[RELEASE] FLAIR DEVICES with new capabilities for building physical zones in your home and controlling your mini/window splits, portable heaters/coolers
Hi, it really depends on the IR codes available for your device. You should first contact flair support about it.
If the IR codes support the dry mode, then the Flair device under ST will be able to enable the dry mode. with my code. However, with the new Samsung connect platform, the new capability airConditionnerMode doesn’t always work as planned (work in progress, this is due to the Samsung connect UI, not my code).
Under the old ST platform or under Webcore (rule engine), the dry mode can be enabled.
Regards.
