Ok, re-installed the ES. Same result
This is indicative of a problem between the Skill and Lambda. Are you sure you set it up correctly? (ARN number is correct, etc)
Yes. I have no idea what I could possibly be doing wrong.
How can I say âAlexa, officeâ and it work but everything beyond that fail.
I even setup the ability to message and said âAlexa tell office helloâ and that failed.
Are the profiles you have previously installed working properly?
Yup. Tested them too. They work just fine.
When you copy the ARN, make sure there is not a space at the beginning.
There is no space.
I created a new ES calling it Garage. Created a new skill with invocation garage and same result.
How is it possible that I can invoke Garage or Office, but cannot execute anything beyond it.
I have checked the ES and the skill a dozen times and everything is correct.
Is there a limit to profiles?
No there is no limit.
Letâs go to a pm
There are BIG changes coming to AWS Skill Interface. It might just be that AWS is broken. I cannot set up a new skill right now. Anyone else available to try to set up a new skill?
UPDATE UPDATE UPDATE UPDATE UPDATE
Due to some rather significant change on the Amazon Side of the world we are forced to implement an update. We apologize for any problems you may have experienced.
If you are experience the symptoms below, please update your previously created profiles. All NEW profiles must be created with the updated code.
Symptoms -
- When creating a new Profile Skill you are unable to control any devices in the profile or send messages. You receive an error in the AWS Skill Test panel that says âUnable to generate your user skillâ (or something like that).
- Previously created Profile Skills continue to work but you are seeing an increased failure rate.
Please perform the following to rectify this situation:
Update ALL Profile Skills with the following data:
- Profile Intent Schema -
https://github.com/BamaRayne/Echosistant/blob/master/smartapps/echo/AWS_Files/ProfileIntentSchema - Profile Sample Utterance - https://github.com/BamaRayne/Echosistant/blob/master/smartapps/echo/AWS_Files/ProfileSampleUtterance
Step One -
Follow the links above to obtain the required code -
Step Two -
Make a note of your exact Intent name and Utterance name (Highlighted in Yellow here)
Step Three -
Paste the code into the intent schema and then into the utterance. Change the names back to your profile names in the highlighted areas above. -
Step Four -
Click on the save button -
Step Five -
When you are complete your Profile Skill will look like the picture above.
This must be done for ALL profiles.
Again, we apologize for the inconvenience that this has created and we continue to appreciate your support of work.
ES started playing up with the above error (Unable to generate request for your skill) and I spent some time trying to troubleshoot - eventually gave up and completely removed everything. Just tried to install with the new profile intent and I get the following error:
Error: There was a problem with your request: The built-in slot type LITERAL is not supported for this locale.
Iâm running with English (UK) - might be the case for others too. Broken
It looks like the intent is not active for the UK. If you change your location in the AWS to the n. Virginia location, it might work. But you will lose the pretty accent.
After a little bit of research it is confirmed that the format of the intent changes I made last night are not compatible with the UK language.
I am continuing to work on this and find a functioning first for all of you in the UK. I should hopefully have something for you tonight.
In the mean time, if your ES is working, do not uninstall it and do not make any changes to the current skills. If it is not working, please be patient, I will find a fix that I hope will be suitable.
This update is for two things⊠one minor and one major. Iâll start with the minor update.
Update One
Feature:
Profiles now have the ability to change the Smart Home Monitor as a profile action. This means you can select the state to change SHM to when the profile is run.
Please update the âProfilesâ smart app here: https://github.com/BamaRayne/Echosistant/blob/master/smartapps/echo/profiles.src/profiles.groovy
Update Two
This is for our Friends in Europe ONLY. If you are not using the British Language or you are not using the AWS in the European location, do NOT do this.
As most of you know there were some major changes to the AWS yesterday that caused your EchoSistant profiles to either become very glitchy or to stop working all together.
I have formulated an update to the Profile AWS Skill that I believe is going to work for you. If you are NOT having any problems at this time, do not update this. It is going to be buggy until the wrinkles are worked out.
What I need are the Europeans that are having problems to help me out. I need you to update to this and to really test it. If you are interested please PM me. I will ad everyone into the one PM so that we can work on updating this together. I am keeping the code private for the next couple of days or until I can get some testers to help me smooth this out.
Thank you.
i just found time to update some Echosistant stuff yesterday and i noticed the Reminders module.
is the Reminders module available to use?
I cant seem to find any reference to it on the Echosistant wiki (or I may missing to see it.)
Sorry, itâs not ready yetâŠsoon
It is not operational, sorry it was pushed by mistakeâŠ
But donât worry⊠Weâve got a couple of major feature updates comingâŠ
Weâve slowed down the updates though, but weâre still here!
sorry im getting ahead of myself⊠(and i thought i was behind lol)
cant wait⊠i may not implement whatever new things you have on here but i make it a point to update IDE often.
Is there a command to set the a profileâs lights to a certain dimmer level? I know I can say âmake it brighterâ or âmake it darkerâ, but it doesnât seem to respond to any variant of âtell the living room to set the lights to 100%â.
