Enhanced Z-Wave Thermostat with Temperature, Humidity and Auto Time setting - Version 04.03.00
- Thermostats controls for CTxxx/GoControl/Linear etc can now be locked (full/partial) and unlocked remotely
Tap the refresh tile and if your thermostat supports this feature it will show up.
Key features of enhanced DTH:
- Supports secure inclusion and encrypted communication for Z-Wave Plus thermostats
- Battery saver option to extend battery life
- Synchronizing SmartThings dead-band settings with thermostat (default is 1°)
- Fix for ST Celsius scale bug
- Patches for firmware bugs
- CT-xxx incorrect date
- CT-xxx auto switch over
- CT-xxx state synchronization
- Customize thermostat settings (CT-xxx and ZTS-xxx)
- Temperature reporting threshold
- Temperature swing threshold
- Lock (partial/full) and unlock controls
- Show fan state (running or off even when set to Auto mode)
- Humidity
- Battery
- Clock
- Heat/Cool temperature settings
- Auto detect supported thermostat modes
- Off
- Auto
- Heat
- Cool
- Emergency heat
- Auto detect supported fan modes
- Off
- On
- Auto
- Circulate
- Thermostat models tested:
- CT-xxx Z-Wave
- CT-xxx Z-Wave Plus
- ZTS-1xx Z-Wave
- ZTS-5xx Z-Wave
- GoControl Z-Wave
- Vivint Z-Wave
- Lowes Z-Wave
- Filtrete 3M Z-Wave
- Honeywell Z-Wave
- APX Z-Wave
It will only show C-Wire
if the thermostat was paired with the hub in repeater mode (i.e. with the C-Wire connected) otherwise it shows the battery level.
