[RELEASE] Enerwave ZWN-RSM2 (v1 & v2) & RSM2-Plus —Smart Dual Relay Switch Module
Would that be the driver for the Zooz Multichannel Switch?
I used the zen52 dual relay driver without any issues.
Hi TJ
How do you force it to use the Zooz driver.
I have several ZWN-RSM2-PLUS relays.
I’ve installed the “Zooz Multichannel Switch” driver, but “Select different driver” doesn’t give the option to select that driver.
Armen,
I started here: [ST EDGE] Zooz Edge Driver Channel
Click on the official Edge Driver Channel and accept the agreement
Then I went to http://ide.smartthings.com/ selected my location, then hub, then devices. Click on the device then Edit at the bottom of the page and change type to “Zooz ZEN52 Double Relay”
Click update and you should now have 2 devices you can control!
TJ, I’m confused. AFAIK, The IDE is for the Groovy device handlers, not the Edge. The devices with Edge drivers show as “placeholder” there without a network ID. To change the type, first, you need to find the Network ID, and then, I think if you select the type from the IDE, you’ll change it to Groovy type, not the Edge driver. Correct me if I’m wrong.
In the IDE don’t change Placeholder to anything else with Edge Drivers, you could mess them up.
The IDE doesn’t work with Edge Driver and will be phased out by the end of the year.
@Paul_Oliver thank you. That’s exactly what I thought.
@TJC19 how did you do that then?
