if this is the first time you are running it you’ll need to do
$ npm install
then
$ npm run start
Yeah, I did everything in the guide.
Does anyone know the proper commands to use ‘pm2’ to run assistant-relay v2 on a Raspberry Pi? I have been using pm2 for months with my assistant-relay v1 instance. I have a brand new RPi and I’d like to migrate to v2, but I would prefer to continue using pm2 to run assistant-relay on startup of the Pi. So far, I am not having any luck.
UPDATE: I figured it out.
From within the assistant-relay directory
pm2 start server/app.js --name "assistant-relay-v2"
pm2 save
Does yours also so ’ assistant relay is broadcasting… It sais… .’
Did you find a workaround?
Yes, Google changed something recently which adds the “Broadcast from ‘username’, …” there is nothing that can currently be done about it at this time.
@ogiewon Thanks for the response. I think Google did it on purpose since its way too specific as if they didn’t wanna make this a
Seamless integration of which it felt like…
Hope this doesn’t last
You can try the steps outlined in my personal notes I took during my recent successful installation of Google Assistant Relay v2.0 on my RPi 3B+. You’ll need to be able to download a view a MS Word Document.
Note: Ignore the Hubitat-specific Device Driver in the same GitHub repository. It will not run on SmartThings without some edits. Most ST users seem to be using webCoRE to make the httpPost calls. I like the simplicity of a Device to handle that work for me.
So there is no way to disable username?
Not until Google changes their end.
Whoo hoo! I followed your instructions, and it’s now working!
Thanks for taking the time to create such detailed instructions. These are the goto setup instructions for the Raspberry Pi: https://github.com/ogiewon/Hubitat/blob/master/Drivers/google-home-assistant-relay-v2.src/RaspberryPi-Assistant-Relay_v2.docx
Glad to hear those instructions are helping others. Most of what is in there is just a compilation of best practices I gleaned by reading through this entire thread, as well as the previous v1 thread. Most of the credit is owed to @ghesp and @Ryan780. Ryan’s Github instructions are where I learned most of the details.
Wow, this should be the one everyone should be referring for the setup and it should be linked on the top.
Thanks for the kind words. However, I am really not planning on actively maintaining this document as I really created it for myself to be able to recreate my Raspberry Pi should it fail, or I decide to upgrade it. It should also be converted to something a little more web friendly versus a MS Word document.
is there any way to tell Google about this constant announcing of the sender ‘sender Broadcasting’ It is really annoying and not really needed.
By the way. Great work.
Is there any way to change the language of the voice used (i.e. the accent)? Right now I have the American voice (whilst I live in England…) but changing language to “en-GB” doesn’t seem to change anything.
Not sure this has anything to do with the relay
Just read this
https://support.google.com/googlehome/forum/AAAAXWcshA0-tCyTm_Hkbo/?hl=en
Looks like we are not alone
See the issue I’m having is that my Google Home Mini speaks in British English, but if I play the audio file that the relay makes, it’s in American English.
I’m having the same issue so you guys aren’t alone. I’d suggest sending some feedback from the Google home app asking them to make the “new broadcast from” message optional
So I managed to fix the problem of language not changing in the audio files. I edited the conversations.js file in the google-assistant node-module folder and changed “en-US” to “en-GB”. It looks like the config.js for the relay isn’t changing the language properly.
