I have a couple of the Monoprice Z-Wave Plus Open/Close door sensors. They work fine with the SmartThings Z-Wave Plus Door/Window sensor. But they do not work with this DTH. With this code it always displays open. Is everyone else able to get this code to work with the Monoprice sensors?
Kevin,
Is there any way youâd be able to modify this handler to use as integrated smoke detector on a gocontrol door sensor?
Thereâs a handler for the smokes in this thread:
But it was written for a schlage door sensor. It works for a few hours and then fails due to it being for the wrong device type.
Youâd be my new best friend.
Iâm fine with hacking hardware, but I couldnât code my way out of a paper bag.
@krlaframboise, I am using the Door/Window Sensor code for a Monoprice Open/Close sensor. However I would like to modify the code for things like Power detector, Water detector, etc. To do so, I have to display different messages depending on whether the sensor (internal contacts) is open or closed. I am looking at this part of your code, and would like to display different messages based on open or closed:
private createContactEvents(val, contactType) {
def contactVal = (val == 0xFF) ? âopenâ : "closed"
def desc = âContact is $contactValâ
def result = []
result << createEvent(name: "contact", value: contactVal, isStateChange: true, descriptionText: desc)
How would I create unique messages based on open or closed? Example, âPower is normalâ and âPower has failedâ
This DTH was written for the Linear/GoControl door/window sensors so Iâm not sure if it will work with Monoprice. I believe there are a few other DTHs floating around that were written specifically for that product.
The DTH should either work or not work so if itâs working for a while and stopping, it sounds like you have a bigger problem, but this is how you would make it work like a smoke detector.
To change this to a smoke detector DTH, replace the âcapability Contact Sensorâ line with âcapability Smoke Detectorâ.
Then the lines that say createEvent or sendEvent, you should replace the word âcontactâ with âsmokeâ. Then the words âopenâ and âclosedâ with âdetectedâ and âclearâ.
@krlaframboise, I do have the Monoprice Open/Close sensor working with this DTH, However I would like to send different messages based on open or close . See my post #43 above. Can you tell me how to modify the code to display different messages?
All you have to do is replace line:
def desc = "Contact is $contactVal"
with something like:
def desc = (val == 0xFF) ? "New description for open contact" : "New description for closed contact"
any chance to âdecodeâ this for the noobs. What means what?
If you have a specific question Iâll try to help you out, but for general information on how a device handler is structured, please review the Device Handler section of the SmartThings Documentation.
Kevin,
is there a way to have it reverse the color logic for open/closed?
Iâd like a version B of this handler, as I have a door that has a sensor to tell me if it gets closed. It is supposed to remain open for my cats. So on the one sensor Iâd want to show âopenâ as green.
Also, when using the internal contact on the door/window sensor, how do you see the status? I realize itâs only going to show the primary device status on the things screen, but within the device, will it show a secomd open/closed tile for the internal contact, and is this enabled simply by connecting the terminals, or something in the software?
Swap the colors #79b821 and #ffa81e on line 95 and 99.
The main tile shows the state of whichever one changed most recently.
If youâre using a SmartApp like CoRE, you can use the âinternalContactâ and âexternalContactâ attributes to get their state independently.
All you have to do is connect the terminals.
Is anyone else having an issue with cold temperatures? I have my motion sensor outside, and once the temperature drops below 32 F, it starts reporting in the -20s.
Kevin, I swapped the color codes in lines 95/99 and there was no change. Ideas?
I havenât seen this before, but Iâll look into it and get back to you.
Did you publish your changes?
I have 1. Gave up using it for motion so I stuck it in the garage. I was using the temp. in the summer to turn on an exhaust fan. Noticed it was -21 a few days ago.
Brought it in side and back to normal. I just use for temp. as the motion is so slow. For now - it tells me when the cat gets in the cat pan (and out).
Iâm new to the forum⊠Just installed your DHL (GoControl Contact Sensor v1.6.1). From what I read, it has built in support for the Monoprice ZWave Plus Door/Window Sensors? PN: #15270 (Correct me please if I am wrong on that)
âŠIâve noticed on the rboy DHLâer I am using (For Schlage Lock), I can goto the settings/properties of the device under My Home -> Things -> (device) -> COG WHEEL. And it will show me the DHL it is connected through.
How can I verify my door/window sensor is connecting through your DHL?
[quote=âfireheadman, post:60, topic:50728â]
[/quote] If you go into your SmartThings IDE, https://graph.api.smartthings.com, under MyDevices,
The first two columns, find your device by its name, then second column shows the Device Handler Type (I think thatâs what you mean by DHL, DHT?).
Hereâs a better example, as it went quite a bit below freezing this morning. Looks like as soon as it hits 31 degrees or lower, itâs off by 52 degrees. I assume the device is reporting the temperature in Celsius, so possibly a bug in the Celsius to fahrenheit conversion.
Here is what is says:
The first 2 devices are using RBoys DHL, they reflect his DHL label for type
The next 2 I am unsure if these are using @krlaframboise DHL.
Hoping he might chime⊠it is possible he is using the generic name for type in his code???
DHLs:
