Hello.
Can anyone point me in the right direction. I was able to add the Fibaro Double Switch 2 FGS-223 into Smartthings classic. However I can’t seem to control the lights whatsoever. The lighting switch and the child devices are not responding on the classic app. When I press ‘ON’ it will show ‘Turning on’ and just remain there.
However I can still control the light from the traditional light switches.
Also I noticed on my IDE page network security level showing “ZWAVE_S0_FAILED”
Does it have anything to do with the unresponsiveness?
I will appreciate any help !
Also to note, I’m using Eric’s handler. I had used the smartthings native handler as well and it wasn’t responding too.
It might be that the Z-Wave inclusion process did not complete properly. See this thread on Having An Issue With networkSecurityLevel: ZWAVE_S0_FAILED where the suggested solution “Try to reboot the hub, reset the device and pair it while it’s close to the hub (within 5ft or so)” worked.
I’m not sure what the default Fibaro handlers might be missing. It wouldn’t hurt to try them out and if you need to, install a community handler. I think there are a few places to find the instructions you are asking for. Here is one:
@erocm1231
After updating yesterday the HUB to Firmware : 000.030.00003
The status is not updated when turning on via the mechanical switch , status keep showing OFF. Or if turning off via mechanical switch , status keep showing ON. Can you please check? Friends of mine are having the same behaviour. Can you please advise…
Just to add some more info. I live in the UK.
I recently purchased 2 Fibaro Single Switch 2s (FGS-213 EU v3.3) and 1 Fibaro Double Switch 2 FGS-223 EU v3.3 but with each device adding using the standard options I get the message “Some security features not supported. Your device has been connected but it isn’t using the highest level of security. Use a newer Z Wave device for the highest security”. These switches are brand new from a reputable UK supplier!
The Double Switch 2 works fine both with Smartthings allowing the switch to be turned on and off via using the screen with the switch status being updated ok.
The Single Switch 2s do not get the switch status updated (spinning circle for 20 secs. If I turn the switch on the relay operates ok but ST still shows it as Off. The switches work fine via automations. Upgrading the Hub to
So my symptoms are the opposite to others. Just wondering if that might be down to mine being v3.3 firmware whereas lots of people reporting other issues seem to refer to Fibaso v3.2 firmware. Upgrading the hub made no difference.
Fibaro Double Switch 2 ZW5 is the DTH for the main device. Fibaro Double Switch 2 USB is the DTH for the second channel. They don’t run locally but they are the best ones to use now.
