[RELEASE] Free PurpleAir Air Quality Station
dth_sensors
(Gary Luton) #41
Thats great. Thanks Barry!
(Ryan Tollefson) #42
Thanks for this handler!
Has anyone else had issues with temperature being reported incorrectly? Both my indoor & outdoor monitors are showing as 8° F too high. I see in the JSON object that the temp is also showing 8° high, but on the purpleair.com map they both report properly.
Ideas?
#43
From their website:
“Temperature may be elevated and humidity under estimated.”
“The temperature values may be elevated due to the case and other factors that do not provide ideal temperature sensing. These values are provided as is and are just for interest.
Frankly, these readings are so far off that it’s best just to ignore them.
(Acastal) #44
You can email the purple air side about this if you can’t figure it out.
PurpleAir Contact contact@purpleair.com
(Benji) #45
Is there any particular reason why you couldn’t use the outdoor one indoors? Other than the specs differences stated on the website, what are the other differences between the indoor one and outdoor one?
It’s a shame the temp and humidity readings aren’t accurate, I really wish there was one sensor to rule them all…
(Acastal) #46
The indoor one has a visual indicator which is useful. It is pretty ugly however.
#47
No reason whatsoever … lots of outdoor stations seem to be used indoors. Also, you need to keep in mind that the PurpleAir outdoor station (PA-II) looks like an inverted automobile oil filter, so if you don’t mind one of those in your home, go for it, LOL.
Yup … not only is it the same size as a mouse (computer input device), it looks like one too :slight_smile:
(Ilya) #48
@Mspowley Did you ever figure out how to integrate this into ActionTiles? I am having a hard time getting anything to populate besides the temp and humidity.
(Barry) #49
nope- sorry, there isn’t a standard attribute named “aqi” (or “AQI”) in SmartThings.
If the Action Tiles folk want to capture & represent AQI, I’m more than happy to work with them… @tgauchat ???
(fwiw, the temp/humidity/barometricPressure from these devices isn’t meaningful data - it’s measured inside the device so that the lasers are adjusted properly for the ambient operating conditions)
(ActionTiles.com co-founder Terry @ActionTiles; GitHub: @cosmicpuppy) #50
ActionTiles (and the whole SmartThings Platform actually - especially given the inevitable transition to the new API) is designed to work specifically with the official Capability definitions. ActionTiles implements a subset and adds more from time to time.
There is an official Capability for Air Quality.
If there are DHs which conform to it, then we will as well.
https://smartthings.developer.samsung.com/develop/api-ref/capabilities.html#Air-Quality-Sensor
(Barry) #51
If I can figure out how to translate PurpleAir data into the definition of CAQI, I can publish the attribute. But I don’t think this is implemented in the current API (‘classic’) as a Capability.
(ActionTiles.com co-founder Terry @ActionTiles; GitHub: @cosmicpuppy) #52
That’s an interesting question / mystery; but perhaps easily explored. What happens if you claim capability "Air Quality Sensor" in your classic-API DH?
Meanwhile, the pragmatic workaround to get this sort of data into ActionTiles is to masquerade as any ActionTiles support Capability with a simple numeric Attribute (e.g., Energy Meter, Power Meter, Voltage Measurement, Sound Pressure Level…). Sure, the units on the Tile will be nonsense, but the Label and Icon are user selectable.
https://support.actiontiles.com/knowledge-bases/8/articles/3556-compatible-smartthings-capabilities-device-type-abstractions
(Barry) #53
Hmm…surprised I am.
Yes, I can add capability "Air Quality Sensor" to my device, and it creates the airQuality attribute. From the information here (https://en.wikipedia.org/wiki/Air_quality_index#CAQI) I am able to (loosely) translate the hourly average pm2.5 into CAQI values within the defined range (0-100) to populate the attribute.
It appears that the colors used to display CAQI are defined as below:
private def getCaqiColors() {
// Common Air Quality Index
	[value:   0, color: '#79bc6a'],		// Green - Very Low
    [value:  24, color: '#79bc6a'],
    [value:  25, color: '#bbcf4c'],		// Chartruese - Low
    [value:  49, color: '#bbcf4c'],
    [value:  50, color: '#eec20b'],		// Yellow - Medium
    [value:  74, color: '#eec20b'],
    [value:  75, color: '#f29305'],		// Orange - High
    [value:  99, color: '#f29305'],
    [value: 100, color: '#e8416f']		// Red - Very High
I will post the update to my github momentarily.
