChildProcess.onExit (/opt/nodejs/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:285:23)
gyp ERR! stack at emitTwo (events.js:125:13)
gyp ERR! stack at ChildProcess.emit (events.js:213:7)
gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:197:12)
gyp ERR! System Linux 4.14.7-v7+
gyp ERR! command “/opt/nodejs/bin/node” “/opt/nodejs/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js” “rebuild”
gyp ERR! cwd /home/pi/assistant-relay-2.0/node_modules/speaker
gyp ERR! node -v v8.0.0
gyp ERR! node-gyp -v v3.6.1
gyp ERR! not ok
grpc@1.8.0 install /home/pi/assistant-relay-2.0/node_modules/grpc
node-pre-gyp install --fallback-to-build --library=static_library
[grpc] Success: “/home/pi/assistant-relay-2.0/node_modules/grpc/src/node/extension_binary/node-v57-linux-arm-glibc/grpc_node.node” is installed via remote
npm WARN assistant-relay@2.0.0 No repository field.
npm WARN optional SKIPPING OPTIONAL DEPENDENCY: speaker@0.4.1 (node_modules/speaker):
npm WARN optional SKIPPING OPTIONAL DEPENDENCY: speaker@0.4.1 install: node-gyp rebuild
npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
added 390 packages in 94.136s
#44
You’re still not getting the right package. Where is this speaker coming from. Try this:
git clone https://github.com/greghesp/assistant-relay
Then cd assistant-relay
Then npm install
That’s the steps that I use I don’t see any of these errors.
(Steve) #45
Interestingly, I did NPM run start and it spit out the browser url, I logged in, pasted the code it gave me and it says it is up and running… though I’m not yet sure it’s running without error.
(Steve) #46
Ryan that’s what I did the first time… I will try again. Thanks!
(Aesgarth) #47
I’ve just tried to install this and am getting the following:
pi@raspberrypi:~/assistant-relay $ npm install
grpc@1.8.0 install /home/pi/assistant-relay/node_modules/grpc
node-pre-gyp ERR! Tried to download(403): https://storage.googleapis.com/grpc-precompiled-binaries/node/grpc/v1.8.0/node-v64-linux-arm-glibc.tar.gz
node-pre-gyp ERR! Pre-built binaries not found for grpc@1.8.0 and node@10.10.0 (node-v64 ABI, glibc) (falling back to source compile with node-gyp)
node-pre-gyp ERR! Tried to download(undefined): https://storage.googleapis.com/grpc-precompiled-binaries/node/grpc/v1.8.0/node-v64-linux-arm-glibc.tar.gz
make: Entering directory ‘/home/pi/assistant-relay/node_modules/grpc/build’
CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/surface/init.o
CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/backoff/backoff.o
sed: can’t read ./Release/.deps/Release/obj.target/grpc/deps/grpc/src/core/lib/surface/init.o.d.raw: No such file or directory
rm: cannot remove ‘./Release/.deps/Release/obj.target/grpc/deps/grpc/src/core/lib/surface/init.o.d.raw’: No such file or directory
grpc.target.mk:390: recipe for target ‘Release/obj.target/grpc/deps/grpc/src/core/lib/surface/init.o’ failed
make: *** [Release/obj.target/grpc/deps/grpc/src/core/lib/surface/init.o] Error 1
make: Leaving directory ‘/home/pi/assistant-relay/node_modules/grpc/build’
gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:262:23)
gyp ERR! stack at ChildProcess.emit (events.js:182:13)
gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:240:12)
gyp ERR! System Linux 4.14.52-v7+
gyp ERR! command “/usr/bin/node” “/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js” “build” “–fallback-to-build” “–library=static_library” “–module=/home/pi/assistant-relay/node_modules/grpc/src/node/extension_binary/node-v64-linux-arm-glibc/grpc_node.node” “–module_name=grpc_node” “–module_path=/home/pi/assistant-relay/node_modules/grpc/src/node/extension_binary/node-v64-linux-arm-glibc”
gyp ERR! cwd /home/pi/assistant-relay/node_modules/grpc
gyp ERR! node -v v10.10.0
gyp ERR! node-gyp -v v3.8.0
gyp ERR! not ok
node-pre-gyp ERR! build error
node-pre-gyp ERR! stack Error: Failed to execute ‘/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js build --fallback-to-build --library=static_library --module=/home/pi/assistant-relay/node_modules/grpc/src/node/extension_binary/node-v64-linux-arm-glibc/grpc_node.node --module_name=grpc_node --module_path=/home/pi/assistant-relay/node_modules/grpc/src/node/extension_binary/node-v64-linux-arm-glibc’ (1)
node-pre-gyp ERR! stack at ChildProcess. (/home/pi/assistant-relay/node_modules/grpc/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
node-pre-gyp ERR! stack at ChildProcess.emit (events.js:182:13)
node-pre-gyp ERR! stack at maybeClose (internal/child_process.js:962:16)
node-pre-gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:251:5)
node-pre-gyp ERR! System Linux 4.14.52-v7+
node-pre-gyp ERR! command “/usr/bin/node” “/home/pi/assistant-relay/node_modules/grpc/node_modules/.bin/node-pre-gyp” “install” “–fallback-to-build” “–library=static_library”
node-pre-gyp ERR! cwd /home/pi/assistant-relay/node_modules/grpc
node-pre-gyp ERR! node -v v10.10.0
node-pre-gyp ERR! node-pre-gyp -v v0.6.39
node-pre-gyp ERR! not ok
CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/channel/channel_args.o
CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/channel/channel_stack.o
…/deps/grpc/src/core/lib/channel/channel_stack.cc:19:48: fatal error: src/core/lib/channel/channel_stack.h: No such file or directory
grpc.target.mk:390: recipe for target ‘Release/obj.target/grpc/deps/grpc/src/core/lib/channel/channel_stack.o’ failed
make: *** [Release/obj.target/grpc/deps/grpc/src/core/lib/channel/channel_stack.o] Error 1
gyp ERR! not ok
npm ERR! code ELIFECYCLE
npm ERR! errno 1
npm ERR! grpc@1.8.0 install: node-pre-gyp install --fallback-to-build --library=static_library
npm ERR! Exit status 1
npm ERR!
npm ERR! Failed at the grpc@1.8.0 install script.
npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
npm ERR! A complete log of this run can be found in:
npm ERR! /home/pi/.npm/_logs/2018-09-18T19_08_00_643Z-debug.log
Anything obvious i’ve done wrong?
(Steve) #48
Ryan I did that as you can see, and this is the result. Thanks!!!
pi@raspberrypi:~ $ git clone https://github.com/greghesp/assistant-relay
Cloning into ‘assistant-relay’…
remote: Counting objects: 437, done.
remote: Compressing objects: 100% (100/100), done.
remote: Total 437 (delta 75), reused 99 (delta 36), pack-reused 293
Receiving objects: 100% (437/437), 2.47 MiB | 2.12 MiB/s, done.
Resolving deltas: 100% (206/206), done.
speaker@0.4.1 install /home/pi/assistant-relay/node_modules/speaker
node-gyp rebuild
make: Entering directory ‘/home/pi/assistant-relay/node_modules/speaker/build’
make: Leaving directory ‘/home/pi/assistant-relay/node_modules/speaker/build’
gyp ERR! cwd /home/pi/assistant-relay/node_modules/speaker
gyp ERR! not ok
[grpc] Success: “/home/pi/assistant-relay/node_modules/grpc/src/node/extension_binary/node-v57-linux-arm-glibc/grpc_node.node” is installed via remote
added 390 packages in 96.194s
#49
I would try with a clean install of Raspbian.
#50
The version of node you have won’t work I don’t think. Try v 8.8 or 8.9. 10.10 is definitely too new.
(Steve) #51
Oh god no, lol!! I hope I don’t have to go there. The only other thing I have installed is docker, running harmony-api. That was not too easy for me to set up when I did it months ago.
#52
You’re seeing the same error no matter what we do, so that’s all i got for you. Sorry.
(Aesgarth) #53
Thanks. That did it. Now to try to get it to make a noise… It says it’s running…
(Aesgarth) #54
I’m now getting the following:
Received command broadcast hello world
User not found, using Alex
Conversation Complete
But no sound coming out of any speakers. I also don’t have the relay as a device in my google home app, if that makes any difference…
Edit: resolved the user not found issue…
#55
I had to install Git, then no errors. Weird as i didnt have to install that for V1. Now have everything up and running
#56
Ok relay is running, but i am stuck on having webcore announce as i did with V1. I looked at a couple of examples and thought i had it setup correctly.
(Eric) #57
It looks like you need to add a command string.(user,broadcast,command)
#58
Thats it…thank you very much! dumb mistake :frowning:
(Aesgarth) #59
I have no idea what i’m doing wrong. I have the server running, and I can get webcore to talk to it, but I can’t get a sound out of my google home(s)… This is the output from the server…
Assistant Relay is now setup and running for Alex
You can now visit 192.168.0.26:3000 in a browser, or send POST requests to it
Received command broadcast WebCore test broadcast
(Can’t remember how I fixed the user not found issue previously, I’m using the correct username for both the webcore and hello world tests…)
edit: the upper case A was the issue… I was using it at both ends but it’s being passed as an a… still no sound
(Aesgarth) #60
looks like I’ve dome something wrong at the google end…
|API|Requests|Errors|Error ratio|Latency, median|Latency, 98%||
|[Google Assistant API](https://console.developers.google.com/apis/api/embeddedassistant.googleapis.com/overview?project=xxxxxxxxxx)|25|25|100%|1,407 ms|2,070 ms|Disable|
(Greg) #61
Can you see anything in your My Activity page?
Usually this is a case of not having the correct oauth file with the projects connected to the assistant api
