[RELEASE] Enhanced Z-Wave Plus Thermostat Device Handler - Honeywell, GoControl, CT, Linear, Trane, MCO, Remotec
From what I remember, this is a modification of SmartThings official device type. That official device type changes from time to time. So, rather than having to constantly update an entire device type, it is shared as modifications. Complicating matters, SmartThings doesn’t notify us when they push updates. This also allows you to chose which changes you wish to have.
That being said, I’m not a coder either and tackled this during the first few weeks that I had my hub. Give it a shot. You can’t really “break” anything. The directions are pretty clear and it’ll give you a little exposure to how these things are written.
I also have the CT100 and have had luck with this. Although, I can’t get battery % to show up anymore. I may retry soon. If you’re still having trouble, I can share the “latest” with all the changes.
That’s right @DITPL. @ultrazero The whole point of the modifications rather than code was so people can pick and choose their customizations and also they aren’t tied into any base code as device code changes from time to time.
As a workaround I’ve also put up the “whole” device code with all the above modifications on the server for folks who prefer to copy paste which I update from time to time with the latest code base.
Somewhere on GitHub?
Thanks. I’ll give it a try. Just was a little daunting! :blush:
Ok. That wasn’t so bad at all. Even felt comfortable making some modifications on the fly and it worked on the first try. Thanks @RBoy for putting this together.
Fyi, I went to my hello home phrases a few minutes after testing the new device type and the battery/humidity info came right over. Perhaps this is some way to quickly poll the device without waiting 24 hours?
What would be really great is making a change to the device type so that I can click into my thermostat device by clicking the main part of the tile and not having to hit the small gear icon. Hate that! Maybe I have large fingers.
Lastly, so since I created this from a template, this is now a new device type that belongs to me right? Meaning… Any updates ST makes to the thermostat device type will not effect mine.
Thanks!!
The above customization does not take into count Celsius settings. When I first implemented the changes my Fireplace came on and the Target Temp Point was 30 degrees. In my case that is 30 degrees Celsius (about 86F) . I was unable to lower the temperature below. Review the customization shown above I noticed:
def heatLevelDown() {
int nextLevel = device.currentValue(“heatingSetpoint”) - 1
if( nextLevel < 30) {
nextLevel = 30
log.debug “Setting heat set point down to: ${nextLevel}”
quickSetHeat(nextLevel)
This routine needs to take into account the current Temp Scale setting.
i.e.
If Scale =C then MinTemp=0 else MinTemp=30
if( nextLevel < MinTemp) {
nextLevel = MinTemp
Sorry for the delay and thanks for pointing this out, will fix it.
For whatever reason I can’t seem to edit my original post. I can edit my recent posts just not the initial ones.
@April I had sent you a PM on this please see if you can have this fixed.
In the interim here is the updated code, hopefully ST will be able to fix the option to edit posts and I’ll update the original post also.
def coolLevelUp() {
    def locationScale = getTemperatureScale()
    def maxTemp
    def minTemp
    if (locationScale == "C") {
    	maxTemp = 37 // Max Temp in C
        minTemp = 1 // Min Temp in C
    	log.trace "Location is in Celsius, MaxTemp $maxTemp, MinTemp $minTemp"
    } else {
    	maxTemp = 99 // Max temp in F
    	minTemp = 35 // Max temp in F
    	log.trace "Location is in Farenheit, MaxTemp $maxTemp, MinTemp $minTemp"
    int nextLevel = device.currentValue("coolingSetpoint") + 1
    if( nextLevel > maxTemp) {
    	nextLevel = maxTemp
    log.debug "Setting cool set point up to: ${nextLevel}"
    quickSetCool(nextLevel)
def coolLevelDown() {
    def maxTemp
    def minTemp
    } else {
	int nextLevel = device.currentValue("coolingSetpoint") - 1
    if( nextLevel < minTemp) {
    	nextLevel = minTemp
    log.debug "Setting cool set point down to: ${nextLevel}"
def heatLevelUp() {
    def maxTemp
    def minTemp
    } else {
    int nextLevel = device.currentValue("heatingSetpoint") + 1
    	nextLevel = maxTemp
    log.debug "Setting heat set point up to: ${nextLevel}"
    def maxTemp
    def minTemp
    } else {
    int nextLevel = device.currentValue("heatingSetpoint") - 1
    	nextLevel = minTemp
    log.debug "Setting heat set point down to: ${nextLevel}"
@RBoy just confirmed: changed settings to allow people to edit posts after more than 30 days… :slight_smile:
Perfect, it works now. Thanks @April
I’ve update the code above.
I’m having some trouble creating the device type. It’s telling me:
Org.springframework.dao.DuplicateKeyException: a different object with the same identifier value was already associated with the session: [physicalgraph.device.CapabilityDeviceType#physicalgraph.device.CapabilityDeviceType : (unsaved)]; nested exception is org.hibernate.NonUniqueObjectException: a different object with the same identifier value was already associated with the session: [physicalgraph.device.CapabilityDeviceType#physicalgraph.device.CapabilityDeviceType : (unsaved)]
I’m sure I pasted incorrectly. Any chance someone can post their code? I’m using all the options RBoy gave. Thanks.
@RBoy
Can you please help me out here? I can’t find my error. I’m looking for all options listed above. Thanks.
try this: :smile:
metadata {
	// Automatically generated. Make future change here.
	definition (name: "Z-Wave Thermostat", namespace: "smartthings", author: "SmartThings") {
		capability "Actuator"
		capability "Temperature Measurement"
		capability "Relative Humidity Measurement"
		capability "Thermostat"
		capability "Configuration"
		capability "Polling"
		capability "Sensor"
        capability "Refresh"
    	capability "Battery"
    	command "refresh"
		attribute "thermostatFanState", "string"
		command "switchMode"
		command "switchFanMode"
        command "quickSetCool"
        command "quickSetHeat"
		fingerprint deviceId: "0x08"
		fingerprint inClusters: "0x43,0x40,0x44,0x31"
	// simulator metadata
	simulator {
		status "off"			: "command: 4003, payload: 00"
		status "heat"			: "command: 4003, payload: 01"
		status "cool"			: "command: 4003, payload: 02"
		status "auto"			: "command: 4003, payload: 03"
		status "emergencyHeat"	: "command: 4003, payload: 04"
		status "fanAuto"		: "command: 4403, payload: 00"
		status "fanOn"			: "command: 4403, payload: 01"
		status "fanCirculate"	: "command: 4403, payload: 06"
		status "heat 60"        : "command: 4303, payload: 01 09 3C"
		status "heat 68"        : "command: 4303, payload: 01 09 44"
		status "heat 72"        : "command: 4303, payload: 01 09 48"
		status "cool 72"        : "command: 4303, payload: 02 09 48"
		status "cool 76"        : "command: 4303, payload: 02 09 4C"
		status "cool 80"        : "command: 4303, payload: 02 09 50"
		status "temp 58"        : "command: 3105, payload: 01 2A 02 44"
		status "temp 62"        : "command: 3105, payload: 01 2A 02 6C"
		status "temp 70"        : "command: 3105, payload: 01 2A 02 BC"
		status "temp 74"        : "command: 3105, payload: 01 2A 02 E4"
		status "temp 78"        : "command: 3105, payload: 01 2A 03 0C"
		status "temp 82"        : "command: 3105, payload: 01 2A 03 34"
		status "idle"			: "command: 4203, payload: 00"
		status "heating"		: "command: 4203, payload: 01"
		status "cooling"		: "command: 4203, payload: 02"
		status "fan only"		: "command: 4203, payload: 03"
		status "pending heat"	: "command: 4203, payload: 04"
		status "pending cool"	: "command: 4203, payload: 05"
		status "vent economizer": "command: 4203, payload: 06"
		// reply messages
		reply "2502": "command: 2503, payload: FF"
	tiles {
		valueTile("temperature", "device.temperature", width: 2, height: 2) {
			state("temperature", label:'${currentValue}°',
				backgroundColors:[
					[value: 31, color: "#153591"],
					[value: 44, color: "#1e9cbb"],
					[value: 59, color: "#90d2a7"],
					[value: 74, color: "#44b621"],
					[value: 84, color: "#f1d801"],
					[value: 95, color: "#d04e00"],
					[value: 96, color: "#bc2323"]
		standardTile("mode", "device.thermostatMode", inactiveLabel: false, decoration: "flat") {
			state "off", label:'${name}', action:"switchMode", nextState:"to_heat"
			state "heat", label:'${name}', action:"switchMode", nextState:"to_cool"
			state "cool", label:'${name}', action:"switchMode", nextState:"..."
			state "auto", label:'${name}', action:"switchMode", nextState:"..."
			state "emergency heat", label:'${name}', action:"switchMode", nextState:"..."
			state "to_heat", label: "heat", action:"switchMode", nextState:"to_cool"
			state "to_cool", label: "cool", action:"switchMode", nextState:"..."
			state "...", label: "...", action:"off", nextState:"off"
		standardTile("fanMode", "device.thermostatFanMode", inactiveLabel: false, decoration: "flat") {
			state "fanAuto", label:'${name}', action:"switchFanMode"
			state "fanOn", label:'${name}', action:"switchFanMode"
			state "fanCirculate", label:'${name}', action:"switchFanMode"
		controlTile("heatSliderControl", "device.heatingSetpoint", "slider", height: 1, width: 2, inactiveLabel: false) {
			state "setHeatingSetpoint", action:"quickSetHeat", backgroundColor:"#d04e00"
		valueTile("heatingSetpoint", "device.heatingSetpoint", inactiveLabel: false, decoration: "flat") {
			state "heat", label:'${currentValue}° heat', backgroundColor:"#ffffff"
		controlTile("coolSliderControl", "device.coolingSetpoint", "slider", height: 1, width: 2, inactiveLabel: false) {
			state "setCoolingSetpoint", action:"quickSetCool", backgroundColor: "#1e9cbb"
		valueTile("coolingSetpoint", "device.coolingSetpoint", inactiveLabel: false, decoration: "flat") {
			state "cool", label:'${currentValue}° cool', backgroundColor:"#ffffff"
		standardTile("refresh", "command.refresh", inactiveLabel: false, decoration: "flat") {
		state "default", action:"refresh.refresh", icon:"st.secondary.refresh"
    valueTile("battery", "device.battery", inactiveLabel: false, decoration: "flat") {
		state "battery", label:'Battery ${currentValue}%', backgroundColor:"#ffffff"
    valueTile("humidity", "device.humidity", inactiveLabel: false, decoration: "flat") {
		state "humidity", label:'Humidity ${currentValue}%', backgroundColor:"#ffffff"
	main "temperature"
	details(["temperature", "mode", "fanMode", "heatSliderControl", "heatingSetpoint", "coolSliderControl", "coolingSetpoint", "battery", "humidity", "refresh", "configure"])
def parse(String description)
	def map = createEvent(zwaveEvent(zwave.parse(description, [0x42:1, 0x43:2, 0x31: 3])))
	if (!map) {
		return null
	def result = [map]
	if (map.isStateChange && map.name in ["heatingSetpoint","coolingSetpoint","thermostatMode"]) {
		def map2 = [
			unit: getTemperatureScale()
		if (map.name == "thermostatMode") {
			state.lastTriedMode = map.value
			if (map.value == "cool") {
				map2.value = device.latestValue("coolingSetpoint")
				log.info "THERMOSTAT, latest cooling setpoint = ${map2.value}"
			else {
				map2.value = device.latestValue("heatingSetpoint")
				log.info "THERMOSTAT, latest heating setpoint = ${map2.value}"
		else {
			def mode = device.latestValue("thermostatMode")
			log.info "THERMOSTAT, latest mode = ${mode}"
			if ((map.name == "heatingSetpoint" && mode == "heat") || (map.name == "coolingSetpoint" && mode == "cool")) {
				map2.value = map.value
				map2.unit = map.unit
		if (map2.value != null) {
			log.debug "THERMOSTAT, adding setpoint event: $map"
			result << createEvent(map2)
	} else if (map.name == "thermostatFanMode" && map.isStateChange) {
		state.lastTriedFanMode = map.value
	log.debug "Parse returned $result"
	result
// Event Generation
def zwaveEvent(physicalgraph.zwave.commands.thermostatsetpointv2.ThermostatSetpointReport cmd)
	def cmdScale = cmd.scale == 1 ? "F" : "C"
	def map = [:]
	map.value = convertTemperatureIfNeeded(cmd.scaledValue, cmdScale, cmd.precision)
	map.unit = getTemperatureScale()
	map.displayed = false
	switch (cmd.setpointType) {
		case 1:
			map.name = "heatingSetpoint"
			break;
		case 2:
			map.name = "coolingSetpoint"
			break;
		default:
			return [:]
	// So we can respond with same format
	state.size = cmd.size
	state.scale = cmd.scale
	state.precision = cmd.precision
	map
def zwaveEvent(physicalgraph.zwave.commands.sensormultilevelv3.SensorMultilevelReport cmd)
	def map = [:]
	if (cmd.sensorType == 1) {
		map.value = convertTemperatureIfNeeded(cmd.scaledSensorValue, cmd.scale == 1 ? "F" : "C", cmd.precision)
		map.name = "temperature"
	} else if (cmd.sensorType == 5) {
		map.value = cmd.scaledSensorValue
		map.unit = "%"
		map.name = "humidity"
	map
def zwaveEvent(physicalgraph.zwave.commands.thermostatoperatingstatev1.ThermostatOperatingStateReport cmd)
	def map = [:]
	switch (cmd.operatingState) {
		case physicalgraph.zwave.commands.thermostatoperatingstatev1.ThermostatOperatingStateReport.OPERATING_STATE_IDLE:
			map.value = "idle"
			break
		case physicalgraph.zwave.commands.thermostatoperatingstatev1.ThermostatOperatingStateReport.OPERATING_STATE_HEATING:
			map.value = "heating"
			break
		case physicalgraph.zwave.commands.thermostatoperatingstatev1.ThermostatOperatingStateReport.OPERATING_STATE_COOLING:
			map.value = "cooling"
			break
		case physicalgraph.zwave.commands.thermostatoperatingstatev1.ThermostatOperatingStateReport.OPERATING_STATE_FAN_ONLY:
			map.value = "fan only"
			break
		case physicalgraph.zwave.commands.thermostatoperatingstatev1.ThermostatOperatingStateReport.OPERATING_STATE_PENDING_HEAT:
			map.value = "pending heat"
			break
		case physicalgraph.zwave.commands.thermostatoperatingstatev1.ThermostatOperatingStateReport.OPERATING_STATE_PENDING_COOL:
			map.value = "pending cool"
			break
		case physicalgraph.zwave.commands.thermostatoperatingstatev1.ThermostatOperatingStateReport.OPERATING_STATE_VENT_ECONOMIZER:
			map.value = "vent economizer"
			break
	map.name = "thermostatOperatingState"
	map
def zwaveEvent(physicalgraph.zwave.commands.thermostatfanstatev1.ThermostatFanStateReport cmd) {
	def map = [name: "thermostatFanState", unit: ""]
	switch (cmd.fanOperatingState) {
		case 0:
			map.value = "idle"
			break
		case 1:
			map.value = "running"
			break
		case 2:
			map.value = "running high"
			break
	map
def zwaveEvent(physicalgraph.zwave.commands.thermostatmodev2.ThermostatModeReport cmd) {
	def map = [:]
	switch (cmd.mode) {
		case physicalgraph.zwave.commands.thermostatmodev2.ThermostatModeReport.MODE_OFF:
			map.value = "off"
			break
		case physicalgraph.zwave.commands.thermostatmodev2.ThermostatModeReport.MODE_HEAT:
			map.value = "heat"
			break
		case physicalgraph.zwave.commands.thermostatmodev2.ThermostatModeReport.MODE_AUXILIARY_HEAT:
			map.value = "emergency heat"
			break
		case physicalgraph.zwave.commands.thermostatmodev2.ThermostatModeReport.MODE_COOL:
			map.value = "cool"
			break
		case physicalgraph.zwave.commands.thermostatmodev2.ThermostatModeReport.MODE_AUTO:
			map.value = "auto"
			break
	map.name = "thermostatMode"
	map
def zwaveEvent(physicalgraph.zwave.commands.thermostatfanmodev3.ThermostatFanModeReport cmd) {
	def map = [:]
	switch (cmd.fanMode) {
		case physicalgraph.zwave.commands.thermostatfanmodev3.ThermostatFanModeReport.FAN_MODE_AUTO_LOW:
			map.value = "fanAuto"
			break
		case physicalgraph.zwave.commands.thermostatfanmodev3.ThermostatFanModeReport.FAN_MODE_LOW:
			map.value = "fanOn"
			break
		case physicalgraph.zwave.commands.thermostatfanmodev3.ThermostatFanModeReport.FAN_MODE_CIRCULATION:
			map.value = "fanCirculate"
			break
	map.name = "thermostatFanMode"
	map
def zwaveEvent(physicalgraph.zwave.commands.thermostatmodev2.ThermostatModeSupportedReport cmd) {
	def supportedModes = ""
	if(cmd.off) { supportedModes += "off " }
	if(cmd.heat) { supportedModes += "heat " }
	if(cmd.auxiliaryemergencyHeat) { supportedModes += "emergency heat " }
	if(cmd.cool) { supportedModes += "cool " }
	if(cmd.auto) { supportedModes += "auto " }
	state.supportedModes = supportedModes
def zwaveEvent(physicalgraph.zwave.commands.thermostatfanmodev3.ThermostatFanModeSupportedReport cmd) {
	def supportedFanModes = ""
	if(cmd.auto) { supportedFanModes += "fanAuto " }
	if(cmd.low) { supportedFanModes += "fanOn " }
	if(cmd.circulation) { supportedFanModes += "fanCirculate " }
	state.supportedFanModes = supportedFanModes
def zwaveEvent(physicalgraph.zwave.commands.basicv1.BasicReport cmd) {
	log.debug "Zwave event received: $cmd"
	log.warn "Unexpected zwave command $cmd"
// Command Implementations
def poll() {
	delayBetween([
		zwave.sensorMultilevelV2.sensorMultilevelGet().format(),
		zwave.thermostatSetpointV1.thermostatSetpointGet(setpointType: 1).format(),
		zwave.thermostatSetpointV1.thermostatSetpointGet(setpointType: 2).format(),
		zwave.thermostatModeV2.thermostatModeGet().format(),
		zwave.thermostatFanModeV3.thermostatFanModeGet().format(),
		zwave.thermostatOperatingStateV1.thermostatOperatingStateGet().format(),
        getBattery(), // CUSTOMIZATION
        setClock(), // CUSTOMIZATION
        zwave.multiInstanceV1.multiInstanceCmdEncap(instance: 2).encapsulate(zwave.sensorMultilevelV3.sensorMultilevelGet()).format() // CT-100/101 Customization for Humidity
	], 2300)
def quickSetHeat(degrees) {
	setHeatingSetpoint(degrees, 1000)
def setHeatingSetpoint(degrees, delay = 30000) {
	setHeatingSetpoint(degrees.toDouble(), delay)
def setHeatingSetpoint(Double degrees, Integer delay = 30000) {
	log.trace "setHeatingSetpoint($degrees, $delay)"
	def deviceScale = state.scale ?: 1
	def deviceScaleString = deviceScale == 2 ? "C" : "F"
	def p = (state.precision == null) ? 1 : state.precision
    def convertedDegrees
    if (locationScale == "C" && deviceScaleString == "F") {
    	convertedDegrees = celsiusToFahrenheit(degrees)
    } else if (locationScale == "F" && deviceScaleString == "C") {
    	convertedDegrees = fahrenheitToCelsius(degrees)
    } else {
    	convertedDegrees = degrees
	delayBetween([
		zwave.thermostatSetpointV1.thermostatSetpointSet(setpointType: 1, scale: deviceScale, precision: p, scaledValue: convertedDegrees).format(),
	], delay)
def quickSetCool(degrees) {
	setCoolingSetpoint(degrees, 1000)
def setCoolingSetpoint(degrees, delay = 30000) {
	setCoolingSetpoint(degrees.toDouble(), delay)
def setCoolingSetpoint(Double degrees, Integer delay = 30000) {
    log.trace "setCoolingSetpoint($degrees, $delay)"
    } else {
	delayBetween([
		zwave.thermostatSetpointV1.thermostatSetpointSet(setpointType: 2, scale: deviceScale, precision: p,  scaledValue: convertedDegrees).format(),
	], delay)
def configure() {
	delayBetween([
		zwave.thermostatModeV2.thermostatModeSupportedGet().format(),
		zwave.thermostatFanModeV3.thermostatFanModeSupportedGet().format(),
		zwave.associationV1.associationSet(groupingIdentifier:1, nodeId:[zwaveHubNodeId]).format()
	], 2300)
def modes() {
	["off", "heat", "cool", "auto", "emergency heat"]
def switchMode() {
	def currentMode = device.currentState("thermostatMode")?.value
	def lastTriedMode = state.lastTriedMode ?: currentMode ?: "off"
	def supportedModes = getDataByName("supportedModes")
	def modeOrder = modes()
	def next = { modeOrder[modeOrder.indexOf(it) + 1] ?: modeOrder[0] }
	def nextMode = next(lastTriedMode)
	if (supportedModes?.contains(currentMode)) {
		while (!supportedModes.contains(nextMode) && nextMode != "off") {
			nextMode = next(nextMode)
	state.lastTriedMode = nextMode
	delayBetween([
		zwave.thermostatModeV2.thermostatModeSet(mode: modeMap[nextMode]).format(),
	], 1000)
def switchToMode(nextMode) {
	if(supportedModes && !supportedModes.contains(nextMode)) log.warn "thermostat mode '$nextMode' is not supported"
	if (nextMode in modes()) {
		"$nextMode"()
	} else {
		log.debug("no mode method '$nextMode'")
def switchFanMode() {
	def currentMode = device.currentState("thermostatFanMode")?.value
	def lastTriedMode = state.lastTriedFanMode ?: currentMode ?: "off"
	def supportedModes = getDataByName("supportedFanModes") ?: "fanAuto fanOn"
	def modeOrder = ["fanAuto", "fanCirculate", "fanOn"]
	while (!supportedModes?.contains(nextMode) && nextMode != "fanAuto") {
	switchToFanMode(nextMode)
def switchToFanMode(nextMode) {
	def supportedFanModes = getDataByName("supportedFanModes")
	if(supportedFanModes && !supportedFanModes.contains(nextMode)) log.warn "thermostat mode '$nextMode' is not supported"
	def returnCommand
	if (nextMode == "fanAuto") {
		returnCommand = fanAuto()
	} else if (nextMode == "fanOn") {
		returnCommand = fanOn()
	} else if (nextMode == "fanCirculate") {
		returnCommand = fanCirculate()
	} else {
		log.debug("no fan mode '$nextMode'")
	if(returnCommand) state.lastTriedFanMode = nextMode
	returnCommand
def getDataByName(String name) {
	state[name] ?: device.getDataValue(name)
def getModeMap() { [
	"off": 0,
	"heat": 1,
	"cool": 2,
	"auto": 3,
	"emergency heat": 4
def setThermostatMode(String value) {
	delayBetween([
		zwave.thermostatModeV2.thermostatModeSet(mode: modeMap[value]).format(),
	], standardDelay)
def getFanModeMap() { [
	"auto": 0,
	"on": 1,
	"circulate": 6
def setThermostatFanMode(String value) {
	delayBetween([
		zwave.thermostatFanModeV3.thermostatFanModeSet(fanMode: fanModeMap[value]).format(),
	], standardDelay)
def off() {
	delayBetween([
		zwave.thermostatModeV2.thermostatModeSet(mode: 0).format(),
	], standardDelay)
def heat() {
	delayBetween([
		zwave.thermostatModeV2.thermostatModeSet(mode: 1).format(),
	], standardDelay)
def emergencyHeat() {
	delayBetween([
		zwave.thermostatModeV2.thermostatModeSet(mode: 4).format(),
	], standardDelay)
def cool() {
	delayBetween([
		zwave.thermostatModeV2.thermostatModeSet(mode: 2).format(),
	], standardDelay)
def auto() {
	delayBetween([
		zwave.thermostatModeV2.thermostatModeSet(mode: 3).format(),
	], standardDelay)
def fanOn() {
	delayBetween([
		zwave.thermostatFanModeV3.thermostatFanModeSet(fanMode: 1).format(),
	], standardDelay)
def fanAuto() {
	delayBetween([
		zwave.thermostatFanModeV3.thermostatFanModeSet(fanMode: 0).format(),
	], standardDelay)
def fanCirculate() {
	delayBetween([
		zwave.thermostatFanModeV3.thermostatFanModeSet(fanMode: 6).format(),
	], standardDelay)
private getStandardDelay() {
	1000
def zwaveEvent(physicalgraph.zwave.commands.sensormultilevelv2.SensorMultilevelReport cmd) {
    log.debug "SensorMultilevelReportV2 $cmd"
    def map = [:]
		map.unit = "%"
            sendEvent(name: "HumidityLevel", value: "humidity is ${map.value}%")
	map
def zwaveEvent(physicalgraph.zwave.commands.multiinstancev1.MultiInstanceCmdEncap cmd) {
    def encapsulatedCommand = cmd.encapsulatedCommand([0x31: 3])
    log.debug ("multiinstancev1.MultiInstanceCmdEncap: command from instance ${cmd.instance}: ${encapsulatedCommand}")
    if (encapsulatedCommand) {
        return zwaveEvent(encapsulatedCommand)
def zwaveEvent(physicalgraph.zwave.commands.batteryv1.BatteryReport cmd) {
    def nowTime = new Date().time
    state.lastBatteryGet = nowTime
    def map = [ name: "battery", unit: "%" ]
    if (cmd.batteryLevel == 0xFF || cmd.batteryLevel == 0) {
        map.value = 1
        map.descriptionText = "battery is low!"
        map.isStateChange = true
        sendEvent(name: "BatteryLevel", value: "battery is low!")
    } else {
        map.value = cmd.batteryLevel
        sendEvent(name: "BatteryLevel", value: "battery is $map.value%")
    map
private getBattery() {	//once every 24 hours
	def ageInMinutes = state.lastBatteryGet ? (nowTime - state.lastBatteryGet)/60000 : 1440
    log.debug "Battery report age: ${ageInMinutes} minutes"
    if (ageInMinutes >= 1440) {
        log.debug "Fetching fresh battery value"
		zwave.batteryV1.batteryGet().format()
    } else "delay 87"
private setClock() {	// once a day
	def ageInMinutes = state.lastClockSet ? (nowTime - state.lastClockSet)/60000 : 1440
    log.debug "Clock set age: ${ageInMinutes} minutes"
		state.lastClockSet = nowTime
        def nowCal = Calendar.getInstance(location.timeZone) // get current location timezone
		log.debug "Setting clock to ${nowCal.getTime().format("EEE MMM dd yyyy HH:mm:ss z", location.timeZone)}"
        sendEvent(name: "SetClock", value: "setting clock to ${nowCal.getTime().format("EEE MMM dd yyyy HH:mm:ss z", location.timeZone)}")
		zwave.clockV1.clockSet(hour: nowCal.get(Calendar.HOUR_OF_DAY), minute: nowCal.get(Calendar.MINUTE), weekday: nowCal.get(Calendar.DAY_OF_WEEK)).format()
    } else "delay 87"
def refresh() {
    // Force a refresh
    log.info "Requested a refresh"
    state.lastBatteryGet = (new Date().time) - (1440 * 60000)
    state.lastClockSet = (new Date().time) - (1440 * 60000)
    poll()
IDE accepted yours fine, thanks Tim. CT100 gets delivered tomorrow, so I will give it a test drive later in the week.
So your code is working perfect with one exception - It’s still showing the sliders for temp control instead of the up and down arrows. Are you not using that option?
Nope. The arrow adjustment is awful IMO
Totally unusable. IMO :slight_smile:
The way I’ve setup the code and using it is to provide BOTH the slider and the Up/down. This way I can choose which one I want to use. Up/Down is definitely helpful when I want to make a minor adjustment.
Anyway to add fan circulation to the device type? Ideally it would have an on/off tile that would trigger it to circulate the fan on a “on 10 minutes, off 30 minutes” type schedule.
Here’s a smartapp for doing it, but you can’t turn it on and off without uninstall/re-install:
Looking through the code
		standardTile("fanMode", "device.thermostatFanMode", inactiveLabel: false, canChangeIcon: true) {
		state "fanAuto", label:'${name}', action:"switchFanMode", icon: "st.Appliances.appliances11"
		state "fanOn", label:'${name}', action:"switchFanMode", icon: "st.Appliances.appliances11", backgroundColor: '#02E181'
		state "fanCirculate", label:'${name}', action:"switchFanMode", icon: "st.Appliances.appliances11", backgroundColor: '#02D2E1'
The device type code supports fanCirculate if the base thermostat supports circulate. So if your HVAC supports circulate mode then it should work out of the box, just click on Fan until it says Circulate mode. if it doesn’t say then your thermostat doesn’t support circulate
