hi @dkb, some mediarenderers are slow, I suggest you to increase the time between actions to test if your mediarenderer needs more time, you can change this value editing the device in the app, all mediarenderers I have test take more time over wifi than cable network,
Hi, TextToSpeach function is not working time to time, I have update the fix function, this fix always ask for the native function , if is not working, calls the fix, you can verify Sonos-Notify-with-Sound-External-TTS
You must to update the connect and the player, The tts fix has added a x-rincon-mp3radio protocol for compatibility with sonos
Sucess on Android.
UPNP Monkey renderer
and
Private dancer renderer
discovered within 30 seconds.
But they stay on the list of discovered devices even if they doesnāt exist anymore.
Hi @plantucha, the list is not updated, the next release will delete the uninstalled players from the discovery list, Private dancer still have some issues but UPNP Monkey seems to work pretty fine , if you try the Media Renderer events and select a radio tunes, you can see the art and station description in UPnP Monkey
Hi, Iāve updated and āplayā now works from the Things tab. Android is still crashing everytime I try to go into the device itself, or look at the notifications tab.
Hi @ule. Iāve updated the SmartApp and SmartDevice with the latest code and now it has discovered all my DLNA devices (GraceRadio, Sony AV Receiver, and UPnP Monkey running on Android Table) that wasnāt discovering before.
Note - The Debug messages were a great addition and help to troubleshoot this.
Thanks for this great App.
Hi @RudiP, Great news, IĀ“m glad the device works for you, could you send me the exact model of your devices, to publish in the supported list.
@ule, thanks for the recommendation, but I want to play my own audio files locally. One problem Iāve noticed is that the Sonos Notify with sound has two problems:
- It doesnāt let you specify a specific audio file from your DLNA server. Instead it just lists the recently played files. This is weird. I downloaded a godzilla sound and to get it to show up in the list I had to play it a bunch of times in my DLNA server first.
- There seems to be quite a delay in playback. There are some pre-canned sounds in the Sonos Notify with sound app (door bell, fire alarm, etc) but if you select a DLNA file to play, it seems to take quite a while for it to spool up, sometimes 4-9 seconds.
Anyone else experienced this?
1- DLNA Player is not a Full control point, It receive a url and send it to DLNA Device
1.a The smart apps must to select and send the url to DLNA Player, You can make a DLNA Smartapp who list and selects the files with your DLNA Server (but the ST platform is so limited).
1.b To save the track played, the DLNA device must support Metadata, Once the metadata is sent to smartthings this is saved, I have notice, smartthings platform are not saving and retrieving the saved tracks some times.
2.- The delay in DLNA file is for the Device and Server, they take more time to Process and delivery the file, some DLNA devices and servers are faster than others.
3.- You can add to the smart apps the direct link to use it (just like sound do) , it could be a URL from DLNA file from your server, or a URL file from a web server, in this way you can select the audio file from the smartapp without have to play it before and then selected.
with new android 2.0.4 mobile app doesnāt crash anymore if you open some DLNA speakers. YEEEY
When was this released?
About 3 hours ago today
@ule - Working great now on my Yamaha VX-675 via Airplay. Probably works on all Yamahas.
Kristopher
@zj4x4 @ule
Sorry for the delayed response (almost 8 months I guess). @greg PMād me about this error today and I found your messages while searching the community for it. I will have it fixed in an upcoming release of BigTalker which will be version 1.1.4, likely released this weekend 11/6/15 - 11/8/15.
Hi @ule . Sorry for the delayed reply.
Here are the devices that Iāve tested and that are working with DNLA Player v2.0.0:
Grace Digital Wi-Fi Music Player (GDI-IRC6000)
Sony A/V Receiver (STR-DN1040)
Tagital T10 Tablet (Android 5.1.1) + Private Dancer + Bluetooth to Amazon Echo
ASUS Nexus 7 Tablet (Android 5.1.1) + UPnP Monkey
Note - I just saw that youāve published v2.1.1 and Iāll give it a try tonight.
Thanks again for this great app.
Hi, there is a new update to MediaRenderers events smartapp, now have more then 200 stations, included season christmas, try it
Hi @Patrick_Callahan, thanks you for the donation IĀ“m happy you support this develop I hope to release more features and smartapps
@ule is possible to synchronize DLNA speakers to multiroom configuration?
Iām thinking to use raspberry PI with AVS
and DLNA renderer.
hi @plantucha, it depends on each device, some devices like jongo and sonos suport grouping to syncronize the sounnd in different speakers, sonos have a good documentation for that but I dont known how jongo works, each brand use a custom sync way. If you dont want a sync audio, you can send the same file or streaming to several speakers , but they dont going to be in sync, most dlna speakers do not support in sync.
