Hi
This works great for my HEOS by Denon speakers. I can control them with play, pause, next, volume and so on.
One question: Is there any way to send specific playlists or radiostations to the speakers? Or is it only possible to control what ever the speakers are playing now?
And I mean select a different playlist (a preset) directly from ST. Not using a separate mobile app or anything.
Hi @Richierich, Have you installed before an smartapp? you must install the smartapp and device handler using the ide (uk) and after , you must install the smart app in the ios and android app, from marketplace-smartapps , are you saying you cant seen the smartapp in the marketplace ?
Hi @simonselmer, the smartapp is a basic control point, you cant search or create playlist o it, but if you have a MeidaServer like PS3 media server you can create a virtual folders to use it like Containers, once you play a container with your advance control point, smartthings save the url and you can use it to play it after some events, your MR must to support containers, but I think the HEOS can, try to use [Updated] Media Renderer Events, play messages, radio stations, tracks, sounds
Hi ule
Iāve added drivers and modified some devices and Iāve added smart apps in the uk ide before.
What is happening is the smart app isnāt seen in the marketplace for me to install.
I see the device in the mobile app if I make my device in the ide but obviously the device doesnāt work.
Iāve tried a few times but this is a brand new problem for me Iāve not had before so donāt know where to start.
Hi @Richierich, I known its from newbie , but have you publish the smart app? Its very strange you can not find the smartapp in marketplace, maybe a bug in ST, but, could you install other smartapps and those apears in marketplace?, if you can install other smartapps or you have some smartapp already installed, you can edit the smart app and over write the old smartapp, and you can use the mediarenderer connect. try it
Hi
I have a MediaCenter PC currently have a Plex DLNA server enabled, so currently I stream Music from that a that.
But I would like ST to be able to trigger a specific playlist for a specific event.
So can Plex DLNA server be used, is that PS3 media server doing something difference I need to consider?
Iām rather new in this so I need to take it kinda step by step
I should have clarified, and probably posted in that thread, but I am using Media Render Events.
I set up a new event with a motion sensor as the trigger, using Ivona Voice (with both Access Key and Secret Key). When an event is triggered the log shows -
eb1058f9-a72d-456a-8e31-ab376eb4bac4 2:19:14 PM: trace previous notification in progress or Do Not Disturb Activated
I tried again using Smartthings instead of Ivona and my log shows the same message - previous notification in progress or Do Not Disturb Activated
When I use Speaker Weather forecast, with a switch, via Private Dancer, the speaker plays with out a problem.
Hi @simonselmer, First, try to read the first post to know about control point, containers are folders in a dlna server, and the server manage the songs by index, in this way the MR can request the next song without control point, this kind of folders are like playlist, I known PS3 media server can have folders with shorcuts , in this way you can create a folderlist with the shorcuts you want, and launch the folder by ST.
Of course your MR must support containers, MR events have a track option, to send the track from a list of songs you have played before and have a PL prefix to show its a container, if you launch that song you are launching the complete folder.
Its very important to read and understand the firs post.
@Ule - so I stripped the device, smartapp and device type out and reinstalled again from scratch.
And still it isnāt showing in mu apps.
Now Iāve solved it!
Stupid and obvious⦠I had reset the ipad with a secondary account not the primary account! So it was working but you canāt see myapps because they are only visible on the primary account.
Yep as I said earlier, I have written and modified a number of device handlers; granted not a smartapp but about to write my first one to access my solar panel inverter. But I need to packet sniff the inverter packets because the manufacturer doesnāt know if you can pull the info from the web interface! (Chinese manufacturer and I guess it is lost in translation).
About creating those āvirtual foldersā. Do you know if Plex is also able to do that, or is that a special functionality that the PS3 Media Server have?
At first glance, they are both āDLNA serversā right, so does PS3 server do something extra over forexample Plex DLNA server?
Hi - thanks for providing this code - itās saved me a bunch of time and money. I have a question about slow custom message notifications - I went through most of the posts and noticed some people have asked about it, but no one seems to have a solution.
My setup right now is I have an Amazon Fire tablet as my DLNA speaker (using the full paid version of BubbleUPnP) playing through Bluetooth to the Echo. The Amazon Fire tablet is still using FireOS (not rooted) When I open and close the door, I trigger a custom message through the Sonos Notify With Sound Smart App. Everything works great and the messages are played - the only issue is that it takes 5-8 seconds for the message to come through the Echo.
Any suggestions on how to shorten the delay? Thanks!!
Hi @aeroshark, the device is generic dlna , I have added some delay in actions to avoid crash a slow hardware speaker, but software dlna is quicker, if you know how to change the code I suggest you to remove the delay, it will be faster, In next release I going to add a option to remove the delay by unit.
Hi
Iām experimenting getting Radio stations playing on mu HEOS by Denon speakers, and it works, almost.
It seems that it does not set the volume that I write.
But if I try to do the same using the official āSonos Mood Musicā-thing, that can also play the radio station and it sets the volume correctly.
Any idea why your code cannot set the volume on my speakers?
I just write ā20ā and in 20% volume. I assume that is all I have to do. Write the number.
Hi. I have installed PS3 Media Server and Iām trying to figure out how to create Virtual Folders. I dont see it as an option in the application, and when I dont find anything instructions in their FAQ or by googling the topic.
Can shortly explain how to create such Virtual Folders?
Hi @simonselmer, Just search ps3 media server playlist, its easy, create your playlist as m3u file and put in a folder, the server recognize the playlist.
ex. myFolder --> myPlaylist.m3u
In DLNA media control you will see your MyFolder option with your music selection.
Remember to read the first post to know about containers and control point.
Thank you for sharing your work. Iām not familiar with the Smart Things API (mostly Android/iOS apps). The connect smart app found my renderers just fine (Samsung UN48JS8500 and Sony STR-DN1040 receiver). The DLNA player puts the Sony receiver in network mode and receives the audio just fine, however it leaves the receiver in that mode and does not return it to Blue Ray, DVD, or TV mode so that has to be done manually. The Samsung TV pop up the message notice and a portion of the message can be heard (maybe the middle one or two works of the flood detected notice) and then the file icon disappears from the screen and the TV resumes whatever it was doing just fine. So I was wondering with delay setting and so on if there could be an option to either stretch the duration that the file will appear or repeat the message several times to take care of the issue with the TV. As a work around I created a custom message with two or three words that wont get played on the TV and then the actual message.
The Bubble Upnp app seems to work fine on both devices also. Not sure what if anything could be done to the Sony to resume input mode if thats possible with the DLNA schema or methods provided.
Overall though a great start keep up the good work!
Yesterday I tried to add a new Android Device with Bubble Upnp⦠When I opened MediaRenderer Connect and try to search for new devices it seems to have ābrokenā things.
I canāt find my old device (which is still connected to the same network) or my new device.
