After reading some more of the thread… decided to wipe and start over on this project
Foscam C1 → Factory Reset
DHL → Deleted
SmartApp → Deleted
Device → Deleted
Hub → Rebooted, verified everything was gone before I started.
This time I did not use the Foscam Android App to configure the C1.
Did the following:
Initiated the WPS software button on router (R7000 Nighthawk), then pressed WPS button on C1 for a couple seconds, it paired up.
Used Equipment Search Tool to find the IP Address, using Safari, went to http://x.x.x.x:88 (username = admin, passwd = blank/empty)
Logged in, updated admin user/passwd
When through 1-5 step wizard
Clicked Finish, it reconfigured the C1 network and redirected me back to the login.
Logged back in, made the following settings (NOTE: I have not yet configured the C1 to the Device Handler in ST yet)
Basic Settings > Status Light = Yes
Network > UPnP = Yes (Default was No, can this be changed to yes??)
Network > Port (HTTP/HTTPS ports were changed from defaults). Redirected back to login on save, logged back in
Network > Mail Settings (Configured/Test/Verified email) Oddly enough, it was successful, but never received an email.
Network > Onvif = Enabled (Kept all Defaults for ONVIF/RTSP ports)
Video > Video Settings > Enhance Night Vision Definitions = Enabled (Kept all Default settings)
Video > Snapshot Settings > Enable timing to capture = Unchecked (This is the Default… Should this be Enabled??)
Detector > Action Detection > Enabled = Checked (Kept all Defaults) Should these be changed??
Detector > Sound Detection > Enabled = Unchecked (This is the Default)
Rebooted C1 after making changes.
Launched ST, located Device in “Things” tab, configured DHL
Set ipaddr, cam port, username/passwd, rstp port (554), enabled for HD model.
Lastly, click the refresh tile.
When I launched the livestream, it worked this time! Also noticed the IR Led tile, Motion Alarm tile, Snapshot, and Reboot Tiles are working. TO answer my own question in previous post, I can now understand why the connected user account MUST be at an Administrator level to allow a reboot.
BUT… BUT I did still get a green screen on my Android. My Ipad has not.
Android = Galaxy S5
Ipad = Gen 4/Retina
Also looks like the C1 does not support MJPEG streams: (this does nothing)
http://LAN-IPADDR:PORT/cgi-bin/CGIStream.cgi?cmd=GetMJStream&usr=xxxx&pwd=xxx
Other issues:
Once I had everything setup, I logged back into the Foscam WebUI to see how things looked (since the DHL is supposed to override settings). In the Video Detection section, I saw where it changed the sensitivity from Low To Medium… I selected it back to Low in the WebUI (but did not “save” the setting). However, the settings did not go back to Medium when I refreshed the settings… its still on low. And now when I make changes in the DHL options and refresh them with the “Refresh Tile” nothing happens other than seeing the IDE logs show the “tobe” changed settings. Something is now preventing the DHL from updating the foscam.
I have tried rebooting the camera and restarting ST app. No dice! Then I tried turning off emails and the annoying camera alarm. They show unset in the DHL and I saw the change go through the IDE logs, but the Foscam UI is not showing the change being made.
0e4e0e08-3aae-4a17-a56e-xxxxxxxxxx 12:09:14 AM: trace Refresh called. Settings → [ip:192.168.x.xxx, port:xx, username:xxxxxxxxx, password:xxxxxx, rtspport:554, hdcamera:true, mjpeg:false, mirror:false, flip:false, motionLevel:High, soundAlarm:false, motionEMail:false, motionSnap:true, motionRecord:true, motionRing:false, cruisename1:Horizontal, cruisename2:Vertical, lightCompensation:true, detectionArea:area0=1023&area1=1023&area2=1023&area3=1023&area4=1023&area5=1023&area6=1023&area7=1023&area8=1023&area9=1023]
WebUI still shows Low Sensitivity, Camera Sound enabled, and Send Email enabled.
