SmartThings Community
[RELEASE] EchoSistant Ver 5.0 ~ Updated Release
(Jason "The Enabler" as deemed so by @Smart) #203
Log into the ST API. Click on the EchoSistant parent app. Click Save. Click Publish. Click For Me.
Then try again.
(Eric) #204
Now Echoassistant is blue…file is modified. When I look under Update from Repo, there’s a bunch of files in the New (Only in Github) section, but they say V3 or 4.5.
And I still get the same response.
(Jason "The Enabler" as deemed so by @Smart) #205
Ignore the NEW box. You should only use the box on the left.
Have you changed any of the EchoSistant code?
(Eric) #206
No. Only changed tokens and app IDs in the Lambda code.
(Jason "The Enabler" as deemed so by @Smart) #207
I sent you a PM
(Jason "The Enabler" as deemed so by @Smart) #208
One of my favorite features is this…
Alexa, turn on the fan for 10 minutes in the bedroom.
It turns on and ten minutes later, it turns off!
interesting. i may take another shot at this again.
(Jason "The Enabler" as deemed so by @Smart) #210
I don’t know how long it’s been since you last looked at it, but the install process is much simpler.
#211
I bet. went over the wiki a week or so ago and noticed some changes. ill take a crack on it once i get some down time… look forward on hearing from me. .:smiley:
Im not seeing my amazon echo and dot in here.
How do i add them?
(Jason "The Enabler" as deemed so by @Smart) #213
Do you have echo speaks installed?
#214
No i dont. (This is probably part of my troubles)
I also do not see this on my phone (Part where it lets me set Primary Mobile Device)
(Jason "The Enabler" as deemed so by @Smart) #215
if it’s not showing up, that’s fine. shouldn’t matter. I think I removed that and forgot to update the wiki.
ok then. .crossing my fingers. ill be testing this as soon as i get home.
thanks again.
(Jason "The Enabler" as deemed so by @Smart) #217
*** UPDATE UPDATE ***
Please update the parent and rooms apps.
Update includes: Weather Alert Notifications
Features:
  • App checks every 15 minutes for a weather alert change to your location
  • When an alert is received optional SMS and/or audio messages are broadcast
  • Only sends notification when alert is first received but continues to check every 15 minutes for changes to the alert.
** More capabilities planned for this feature in the near future
Thank you
(Todd M) #218
I have completed the install and am now in the create rooms section. However, there are not any echo devices listed in the “Audio and Text Message Settings.” It says “Amazon Alexa Devices You can’t currently add this”
(Jason "The Enabler" as deemed so by @Smart) #219
You must install the app Echo Speaks to use the echo devices.
(Joel W) #220
@bamarayne Now that emergency weather alerts are implemented is there a way to prevent this during certain hours?
(Jason "The Enabler" as deemed so by @Smart) #221
Sure there is, I just haven’t put it in yet.
(Joel W) #222
Thanks, I knew you had it scheduled.
