SmartThings Community
[RELEASE] Echo Speaks
echo
smartapp_voice
project_alerts
project_voice
(Anthony S.) #2262
Thanks for the update @Brad_ST
Is this isolated to specific shards?
I’m not seeing these issues at all on the server I dubbed Old Faithful (NA01)
(Brad) #2263
Yes, NA02 only.
(Anthony S.) #2264
I have an idea that may help eliminate these issues when the platform is experiencing issues.
I’m going to move the tts commands from being Asynchronous to Synchronous.
(Brad) #2265
Things should be functioning again.
(JEFF) #2266
So it should be fixed?
(Stephen Melody) #2267
Fixed at my end, only one announcement and not multiples!!
Thanks!!
(Brad) #2268
Yes, the status page should be updated to reflect that shortly.
(Tony Fleisher) #2269
Is this going to continue being a problem, or is there some fix (that will hopefully be applied to all the shards)?
(Anthony S.) #2270
Device Detection Status Update
I want to apologize for not getting an update out for the Tablet detection.
I discovered some flaws which lead me down the path of reworking the whole detection process to provide feedback to you when devices are ignored and why.
I should hopefully have the new version out tomorrow evening.
(Scott) #2271
Thanks Anthony. We all know you have a full plate and you have really done a bang up job for the community. We appreciate your efforts very much.
(Pedaars) #2272
Is there a way to capture the current volume of an echo device and save it to a variable for use with the setVolumeSpeakAndRestore command?
(Anthony S.) #2273
The command itself will do that…
If you don’t provide a 3rd parameter
setVolumeSpeakAndRestore("test message", volume)
(Dominick Barile) #2274
I updated echo speaks yesterday & the test command works but can echo speaks be uninstalled & then install as a new app? I’m havi g an issue with big talker & I’m thinking I did something wrong when I updated yeaterday.
Dom
(Tony Fleisher) #2275
Uninstall should not be necessary (and not sure if it will work). What problem are you having? Did big talker work before?
(Dominick Barile) #2276
Yes it did. I only installed it last weekend & after some help got it working. & same for echo speaks. I updated echo speaks yesterday evening & big talker worked but that was it. I dont have any install errors for.both devices & the echo speak test button works but when I put something in big talker to say…nothing. I’m thinking I messed up.somewhere.
#2277
Hi @tonesto7, I know you are busy, just a quick one. I can not figure out what would be wrong.
I am using the app test page, broadcast TTS is working brilliant. As for music, only Spotify works for me. When I test with Amazon Music or TuneIn nothing happens.
I captured the smartthings log for reference. What am I missing?
(Anthony S.) #2278
What kind of device is this?
(Brad) #2279
Additional monitoring and safeguards were implemented across shards to prevent this issue going forward.
#2280
Echo dot 3rd Generation. This is a screenshot from the app.
(Anthony S.) #2281
Show me the top of the SmartApp main page where it shows the title and version
