yes! block out the tokens always…
try this question…
which lights are one.
try this question…
Is NOT working…That error is up higher… The ST and Amazon don’t see each other…API path
Where would I update it?
found where. stand by
You’re getting closer. Make sure everything matches back to lambda file (as far as formatting) …and double check your taken to make sure you didn’t change it since you put the number in…
log out and log back in and try again… I’m pretty sure you timed out
Selected speaker OR phone = free text message
Selected groups and devices = control
NO selected speakers or phoens = no message
NO selected devices in any of the groups = no control…
In other words…you cannot send a free text message if you don’t have a destination (speaker for audio OR phone for sms)
And you cannot control devices if you didn’t authorize EchoSistant Profile to use any devices…
Long day and plenty of comments. Is everyone up and running? If not, please PM
Logging out and back in fixed that issue. I will continue in PM to @SBDOBRESCU since this thread is getting clogged up quickly.
that error is always a “you’ve been logged out” issue
pm both of us… I try to keep track of issues
PSA ~ I’m not sure what is going on with the Amazon servers, but there is something.
I’ve been seeing this off and on all day.
I’m run a test in the AWS web site and it works… run it again a minute later, it fails.
Everything is being very hit and miss this evening. So, if you are doing an install, stay at it.
Follow the wiki closely. There may not be anything wrong with your install.
Good luck… Bobby and I are here if you need us.
Hi Jason,
OK, so you know me, very literal. The instructions say to install the EchoSistant Parent App and the Profiles child app
Now, from the Wiki, which one is the “Profiles child app”
The names in the Wiki don’t seem to match up to the source code names
Maybe it’s just me
Rick
Hey, good catch…
Main Intent Profile…
I’m updating the wiki now
Thanks Rick…
The wiki is changed.
Thanks Jason,
I get the following error after I pasted the Main Intent Profile and selected create, yes I selected Raw and Ctrl A, Ctrl C, then Ctrl V
Rick
I might help if you name Groovy Code as Main App. and the Main Intent Profile as Profile App or better yet Messaging and Control Profile to match in-app description.
Fine! geeesh… I’ll change it again…
