Thanks @pstuart my Compro ipcam is working fine just find it odd my rtsp stream is working without the authentication but it is not working on vlc Android, may be it is a good idea not to expose it to internet
Update: a bit more testing with tinycam pro reminds me it works with streaming but not any PTZ control, still a bit scary though
How have you got on with this @bredfiel1 ?
im having the same problems my stream is
rtsp://192.168.0.57:554/onvif1
and it works fine in VLC and vlc doesnāt ask for credentials which is strange but it works.
but the same address wont work with this SmartApp , has anyone managed to get Onvif cameras to work with this?
im on android and the camera is Sumvision Oracle
cheers
Im very new to all this. Hoping someone can point me in the right direction to getting started on this.
I have 3 UBNT cameras that I would like to integrate into my smartthings hubv2. They support RTSP.
Im not a developer so not really sure where to start with all this code etc on the github links, sure with a point in the right direction I could get started.
Update: I seem to have now added the app ok (after some research online). Now I have the app in my IOS device. When I go to Automation>GVCC>New camera, nothing happens? Any ideas?
Are you sure your adding the correct rtsp stream into the address box.
Check it with VLC on a laptop
name the camera
In camera stream path choose a number I think any will do
Then your stream url in the bottom box
Did you add both smartapps in the ide
Hi, so new here, will be buying my Samsung ST hub starter kit soon, end of June. One of the major things I have read about and looking around for is a CCTV or similar camera setup to work out doors and is compatible or useable with ST. Looking at 2 camera, one to the front and back of the house, night vision, clear video and picture quality. With or without sensors, provide live streams and if sensor needed to trigger recordings etcā¦but I find that there are alot of chats about this product and that, but want to keep the cost down, no monthly fees etc. I do have a DLINK NAS box which I can install a 2Gig drive for this purpose of local storage for the camera etcā¦ any recommendations and advise. I have seen a lot of chat about the hikvison. Also this would need to communicate alerts etc to an IOS and Android phone
Hi there, I have a Linksys WVC80N camera which I am trying to stream via pStuartās code. Everything seems to be ready except I canāt seem to find the right url to actually get it streaming. It looks like it is connecting then stops and displays ācamera unavailableā. What I have for the url is http://192.168.1.xxx:port/img/video.mjpeg?user=theusername&pwd=thepassword which is from a previous post in this chain.
Hello all
I canāt believe i am the first one to ask about Q-See DVR cameras they were widely sold at Costco and Sams and all over the place at some point.
Very nice product it works great with their own app and i can see them from the web browser and other apps with no problem. What i am having a hard time getting at them is through VLC so i can use the url.
I have scoured the internet all over and found many promising type of urlās that all seem to work but they are all rtsp and ask for a user name and password that when i enter nothing happens it keeps on asking for it.
When i go though http though my lan it downloads an active x for internet explorer than works fineā¦ other browsers however donāt seem to work.
Also i went and got a generic ip cam viewer app, it is actually called IP Cam Viewer i also watch my work cams with it, for my android phone (not its own Q-see android app) and it picked it right up with no problem as Q-See DVR w/ TCP port 37777 and prompted me for a user name and password and it worked just fine form than on.
So VLC asks for a user name and password but nothing happens when i enter them. Any ideas on how to surpass this issue so i can get the url that works and put it on this ST app side???
The model is QC958 8 HD cam DVR obviously the h264 format.
Here are the urlās that seem to work with VLCā¦ meaning that they will ask you for user name and password while others i have tried do not work flat out and give you an error. the user name and password are the correct ones i have tried it with multiple users and passwords i have added to the system.
Any ideas???
Seems very similar to what my camera outputs,
You donāt mention which platform the VLC is onā¦ Android, Windows etc?
Iāve got my ip from my camera that is
rtsp://192.168.1.41:554/onvif1 and it will connect first time to VLC on my Windows 7 laptop and I donāt even have to enter and password/username.
But when I enter the same IP into VLC on my android tablet it wonāt connect I donāt even get a option to enter password etc and Iāve tried numerous IP addresses with the password included etc.
And this smartapp wonāt accept the same IP also so im a bit stumped at the moment.
Have you tried leaving the password and username blank
My VLC is on Windows 7 desktop and it will prompt me for a user name and password and i enter the correct ones and nothing happens just another user name and password prompt after another.
I have tried leaving them blank still nothing same result
Yay up and running! Got my zmodo cameras ZP-IBH23-S1 x4 working on rtsp if anyone has the same ones i used this for the stream path rtsp://user:pass@ip:10554/tcp/av0_0 seems to be full 1080 stream!
happy would be nice to see if i can find the right combo for jpeg now.
I have a 6 channel laview (rebranded hikvision) NVR w/6 cameras. Iām looking for help with getting this code to work. I copy/pasted the app code to create a new smart app and pasted the handler where it should go, then published both. After entering my cameraās setting in the smartapp and clicking done, nothing gets created in the things section. Any advice? The url I enter in the first box is rtsp://192.168.2.100:554/streaming/channels/101 (or 102 for substream), the next camera would be 201 for instance. This code streams fine in VLC and tinycam. Iāve tried leaving the nvr port at 7080 as well as trying my NVRs port of 8000. I also entered the correct user/pass combo (VLC also asks for this when initiating stream. Thanks!!!
