It should all be here:
This was found in the Wiki under Latest Software Versions.
Thanks for that. Now one more thing I canāt see all of one Type to enter it is called LIST_OF_SYSTEM_COā¦
Is that list of system commands?
Nevermind. Found it. List of System Controls. Sorry for all the questions.
Itās ny nougat jeboard Tmo pushed it through and my fingers land on the wrong keys, ir is the trink, i cannot really tell.
Iāll update that section of the wiki tonight to be more clear. Sorry for the confusion.
Before we dig further, do you have a message sent to a Profile so you can repeat it?
Iām going to change that messageā¦ It was a coincidence that it was on that pictureā¦
Just type anything you want in thereā¦
This is a test of the speaker system
Oh, based on the errir, I think you donāt have the interaction model fully set up for the Main Intent. Can you take a shot on the interaction model tab?
I didnāt set up the profile yet. Would that be it? I didnāt see it say to go and do that yet.
Hereās the screenshot of the interaction model. I also donāt have a speaker that I would be using with EchoSistant yet.
Iām not seeing anything wrong there. you definitely need to set up a profile firstā¦ the app has to have something to talk to.
Ok, no problem, we blame it on Jason for picking a bad example to testā¦lol. your model looks good, with one exception. Please delete the List of Profiles. And then test again with turn the < device name > on or tell me about a < device name > . Or better yet, try how many lights are on?
definitely my fault
You guys had me for a minuteā¦
I kept erroring out in the app when trying to generate my list of devices.
Then I remembered from Ask Alexa to only add a device ONE time, regardless of the many different capabilities it has.
Not the case with EchoSistant. It should give you a list of unique devicw names to paste in your interaction model. You can actually pick a device in multiple groups. In some cases it is actually recommended to do it. But we get there after you are up and running and comfortable with the appā¦ lol
Iād like to see that, if you can post some logs. That might be a bugā¦
Ok, something is not working right. Can you get to live logging in ide and test again? Then share the ST logs. Not sure what the problem is, at this point.
11:50:09 PM: error java.lang.NullPointerException: Cannot get property 'value' on null object @ line 3682
Iām trying to see if I can narrow it down to a specific device.
Right now, Iām leaning towards the Roomba.
EDIT: Not the Roomba. Didnāt like Kodi (FireTV) being set up as a Media Controller. Took it no problem as a Media Player Type Device.
Not your device, itās my bug Please update to Version:4.0 R.0.0.2a , which I just pushedā¦Thanks for the log!
