[OBSOLETE] Lock User Management (LUM)
###Multi User Lock Code Management with Notifications and Actions - Version 4.6.3
  • Improved reliability of auto unlock and auto relock
  • Bugfix for notifying user if codes are being reused for multiple users
  • Now the App checks if the device lock has the AutoLock feature enabled and if so it will not Unlock the door when open to avoid an infinite lock/unlock loop
  • Clear all codes from the lock before programming when installing for the first time to avoid conflicts
Recommend the use of the [Universal Enhanced Z-Wave Lock] ([RELEASE] Universal Enhanced Z-Wave Lock Driver for Schlage, Yale, Kwikset, IDLock, Popp, Danalock, August Pro, Keywe, Philia, Samsung) device handler version 2.10.1 or later for full SmartApp functionality
To set the hub Location, from smartphone app:
EDIT: Please note this version has simplified the user interface, so please CHECK and VERIFY your notification settings. These are now on the first page under door lock/unlock actions.
