Strange that about 25% of these switches that I pair with the hub actually DO come in with native support for the motion sensor, etc. Not sure what the secret is.
Hi LJ_inFLA -
I achieved what you want by setting:
defaultLevel to 99
Timeout Duration 1 minute (5 for your needs)
Mode to Vacancy
and then having two SmartLighting routines that run starting from 10:00pm till Sunrise:
- Turn on and set level to 10% when motion is detected
- Turn on and set level to 100% when button is pushed
So, from 10pm till Sunrise, motion causes the switch to come on at 10% and then pushing the button bumps it up to 100%. After 1 minute, light goes out.
Sorry to bother. I was noticing that I donāt get the interface that is shown in the screenshots. All I get is a generic switch interface. I do see the motion āswitchā when I try to program other devices based on motion though so thatās a plus, and what I was going for.
Edit: any ideas on how to get it? PS, Iām using the new app.
Are you using the ālegacyā SmartThings app or the ānew oneā?
I was using the new one. I just re-downloaded the classic app and it shows up great there.
Okā¦coolā¦I donāt have the new app, but it is my understanding the devices just show up as āstandardā in the new app.
Hi MichaelS, I used your DTH to get Smartthings to recognize my GE smart motion sensor dimmer and itās working great! Thank you so much for your contributions! The problem Iām having is the 26933 doesnāt respond to the Smartthings automation commands. I want the device to only come on starting at 9pm and ending at sunrise. I havenāt been able to get it to respond. Suggestions?
When you say automations what do you mean? I use WebCore to reconfigure the devices based on time and It works great. Native smartthings apps donāt recognize many of the commands of the DTH but WebCore does.
So this is embarrassing, because Iām not a developer or all that tech savvy. I donāt know how to use WebCore. I was barely able to get through the instructions for loading your DTH in the Smartthings EDI. Are you telling me I should bypass the Smartthings app and use this WebCore application? Sorry if this sounds elementaryā¦
And by automations, Iām referring to the Smartthings app.
Decided to go on an adventure of discovery. Registered to both WebCore and GitHub. Now I have to learn how to use the piston capabilityā¦
Below is the piston I use to do what you want to do:
You can replace the global variables (@xxxxxxxxxxxxxxxx) with actual times if you want to keep it simpler. I used global variables as I use the same settings for a number of pistons.
The restriction switch is just a āVirtual Switchā I created in the IDE to be able to turn off all webCore automations without having to get into webCore to do so. Say I want to temporarily pause the pistonā¦ I can go to my āSettingsā room and turn off the virtual switch that controls āNight Light Dimmingā.
Last, you need to add your motion switch/dimmer in the list of devices you allow webCore to access from within the webCore smartapp.
If you use the wmw9r backup code to import this piston, you will have most of it done for you. You just need to adjust it per my instructions above. Hopefully this gets you started.
Also, the webCore community is very helpful: https://community.webcore.co/
Alex,
Thanks so much! Iāve been tinkering with writing a piston, but I donāt have the confidence or experience to know if Iām doing things correctly or not. I will use your template and go from there. Much appreciated!
You are on the right trackā¦Alexās script should get you going into the correct direction.
Soooā¦when I try to import the piston using the code, I get an unpopulated piston. What am I doing wrong? Is this a question for the WebCore forum?
Blank piston? Iāve seen that before. I am not sure what the issue is but a suggestion Iāve been given, and tested successfully, is to close all tabs pointing to webCore and the IDE in all browsers (including your phone). This may be overkill but it has apparently resolved a number of weird issues Iāve seen. Maybe it was just a coincidence, maybe notā¦ worth a try. Either way, I would report it in the webCore community. I havenāt as I always managed to get past the import issue by doing some or all of what I wrote above.
Alex, just tried importing two other pistons with codes and they successfully imported. Could there be something amiss with your import code?
When I tried importing the code it did not work for me either. I modified the piston by simply adding a note and then tried again. After the minor modification I was able to import the piston using the same code shown above. Please try again now.
Yep, worked this time. Thanks, much!
I know this thread is a little old now, but how were you able to get the switch to recognize the new DTH? Iām new to this and like you already had the dimmer installed. I added the device handler on the IDE, but the switch remained the same āgenericā switch in my classic ST app. I then excluded it and readded it, but it is still the generic version without options. My goal is to get the motion sensor for the light in my bathroom to turn on the fan when it senses motion. Currently the ST app only senses it being on or off when the manual buttons are pressed.
