bamarayne
248
UPDATE UPDATE UPDATE
There are several updates occurring here for EchoSistant Version 4.1.
This update brings the release current to Version:4.0 R.0.3.3c.
For a successful update, please complete the following:
Update EchoSistant Main App
Update Profiles app
Update Notifications App
Update Main Intent Custom Slots
Update Main intent Utterance
Notes about this update:
Most of the updates are behind the scenes types of things that are done to increase reliability and stability. These are done to improve the app and to improve the user experience.
What you will see is this:
EchoSistant App -
This update consist of several bug fixes along with some stability and troubleshooting tools. Most of what has occurred here is behind the scenes and is to help make your experience better. You will see that the ‘Security Suite’ is now in the Profiles section of the app, along with some other minor UI changes. Also, we added the “On” and “Off” commands to your thermostats. You control this feature using these commands: (I have 2 thermostats, one named Upstairs and on named Downstairs)
Tell home, turn on the AC/Heat/Cooling (thermostat device name)
Tell home, turn off the AC/Heat/Cooling (thermostat device name)
Messaging and Control Profile -
This update consist of several bug fixes as well as added commands for the Virtual Person.
Notifications App -
Triggered reports now have a “Sun State” trigger. These triggers are called “Events” triggers. Sunset with offset, Sunrise with offset, and specific times. These are triggers, they are not a time frame. You would use this to trigger and action at one time, and then to trigger the same action again at a later time.
Custom report - Using variables create your message, choose the output type, and the trigger.
Custom report with weather - This is the same as custom but includes variables for weather.
EchoSistant has become a stable and reliable app. Due to personal constraints for both @SBDOBRESCU and @bamarayne updates to the app are going to slow down dramatically. We will always be readily available and will be working to ensure that any problems and bugs are fixed as soon as possible.
Version 5 is in the works, but we do not have a release date at this time. Stay tuned for release teasers for Version 5. We believe the new features are going to blow your minds!
Thank you for all of your support and encouragement!
Finally got to the bottom of the issue and thought I would report back in case anyone else has the same problem. Language setting on the Skill and the Echo were different - English (US) and English (UK), respectively. Changed the skill to English (UK) and it is now working.
Thanks again for your efforts guys. I will be spending the evening creating Profiles!
I have watched it before i installed but i will watch again. But thanks that pretty much solved my issues! Couple question i couldn’t understand from the wiki. “Profile, Messaging and Control” is this section only needed if you have connect speakers ??
bamarayne
258
I just posted a new link at the top for a video.
No, you do not need speakers for those profiles… Those are the ones you use for room control.
[quote=“SBDOBRESCU, post:259, topic:81849”]
I like cut off[/quote]
I don’t. It’s way too Lorena Bobbitt for my tastes.
bamarayne
262
Ouch!!! lol
but, you know what’s funny… When you set up a profile for a room and you invoke that profile…
Alexa, turn off the lights in the bathroom… if you changed your mind and want them back on…
just say, (before she times out)… turn them on… and the lights will turn back on.
