SmartThings Community
[RELEASE] Echo Speaks
echo
smartapp_voice
project_alerts
project_voice
(Anthony S.) #1957
I have some fixes coming for TuneIn playback in the next 30 minutes
(Jason "The Enabler" as deemed so by @Smart) #1958
My fire tablets work.
(Keaton Hoskins) #1959
Here is an article about it: http://www.aftvnews.com/show-mode-on-an-amazon-fire-hd-8-10-tablet-compared-to-the-echo-show/
(Keaton Hoskins) #1960
I am very curious how you have yours cofigured differently than mine. I can’t get them to work at all. I am running Fire OS 5.3.6.4 on the Kindle 7" Gen 5 and HD 8 Gen 7. I am unable to use them as they show Offline, but they are most certainly Online (as in on the network, able to use ActionTiles etc.)
I would like to compare notes :wink:
#1961
Barry - for the camera notifications, are those from Blink, or another camera provider?
(Tony Fleisher) #1962
My Hd8 7th gen with 5 3.6.4 and latest Alexa app is able to use tts, but not play music.
(Anthony S.) #1963
Release V2.1.2:
App:
  • ADDED: New Music Search Test Page which allows you to perform search commands on your device. It also allows you to perform tunein search and see results returned by Amazon.
  • FIXED: Minor bugs and cleanups
Device (v2.1.1):
• FIXED: TuneIn search command is now fixed
(Scott) #1964
You left the version number at v2.1.1 in the code.
(Anthony S.) #1965
Thank you for catching that I’ve pushed out the update with the correct versions
(JIm) #1966
I got mine working again and will not describe my stupidity…:unamused:
(Scott) #1967
SmartApp Version is at 2.1.2 but device handler remains at 2.1.1.
(Scott) #1968
I had this working previously, but the upgrade didn’t go well. Everything appears correct in the app and on Heroku; I completely removed the app and the Heroku instance and re-installed. Devices show as online, cookie is valid. Getting a “amazonCommandResp error: Failed with status code 400” error with every attempt at the Broadcast Test (Echos don’t speak or light up).
Foul
#1969
Is there a possibility of adding set vol and restore to playNotification as optional parameters?
(Guy) #1970
Hi there. I just installed Echo Speaks.
I am wondering how I could use the searchAmazonMusic for a specific song and then play it…
I see it is easy enough to search, but if I add ‘play’ after it, nothing happens.
I tried playtrack() but no luck.
Any advice?
(Barry) #1971
Steve -
None of these are camera-based alerts.
I use Dakota Alert in-ground vehicle detectors along the driveway, a DA motion sensor on the walkway, and a DA contact sensor in the mailbox. Coupled with 4 Ecolink sensors, I hand coded an activity monitor to generate the messages, based in part on who has arrived recently, etc.
(Jean May Jr) #1972
I haven’t played with this feature yet, but none of the examples I see seem to need the play or playtrack; it looks like the searchAmazonMusic should play once it finds it without the play command.
(Anthony S.) #1973
Try using the test tts button in a single device… I haven’t tested the broadcast testing in the latest versions
(Anthony S.) #1974
Are you referring to playAnnouncements()?
(Guy) #1975
Thanks. I tried using that one, but changed spotify to amazonmusic… still no go. The volume is set, but it doesn’t ever play.
I can get the devices to speak… but not play music.
1/7/2019, 9:20:51 PM +447ms
+1ms ╔Received event [Home].routineExecuted = 516cbf80-8a2e-4722-9c45-6219b6d1ac72 with a delay of 46ms
+115ms ║RunTime Analysis CS > 12ms > PS > 82ms > PE > 20ms > CE
+118ms ║Runtime (37272 bytes) successfully initialized in 82ms (v0.3.109.20181207) (116ms)
+120ms ║╔Execution stage started
+136ms ║║Comparison (string) :c24f582ccd6e05bbeb28c97ef072dfe2: executes (string) :c24f582ccd6e05bbeb28c97ef072dfe2: = true (2ms)
+139ms ║║Cancelling condition #8’s schedules…
+140ms ║║Condition #8 evaluated true (10ms)
+142ms ║║Cancelling condition #7’s schedules…
+143ms ║║Condition group #7 evaluated true (state changed) (14ms)
+147ms ║║Cancelling statement #1’s schedules…
+285ms ║║Executed physical command [Echo - Main Echo].setVolume([100]) (128ms)
+287ms ║║Executed [Echo - Main Echo].setVolume (132ms)
+323ms ║║Executed physical command [Echo - Main Echo].searchAmazonMusic([Guard Dogs - Random Barking and Growling Dog Sounds for Added Home Security When the House Is Empty]) (29ms)
+324ms ║║Executed [Echo - Main Echo].searchAmazonMusic (31ms)
+328ms ║╚Execution stage complete. (209ms)
+330ms ╚Event processed successfully (329ms)
(Scott) #1976
Nope:
postCmdProcess Error | status: 400 | message: null
Skipping Device Data Refresh… Device is OFFLINE… (Offline Status Updated Every 10 Minutes)
