[Release] Echo Speaks v3 + Actions
Thx for response. Is there any specific info I can provide to assist in troubleshooting?
I can confirm this happened to me too. I am a first time user of Echo Speaks. Just got my hub yesterday. Setup as guided and was able to do a speak test. After that nothing work including the actions and the tests. Tried the tests many times but my echo didn’t speak. One interesting thing is that I can still change the volume via Echo device in smartthings (using the slider) and my echo light up according the volume level I changed.
So I’ve got a Stuck\missing Action. I think what happened is, when I was creating the action I set up a custom response and then somehow exited without saving properly. When I went back into the actions area to delete it, there were no actions listed, but somehow the custom notification still fires when its triggered. I literally deleted and reinstalled everything I could think of but no joy. Any idea what I need to do to fix this? LOVE the Smartapp. Thanks for all the hard work on it.
Hello!
Can you please add to the Sensor Device Events a carbon dioxide concentration sensor?
Interestingly it’s now working for me. Go figure
Is it possible to send text commands to an Echo device as if you were saying it in the Echo Speaks options?
I am basically trying to set-up automation to transfer music from one echo to another.
This can be done by asking Alexa to pause on the first device and resume on the second device but I cannot figure out how to accomplish this with Echo Speaks. I have tried the following:
  • setTrack
  • restoreTrack
  • resumeTrack
But I can’t get any of them to work. Not sure what to put in string or number fields if anything.
@tonesto7, et al
[brain fart in progress]
Somehow I’m drawing a blank…is it possible to send a command to Alexa and instead of having it say something, have it do something…as if I had spoken a command?
e.g. There is a ‘3rd-Party’ smart system (Hunter’s HydraWise irrigation system) that has an Alexa skill, but the only way it works (of course) is by spoken commands. I’d like to be able to send a command to Alexa to have it do something in HydraWise as if I had spoken that command out loud (but didn’t).
You can create this, by using a routine from Alexa app. (Stop/play music) and then call the routine via echo speaks
Unfortunately, it isn’t possible.
If you put 2 devices near each other, you can use echo speaks to have one device give commands to the other, but i think that is about the best you can do at this time.
I don’t see how this would be possible in the Alexa app as a routine because it’s far to limiting.
Dang. That would be amazing because no longer would Alexa have issues understanding a command.
If you look under the routines you can initiate skills now. Combine that with Es actions to choose when to trigger the routine under SmartThings
Alexa App
Echo Speaks Actions
OK. That’s what I was afraid of.
As it turns out, I do actually already have a second voice activated assistant device (Google Home Mini) in the same room. If something similar to this would be possible with these two devices (i.e. having the Google Home Mini speak commands to my Echo), I might give it a try.
So…do we have something that gives us the same/similar sort of capability that ‘Echo Speaks’ gives us for Amazon Alexa, but for the Google Home/Google Assistant yet? I really haven’t done much with the Google Home world yet (beyond connecting it to my primary HA infrastructure, SmartThings).
@TonyFleisher
Unfortunately, I can’t get my two voice assistants (Amazon Echo and Google Home Mini) to interact in this way, because of voice recognition settings in place in each of them.
When I run a test, the Google Home Mini says that it does not recognize the voice (i.e. coming from the Amazon Echo), and when I test the other direction, the Echo simply ignores the spoken words coming out of the Google Home Mini (the wake light comes on briefly like it heard the wake word, but then the light ring goes right back off, and doesn’t say or do anything else).
So, I’m assuming that anyone who actually has this working is not taking advantage of voice recognition technologies.
…or am I missing something?
Thank you for demonstrating that. I guess the issue is that it’s not possible to create the Routine in Alexa that I can see. The Alexa routines are too restrictive.
Does anyone have the Gen 3 dot with clock working? My tts and announce shows false in the app but announce works fine in the Alexa app. I have installed the latest via GitHub and never had an Amazon device until earlier tonight.
This is a fairly new device, so the capabilities are probably not setup.
Can you go into the echo speaks SmartApp, manage devices, and find the family and type listed for that device?
With the type extracted and copy worthy
Family: ECHO
Type: A30YDR2MK8HMRV
Thanks for sharing that. I will get this added in the next few hours.
Will I need to do anything on my end?
