This was inspired specifically by the GoControl/Linear Garage Door (GD00Z-4) which is a great garage door opened available on Amazon but has a compatibility issue with SmartThings Door/Locks section. ST requires a connected “switch” to operate a garage door opener. The default Z-Wave Garage Door device type code that comes with ST does not support this to one cannot use the “Close Garage Door when someone leaves” or “Open garage door when someone arrives”.
We’ve two solutions for this (depending on your choice and preference).
1. Custom Z-Wave Garage Door Opener/Controller device handler with Switch functionality.
This allows any Garage Door to interact with any ST apps through a standard Switch on/off interface to open/close respectively. This allows for control through the Door/Locks section of ST Mobile App and also from any Smart App which turns on/off lights/switches. It also improves the low battery detection and reporting mechanism for the garage door position sensor. It also takes care of the phantom “opening” reports from the garage door opener.
Supported Controllers
Classic App
2. Garage Door Manager Automatically Open/Close with Timer/Presence SmartApp when someone leaves or someone arrives.
This app allows you to control any Garage Door (including Linear) to open/close when someone arrives/leaves accordingly. You do NOT need any special device types and works with the standard device type from SmartThings. This is the easiest way to provide open/close functionality without having to mess with custom devices.
You can control multiple garage doors simultaneously.
This device also supports reporting the Garage Door Level Sensor battery status.
A list of likely compatible garage door openers that work with these devices
Manufacturer Model
APC CB-SGX12
AHOUSE EM SWING GATE
AHOUSE RAM 100
ALLSTAR AC9000 Series
ALEKO 13XX
ALEKO 22XX
ALEKO AC1400
ALEKO AR1400
ALEKO AR900
ALEKO AS 1300
ALEKO AS 450
ALEKO AS 650
ALEKO AS 900
ALEKO GateGuard 1300
ALEKO GateGuard 1700
ALEKO GateGuard 450
ALEKO GateGuard 650
ALEKO GateGuard 850
ALEKO GateGuard 900
ALL-O-MATIC All O Matic SL-100
ALL-O-MATIC SL-100DC
ALL-O-MATIC SL-150DC
ALL-O-MATIC SL-45DC
ALL-O-MATIC SL-90DC
ALL-O-MATIC SW-300
ALL-O-MATIC SW-350
AVANTI T-Series
Apollo 1050
Apollo 1500
Apollo 1550ETL
Apollo 1650
Apollo 1650ETL
Apollo 3500ETL
Apollo 3600ETL
Apollo 635
Apollo 636
Apollo 7000ETL
Apollo 835
Apollo 836
AVIDSEN 1600
AVIDSEN 350
AVIDSEN Anthea
AVIDSEN EVER212
Aprimatic ALZO 55 with Control board T230
Aprimatic EM51 with control board T3EC-T3SC
Automatic Technology GDO-11v1 Ero
Automatic Technology GDO-6
Automatic Technology GDO-6v3
Automatic Technology GDO-7v2
Automatic Technology GDO-8
Automatic Technology GDO-9 Dynamo
Automatic Technology GDO-9v2
Automatic Technology GDO-9v2 Gen2
Automatic Technology NES-24v3 NeoSlider
B&D Controll-A-Door P Diamonnd
B&D MPC-2
B&D SDO-3V1 CADS
B&D SDO-3V2 CADS
BENINCA BRAINY 230
BENINCA BRAINY 24
BENINCA CP.B1024ESA
BENINCA CP.B24ESA
BENINCA CP.BULL-RI Control unit
BENINCA CP_J3 Control Unit
BENINCA MS4
BENINCA THINK Control Unit
BERNAL S 101-60
BERNAL S 101-80
Berner GA103
Berner GA203
Berner GA403
BFT Botticelli
BFT DEIMOS BT A 400
BFT DEIMOS BT A 600
BFT Deimos
BFT EOS
BFT EOS 120
BFT LIBRA-UL-R
BFT Phobos BT and NT NL
BFT Phobos N L BT
BFT Rigel4
BFT Rigel5
BOSS bol5
BOSS bol6
BOSH Profilift
Baisheng PKD2.3K
Berner GA203
CAME BK1200
CAME BK1800
CAME BK2200
CAME BK800
CAME BKE1200
CAME BKE1800
CAME BKE2200
CAME BX241
CAME BX243
CAME ZA3N
CAME ZA4
CAME ZL-J24
CAME ZM3E
CAME ZM3EC
CRAFTSMAN 75th Anniversary -Model 139.53991-
CRAWFORD Magic 1000
CRAWFORD Magic 600
Centurion Avanti
Centurion D2 Turbo
Centurion D5 EVO
DASPI MAX
DEA 203RR-Control Panel-
DEA 212E-Control Panel-
Chamberlain 248730
Chamberlain HD200D
Chamberlain HD400D
Chamberlain LW2000
Chamberlain LW3000
Chamberlain LW3500
Chamberlain MJ - MH - HMJ
Chamberlain Miracle-ONE
Chamberlain PD210
Chamberlain PD212D
Chamberlain PD300
Chamberlain PD610D
Chamberlain PD612D
Chamberlain Robo Swing R900
Chamberlain TPD10-05
Chamberlain The Robo Slide
Chamberlain Whisper Drive 248754
Chamberlain Whisper Drive HD600
Chamberlain Whisper Drive HD900D
DITEC D2H
DITEC GLOBE
DITEC NEOS
DMIL EVOLUTION
DORENE DR 3020
DORENE DR 3020HX
DORENE DRT 3520
DOWNEE NET230N
E8 E8-300
EAGLE 100 Series
EAGLE 1000
EAGLE 200 Series
EAGLE 2000
EAGLE E7
EAGLE Eagle-1
DoorKing 605
DoorKing 610
DoorKing CONTROL BOX: 6002-6003-6400
DoorKing DKS 6050
DoorKing DKS 6100
DoorKing DKS 9050
DoorKing DKS 9310
ELBE 909A
ELBE 909B
ELLARD Athena
ERREKA KM400
ESTATE SWING E-S 1100
ESTATE SWING E-S 1102
ESTATE SWING E-S 1600
ESTATE SWING E-S 1602
ETDOOR ET-1000E
ETDOOR ET-600E
ETDOOR ET-800E
EVOLOGY EVOSLIDE 5000
EntranceDynamics EDSL450
FAAC 400
FAAC 401MP
FAAC 414P
FAAC 450MPS
FAAC 455D
FAAC 624BLD
FAAC 740
FAAC 741
FAAC C720
FAAC E024S
FAAC E600
FAAC S800H (E024U Control Unit)
FADINI COMBI 740
GATEKEEPER YG-5602
GAREN Central G3
GENIE PowerMax (all models)
GENIE Excelerator (all models)
GENIE SilentMax (all models)
GENIE ChainMax (all models)
GENIE StealthDrive (all models)
GENIE QuietLift (all models)
GENIE StealthLift (all models)
GENIE Chain Drive (all models)
GENIE PowerLift (all models)
GENIUS Brain 03
GENIUS Brain 04
GENIUS Brain 17
GENIUS Brain 592
GLIDEROL Glidermatic GTS+
GTO 1500
GTO 25 code Digital Keypad
GTO GP-SW050
GTO GTO 3000XLS
GTO GTO PRO SW-2000XLS
GTO PRO 1000
GTO SL-1000
GTO SL-2000
GTO SW4000XLS
GUARDIAN 600SL
Generic 3 Button Commercial Door 3 Button Commercial Door
GiBiDi PASS 600 REGO
Grand-O-Matic GM1000
Grand-O-Matic GM1200
Grand-O-Matic GM800
Guardian MODEL 415
Hormann PROMATIC
Hormann Supramatic
HySecurity SlideSmart DC 10F
HySecurity SlideSmart DC 15
HySecurity SlideSmart DCS 10F
HySecurity SlideSmart DCS 15
KIBY 1000
KIBY 600
KINGGATES STARG8 24
LiftMaster 3780
LiftMaster 3840
LiftMaster 535-315LM Security+ Receiver
LiftMaster 5580
LiftMaster BMT5011
LiftMaster CB11
LiftMaster CSL24V
LiftMaster CSW200UL
LiftMaster ECO300K
LiftMaster ECO300KS
LiftMaster ECO400K
LiftMaster ECO400KS
LiftMaster Elite MIRACLE 1 (1998)
LiftMaster HS670
LiftMaster LA100
LiftMaster LA400-LA400S
LiftMaster LA500-LA500S
LiftMaster LM100
LiftMaster LM60
LiftMaster LM80
LiftMaster MT5011
LiftMaster Miracle ONE
LiftMaster Model APT
LiftMaster Model GH
LiftMaster Model GT
LiftMaster Model H
LiftMaster Model HJ
LiftMaster Model J
LiftMaster Model T
LiftMaster Professional Model Series 1200
LiftMaster RSL12U
LiftMaster RSL12V
LiftMaster RSL12VH
LiftMaster SL1000
LiftMaster SL3000UL
LiftMaster SL505
LiftMaster SL575
LiftMaster SL585
LiftMaster SL595
LiftMaster SL930
LiftMaster SW420
Linear 6000
Linear 6500
Linear 6500-P
Linear AP-4
Linear J6500
Linear LDO33
Linear LDO50
Linear Multi-Code (3-wire)
Linear Multi-Code 1099-50
Linear SLC
Linear SLD
Linear SLR
Linear SWC
Linear SWD
Linear SWR
Lynx 455 Plus
MAX - Maximum Controls- MAX F18
MERLIN G715D
MERLIN M230T
MERLIN MR650EVO
MERLIN MR850EVO
MERLIN MT1000EVO
MERLIN MT5580P
MERLIN MT60
MERLIN MT60P
Manaras Opera-MH
Manaras Opera-MJ
Marantec 220
Marantec 250
Marantec 252
Marantec 260
Marantec 270
Marantec 280
Marantec GDO 500(S or L)
Marantec GDO 700 (S or L)
Marantec M4500e
Marantec M4700e
Marantec M55
Marantec Q-7500
Marantec Q-7700
Mhouse SL1 and SL10
Mhouse WG20
Mighty Mule 200
Mighty Mule 350
Mighty Mule 362D
Mighty Mule 500
Mighty Mule 502
Mighty Mule FM145
Mighty Mule FM402
Mighty Mule MM600
MultiCode 1099
MultiCode 3090
NORMSTAHL Magic 1000
NORMSTAHL Magic 600
NORMSTAHL ULTRA EXCELLENT
Nice MC424
Nice MC824H
Nice POA1 (Control board)
Nice POP
Nice R01000
Nice R01040
Nice R01124
Nice RO1010
Nice RO300
Nice RO500
Nice RUN 1500
Nice RUN 1800
Nice RUN 1800P
Nice RUN 2500
Nice RUN 2500P
Nice Robus 1000
Nice Robus 1000P
Nice Robus 600
Nice Robus 600P
Nice SPIN
Nice Soon
Nice Spido 6000
Nice Spin10KCE
Nice Spin11KCE
Novoferm Novamatic 553
Novoferm Novomatic 403
Novoferm Safe 800 III
OVERHEAD DOOR Legacy
OVERHEAD DOOR Phantom
OVERHEAD DOOR Python2
PECCININ CP 4000
PECCININ CP2010
PECCININ CP4030
PECCININ CP5000
PECCININ GATTER 3020
POWERTECH PL1000
POWERTECH PL600
PROTECO Kit MyDiamond
PROTECO Q60A-R
PROTECO Q80A - board-
Platinum Access Systems BLS840
Polaris 500
Polaris 502
Polaris 700
Polaris 702
Power Master CSG
Power Master RSG
PUJOL Mini Marathon
RAYNOR FLITESTAR
RAYNOR POWERHOIST STANDARD -PSJ- -PSH-
RIB K400
ROGER BR20-500
ROGER H70-103AC
ROSSI DZ3 SK
Ramset RAM 100
Ramset RAM 1000
Ramset RAM 300
Ramset RAM 5500
Ramset Star 24
SEA GATE 2 DG
RYTEC System4
SEIP EASY SM
SEIP TM 60
SEIP TS 100
SEIP TS 75
SOMFY Axorn 50
SOMFY Axorn 70
SOMFY Axovia 220
SOMFY ROLLIXO RTS
SOMMER Marathon 550 SL
SOMMER Synoris 550 - 800
SOMMER duo rapido 650
SOMMER duo vision 500
SOMMER duo vision 650
SOMMER duo vision 800
SUPERLIFT SDO-1C
TAU Control Board K120M
TAU Control Board K125M
TAU Control Board K580M
TELECO Mydoor Basic
Telcoma T101
Telcoma T200
Telcoma T201
Tormatic GTA 601
Tormatic GTA 602
US AUTOMATIC 300D
US AUTOMATIC 300S
US AUTOMATIC Patriot
US AUTOMATIC RANGER 500
V2Electtronica AYROS 1000D-24V
V2Electtronica AYROS 1200-230V
V2Electtronica AYROS 400D-230V
V2Electtronica AYROS 500D-24V
V2Electtronica AYROS 600D-24V
V2Electtronica AYROS 800-230V
V2Electtronica CITY1
V2Electtronica City9
V2Electtronica FLEXY2
V2Electtronica JEDI 1000
V2Electtronica JEDI 700
V2Electtronica V2 Vega-C
Viking Access F1
Viking Access G5
Viking Access H10
Viking Access K2
Viking Access L3
Viking Access R6
Viking Access T-21
Viking Access i-8
Wayne Dalton iDrive
Wisniowski ST-2
VIPER TC-3
VIPER X50
VIPER X70
ZAP 800
ZAP 8800 Series 3
ZAREBA G452
If you’re trying to control the device using Alexa (Amazon Echo), please note that the stock ST Amazon Echo does not support operating locks and garage doors due to security issues. If you still want to control them using Amazon Echo, please use Ask Alexa, a custom integration which allows for the same.
More features to added, if you have any suggestions or ideas please feel free to ask and we’ll try to add it.
Check out these other SmartApps
[RELEASE] Door Chimes and Notifications for Doorbells and Sensors
[RELEASE] Security System: Intruder Alert with Actions
This custom device type and smart app is available on the RBoy Apps Server, http://smartthings.rboyapps.com. Refer to our facebook page below to get access to the server.
If you like the Apps consider supporting our development efforts. Visit our Facebook page for updates on new apps and to get Access to all our Premium ST Apps Server. RBOY APPS SmartThings - Make your Home your Butler
