SmartThings Community
[RELEASE] Enhanced ZigBee Keypad - Centralite Keypad, Lowes IRIS Keypad, UEI Keypad and Xfinity Keypad Device Handler
dth_locks
dth_security
adt
dth_temperature
rboyapps
(www.rboyapps.com - Make your home your butler!) #1
RBoy Apps is a SmartThings partner for Centralite
On popular request request here is a Enhanced ZigBee Keypad device handler that can make your keypad work like a lock keypad in SmartThings so it can work with SmartApps designed for managing locks/doors/garage doors, user codes and lots more. (see below for more details).
This Device Handler is compatible with most ZigBee keypads like the Centralite, UEI, Xfinity and Lowes Iris keypads.
The UEI keypad can be bought from eBay for about $15
The Xfinity keypads can be purchased from Comcast Home Security or from eBay (3400-X and XHK1) for about $10 to $20
The Lowes IRIS v3 keypad (IL021) can be bought from Lowes or from eBay for about $40
The Lowes IRIS v2 keypad (3405-L) can be bought from Lowes or from Amazon for about $40
The Centralite 3400-X keypad can be bought from Amazon or from eBay for about $45
The Centralite 3400-C retail smart keypad can be bought from Centralite or from Amazon
Battery Notes:
  • The IRIS v2/Centralite 3400-C/Xfinity 3400-X keypads use 2 x CR123A batteries
  • The newer UEI/Xfinity XHK1/IRIS v3 keypads use 4 x AA batteries and last 3 - 8 times longer than the other keypads depending on the type of battery used (Lithium, Alkaline, NiMH/NiCd)
UEI/Xfinity XHK1->
Centralite<-Centralite/Xfinity 3400-X
Iris v2 (3405-L)->Iris <-Iris v3 (iL02_1)
Centralite 3400-C ->Keypad
You can find the latest features and supported models on our website
This device handler supports the following features (refer to the release notes/website for latest updates):
  1. Work as a keypad lock in SmartThings
    • Set/use 4 digit codes
    • Enable/disable keypad
    • Enable/disable auto lock
    • Lock and unlock using user codes
    • Invalid code notifications
  2. Ability to arm/disarm SHM directly from supported keypads
  3. Read the following sensors
    • Temperature (auto convert to F or C depending upon your location)
    • Motion
    • Battery (new battery calibration algorithm)
      • Centralite/Iris v2/Xfinity keypad support for CR123A Lithium batteries
      • UEI/Xfinity/Iris v3 support for AA Lithium, Alkaline, NiMH/NiCD batteries
    • Tamper
  4. Use as a Tone capability device (beep/chime)
  5. Use as a Siren/Alarm capability device (supported models)
  6. Locate keypad using a beep
  7. Ability to configure the following parameters:
    • Auto lock delay
    • Number of beeps (for beep command)
    • Temperature offset (for correcting the temperature reported by the sensor)
    • Ability to configure the Inactivity timeout (the number of minutes since the last motion was detected after which the motion sensor sends a no motion detected event)
    • Select battery types for AA models
  8. Use with Lock User Management (LUM) to control SHM directly from the keypad
  9. Compatible with SmartLocks and lock/code management apps like Lock User Management (LUM) and Rental Lock Automater (RLA)
  10. Use with Lock & Door Synchronizer to control Garage Doors, Patio Doors and synchronize with other locks/devices
  11. Compatible with legacy SmartApps designed for direct keypad integration
  12. Use with Chime and Notifications for Doorbells and Sensors
Siren and Chime Features
  • Keypads which have a built in beeper can be used as a Chime for sensors/buttons (e.g. door bells or door open/close) using the Beep or Tone capability
  • Iris keypads have a built in Siren that can be triggered with the panic button or independently as an Alarm
    • Iris v2 (3405-L) 60dB siren
    • Iris v3 (iL02_1) 85dB siren
      You can use these keypads with a compatible Chime SmartApp
Sample Use Cases for Keypads in SmartThings (requires compatible SmartApps)
  • Siren/alarm (models which support it)
  • Chime/beeper to notify when doors/windows are opened/closed
  • Panic button
  • Secondary keypad for locks
  • Primary keypad for garage doors/patio doors
  • Temperature sensor
  • Motion sensor (for close up motion)
  • Program codes and create custom actions for each code and for each button (away/night/home)
    • Run/activate/deactivate switches/controls/routines etc
    • Create custom actions
    • Arm/disarm SHM/ADT/Intruder/Security System/Hub modes
  • Chime the keypad when doors/windows are opened or something is turned on/off
Supported apps like Rental Lock Automater, Lock User Management and CoRE/WebCORE can allow the keypad to arm/disarm SHM directly:
  • Lock User Management (LUM) and Rental Lock Automater (RLA) -> Enable the option for Control SHM using keypad under the Lock/Unlock actions.
  • CoRE/WebCoRE -> Use the parameter armMode in the data field of the “lock” event while creating a custom action. The reported values are:
    • 0 for Disarm
    • 1 for Armed Stay
    • 2 for Armed Night
    • 3 for Armed Away
  • CentraliteS image UEI%20CodeCentralite/UEI/Xfinity keypad (assuming the user code has been programmed):
    • to arm SHM press one of the 3 modes buttons on top followed by a valid 4 digit user code
    • to disarm SHM enter a valid 4 digit user code
  • IrisS Iris v2 keypad (assuming the user code has been programmed already):
    • to arm SHM enter a valid 4 digit user code followed by the Partial button (Armed Stay) or the On button (Armed Away)
    • to disarm SHM enter a valid 4 digit user code, press the OFF button
  • IRIS%20Arming Iris v3 keypad (assuming the user code has been programmed already):
    • to arm SHM press the Partial button (Armed Stay) or the On button (Armed Away) (this keypad does NOT support user codes for arming)
  • When SHM is armed via the keypad, the LED light on top will glow red and the appropriate mode button will light up (if present) (required supporting SmartApp)
  • When SHM is disarmed via the keypad, the LED light will be green/red OFF button will light up (requires supporting SmartApp)
NOTE:
  • This device handler is compatible with Mitch Pond/Zack Cornelius dth so you can use it with the existing apps like Keypad Coordinator, SmartAlarms, SHM Delay etc
  • Since the device has no “physical” locking mechanism, it is recommended to use it in conjunction with SmartApps like CoRE, WebCORE or Door Lock Code User Management or Rental Lock Automater to control a physical switch or lock etc.
  • The Iris v3 Keypad arms directly when the On/Partial button is pressed. It does not use a 4 digits code for arming like the other keywords.
  • For operating other keypads, press an action button (off/on/night/away/stay) followed by a 4 digits user pin.
Low Battery: If your battery below 20% consider replacing it. The unit will start flashing a red light when the battery level is low.
More features to added, if you have any suggestions or ideas please feel free to ask and we’ll try to add it.
INSTALLATION INSTRUCTIONS
You can find the step by step instructions to install the Device Handler here.
INCLUSION INSTRUCTIONS:
It is recommended to install the Device Handler BEFORE paring the device for easier setup.
  1. Remove the batteries from the device
  2. Open the SmartThings mobile app and click on + or Add a thing to put the hub into pairing mode
  3. Make sure you’ve inserted the covering piece at the back of the device so that pairing button is pressed
Centralite 3400-C/Xfinity 3400-X/Iris v2
  1. Remove the covering piece
  2. Press and hold the tamper switch
  3. While holding the tamper switch insert one battery into the device (use CR123A Lithium batteries)
  4. Release the tamper switch
  5. It should complete pairing within 30 seconds and it should show up on your SmartThing mobile device
  6. The device wifi/signal LED should be flashing green
  7. Insert the second battery and the wifi/signal LED should stop flashing
  8. Re-insert the covering piece (if the LED doesn’t stop flashing see the TIPS below)
Paired
UEI/Xfinity XHK1
  1. Insert the 4 batteries (use AA Lithium 1.5v batteries for best performance, AA Alkaline batteries or AA Rechargeable NiMH/NiCd batteries).
  2. The Pairing LED light should start flashing (indicating it’s in pairing mode). If the light is not flashing, follow the Exclusion Instruction below to get it back into pairing mode
  3. The device wifi/signal LED should be flashing green
  4. On successful pairing the pairing LED should flashing and the the wifi/signal LED should be lit
  5. Set the battery type (Lithium, Alkaline, Rechargeable) in the device preferences page (click the Gear icon on top right corner of the keypad page in the ST Classic app), after pairing for accurate battery life reporting
UEI%20PairingUEI%20Paired
Iris v3
  2. The Pairing LED light should start flashing blue (indicating it’s in pairing mode). If the light is not flashing, follow the Exclusion Instruction below to get it back into pairing mode
  3. On successful pairing the pairing LED should flashing green
  4. Set the battery type (Lithium, Alkaline, Rechargeable) in the device preferences page (click the Gear icon on top right corner of the keypad page in the ST Classic app), after pairing for accurate battery life reporting
Iris%20Battery IRIS%20Pairing Iris%20Reset
TIP: If you’re having trouble pairing the device, power cycle your hub and try to exclude the device first
TIP: If the network LED continues to blink even after pairing, press the tamper button 5 times to reset it
TIP: If all the mode lights are blinking (On/Partial/Off or Away/Stay/Night etc), this means that the keypad has lost it’s connection with the mesh. Move the keypad closer to the hub (or add a ZigBee repeater). If that doesn’t work, remove the battery for a few seconds, re-insert it and then tap the refresh tile to resync and reestablish communication with the hub.
EXCLUSION INSTRUCTIONS:
Click on the gear icon (top right corner) in your SmartThings mobile phone device page. Scroll down to the bottom and click Remove and follow instructions.
FACTORY RESET INSTRUCTIONS:
Centralite/Xfinity/Iris v2/UEI
  • If the exclusion was not successful (which can happen if the device did not receive the exclusion notification from the hub, when not paired the wifi/signal LED will not be lit), remove the cover and the batteries, keep the tamper/pairing button pressed while inserting the batteries and then release the tamper/pairing button. For the XHK1 models it should make the pairing LED start flashing
  • Press the tamper switch 5 times to reset the keypad
Iris v3
  • Remove 1 battery and wait ten seconds
  • Re-insert the battery while holding down the reset button on the side and release when the status light blinks red once and then start blinking blue
This device type handler is available on the RBoy Apps Server, http://www.rboyapps.com. Refer to our website or facebook page below to get access to the server.
Visit our Facebook page for updates on new apps and to get access to our Premium Apps. http://www.facebook.com/RBoySTApps
© RBoy Apps
[RELEASE] Lock and Door Synchronizer, synchronize your locks with other locks, deadbolts, doors, switches/relays
ZWave Popp Keypad Device Handler?
Door open sensor --> Chime/Speaker in office setting?
Xfinity 2nd generation keypad help
[RELEASE] Lock User Management - Door lock code manager (create, delete and schedule codes) with automatic lock/unlock, custom user actions and SHM/ADT integration
[Release] SHM Delay Version 2.0
Looking for a Z-wave buzzer/noise maker for local sound notification
Tired of trying to get smartthings working
[RELEASE] Lock Manager API - Control your locks and manage users remotely
Keypad to control modes?
[RELEASE] Lock User Unlock/Lock Door Notifications and Actions
Restroom access control from a Switch?
[RELEASE] Rental Lock Automater - Automate user codes with AirBnB, HomeAway, VRBO, TripAdvisor and Booking.com for multiple properties
FAQ: Can I add a keypad to control my garage door?
POPP - Z-Wave Plus KeyPad? Other U.K. Keypad Options?
[RELEASE] Chimes and Notifications for Doorbells and Sensors
[RELEASE] Security System: Intruder Alert with Actions (Lights, Alarms, Pictures/Cameras, Routines etc)
Does Iris window/door sensors work with Smartthings Hub?
Introduction to SmartThings for Iris Customers
Iris Keypad
Keypad for my new Samsung Smartthings setup?
Iris Keypad
XFinity Centralite 3400: how can I set up automations for it?
Change SHM without phone?
Help Needed for outdoor access control project, keypad (not sure which yet) plus PROMAG ER750 RFID reader (EU)
Can't pair Xfinity XHK1-UE keypad
Switching from Iris - any help in making the right purchase?
Corrupt device is causing 500 Internal Server Error
Iris user thinking about switching to Smart Things
Getting there from fresh install. ADT Smartthings app and configuration advice sought. Iris orphan needing to get to speed
Iris User - Looking for info
Thinking of coming over from Iris to SmartThings ADT starter pack
Lowe's Iris is officially history!
Setting up Smartthings to replace my Iris setup. Some items of concern
Xfinity centralite 3400 in the UK?
The Quest for A 100% Reliable Presence detection
[RELEASE] Lowes Iris and XFinity CentraLite keypad DTH + Apps
(MacTechGenius) #2
Is this a device handler or a smart app?
So it works with Lock Manager but does it work with [RELEASE] Keypad Coordinator - Bring out the power of your Keypads
(www.rboyapps.com - Make your home your butler!) #3
It’s a device handler and it works with all the legacy/older SmartApps that relied on the custom keypad DTH (see first post).
It has added new capabilities to allow it to work the SmartApps that use “lock” capabilities like Lock Code User Management, lock manager and SmartLocks.
(Tim) #4
What are the main differences or advantages from this one?
Does it work with ArnB’s Delay and Xfinity 3400?
Thank you!
(www.rboyapps.com - Make your home your butler!) #5
This DTH retains compatibility with the older DTH so works with the Apps you’ve mentioned (on request from users, see below)
We’ve added new capabilities of locks and user programming so that it can be used with SmartApps that are designed to work with locks. It has also new additional features like Alarms, Panic buttons for the IRIS keypads v2 and v3, enabling/disabling the keypad and lots more.
So you can use it with the SmartApps you’ve mentioned and the newer Lock/User management SmartApps (at the same time).
Yes it’s compatible with the Xfinity 3400 (see the screenshots) and the IRIS 2405, we’re working on adding more keypads models to it. If you have any requests for specific models please send them in.
(Joel W) #6
I have a problem, I replaced the standard Centralight DTH with yours and the status says unknown. Did I miss something? Is that because I have no door locks? If so it would be nice if it could be removed if no lock present.
(www.rboyapps.com - Make your home your butler!) #7
That’s the “lock” status, since it’s never been used as yet it’s showing “unknown”, just tap on it and it’ll initialize itself.
Not sure what you mean by remove since this is a lock DTH so it will show the “current” status of the last action taken (locked or unlocked)
EDIT: We have a new app coming out shortly that will complement this DTH and would probably address your question for the use of the lock
(Jeremiah Goode) #8
I have the device handler installed and am using your “Door lock code user management with notifications and automatic relock, Lock User Management v07.01.00” and am having an issue.
I have configured the lock “Xfinity 3400-X keypad” lock\unlock actions to the following:
Keypad Unlock Actions: Run a routine, Change mode to Home and Disarm Smart Home Monitor
Keypad Lock Actions: Run a routine, Change mode to Away and Arm Smart Home Monitor to Away
Manual Unlock Actions: Run routine, Change mode to Home and Disarm Smart Home Monitor
Manual Lock Actions: Run a routine, Change mode to Night and Arm Smart Home Monitor to Home
I hit one of the three button on the top of the Xfinity keypad and enter my code. It beeps to confirm and doesn’t change the SHM mode, the mode stays on Disarmed. If I manually change the mode to Armed(away) or Armed(stay) and push any of the three buttons on the top of the Xfinity keypad and enter my code, the SHM mode changes to Disarmed. If I just put in my code w/out pressing any of the three buttons on the top of the Xfinity keypad it also changes the SHM mode to Disarmed if in any other SHM mode besides Disarmed.
I’m not sure what I am doing wrong, is there something wrong w/ my setup?
Thanks,
JMG
(www.rboyapps.com - Make your home your butler!) #9
Update to the latest version 07.05.01, it adds support for the keypad locks - you should also see a new option to directly arm/disarm SHM from the keypads.
(Jeremiah Goode) #10
Ok I’ve updated to 07.05.01. I did see a new option under lock/unlock actions for the xfinity keypad unlock actions that now says “control smart home monitor using keypad” instead of what it used to say and still says under Manual Unlock Actions “Disarm Smart Home Monitor” but I haven’t found the new option to directly arm/disarm SHM from the keypads.
Where is that option? I’m still not able to arm w/ the new version. I can disarm but can’t arm stay or away.
JMG
(www.rboyapps.com - Make your home your butler!) #11
This is it
EDIT: And I verified it’s working fine with both locks and keypads.
(www.rboyapps.com - Make your home your butler!) #12
On popular request:
Enhanced ZigBee Keypad Lock - Version 01.01.00
  • Added support for UEI and Xfinity XHK1-UE keypads
  • Updated DTH to support latest ST ZigBee framework
This is a low cost keypad and can be purchased on eBay for about $10 to $20. See first post for pairing instructions.
(Jeremiah Goode) #13
under “Keypad Unlock Actions” the setting for “Control Smart Home Monitor using keypad” is enabled, it will disarm the SHM but I can’t for the life of me figure out how to get it to Arm (away or stay) the SHM.
is there a step by step walk through manual that I can follow to ensure I have the proper things setup?
I chose the option to “Seperate actions for each door” and then configured the keypad and manual lock and unlock actions but it just won’t work.
JMG
(www.rboyapps.com - Make your home your butler!) #14
You’ve done it, that’s it (see the first post for step by step).
I tested it here with the Xfinity keypad, IRIS, UEI and Centralite and it’s working fine with all of them. I suspect something else may be going on with your account. Best way to check, open IDE Live Logging, Tap the Away button on your keypad, enter your 4 digit code and look at the logs. The SmartApp should send say sending an arm away signal to ST. Then look into your SHM logs to see what may be going on.
This is what you’ll see in your logs
8:54:34 PM: trace No individual routine configured to run when locked via keypad for Iris 3405-L Keypad
8:54:34 PM: trace Did not find per user lock actions, falling back to global lock actions
8:54:34 PM: info Arming Smart Home Monitor to Away
8:54:34 PM: trace No user Test specific lock action found, falling back to global actions
8:54:34 PM: trace Lock event name lock, value locked, device Iris 3405-L Keypad, description Locked by “Test”, data {“usedCode”:“1”,“codeName”:“Test”,“method”:“keypad”,“armMode”:“armedAway”,“microDeviceTile”:{“type”:“standard”,“icon”:“st.locks.lock.locked”,“backgroundColor”:"#00a0dc"}}
8:54:34 PM: trace Iris 3405-L Keypad locked by user 1 via keypad
It’s possible that your actions/routines are interfering with your SHM, turn off all actions and turn them back on one by one until you see which one is interfering.
(www.rboyapps.com - Make your home your butler!) #15
In addition to the above, on the first page of the SmartApp, scroll down to the bottom and under advanced settings and enable Detailed notifications, now it’ll send you a notification for actions it’s taking (arming/disarming, running routines etc). That will tell you if the SmartApp is sending the signal to arm SHM.
I’m experiencing the exact same issue using a Centralite 3400-x. Disarm works as expected, however, I can’t arm SHM no matter my settings.
(www.rboyapps.com - Make your home your butler!) #17
Did you try this and look at your IDE logs?
(Jeremiah Goode) #18
My issue was that I had specific actions defined for locks per user. I was trying to setup the General Settings\Lock/unlock actions and the user\custom actions/notifications settings appear to conflict. I removed the General Settings\Lock/unlock actions and defined the user\custom actions/notification settings actions and it is working good now.
The only minor issue I have now is that when I ARM(AWAY) or ARM(STAY) using my phone app (I have the rules setup to lock the Xfinity) the keypad doesn’t turn red like when it is armed from the keypad itself. I’m not sure if that can be fixed or not, if so that would be awesome. Right now we are putting in our code everytime we can to leave the house to disarm as we don’t know the SHM state w/out looking at our phones.
(www.rboyapps.com - Make your home your butler!) #19
Glad you figured it out. User actions take precedence over general actions when defined.
You can define the direct keypad arming/disarming also in the user specific actions so that some users can arm using the keypad while other can only lock/unlock.
This is by design, in this instance the keypad is being used as standalone lock device and not a general security keypad. The purpose of the light is to show the status of the lock device (locked or unlocked). So when you lock it via the keypad it turns red and when unlocked it’s green/white (depending on the keypad model).
(Jeremiah Goode) #20
so if you lock the keypad from the keypad it turns red, but if you lock the keypad from the smartthings app it doesn’t, right? what’s the difference? The keypad is locked, knows its locked, but only turns red if you do it from the keypad. So it doesn’t seem to have anything to do w/ your smartapp, has something to do w/ the device itself? Or the device handler?
