Those devices don’t have any useful settings so I doubt they’ll end up having a custom driver.
Yes. If you change their Type field from the IDE to the built-in DTHs then any setting changes you made while using the custom DTH will be saved and if you run into an issue after changing them you can always change the type field back to the custom DTH.
I just have two alarms both set the same for the door chime, The Alarm function is controlled by the Smoke Alarm monitoring function in the Smartthings app.
It is only noticed as I can actually hold the door open, let the dog out and close the door before the Chime rings, about 30% of the time. It may be an issue with this specific siren as prior to the Edge Driver it would alarm once every evening with no Trigger. The second siren, in the bedroom hallway did not have this issue. That issue has been resolved with this driver.
The chime and siren have different settings so use the device details screen to select the Chime Sound and Chime Volume and then only use the Chime command in the routine.
With both settings changed it rings simultaneously with the Alexa. Now, I see that I was actually setting it twice, once in the main settings and again in the routine.
Correct. It’s a little confusing, but those options are needed for users with multiple Routines that play different chime sounds and/or different volumes…
I’ve ‘enrolled’ my hub but don’t have the siren as a device type option.
Hopefully I’m missing something trivial!
Selected Dome’s Edge Driver Channel link, allowed and enrolled which then shows hub status as:
Dome Drivers
SmartThings Hub
Home
NameDome Siren
Permissions
zwave: Enable full access to Z-Wave actions
With [Uninstall] button
Edit device at SmartThings. Add a little smartness to your things.
Device type select list doesn’t list Dome Siren (either alphabetical order or at end, existing other custom switch handlers manually added appear at the end)
Waiting several hours and rebooting hub doesn’t resolve.
Selecting ‘Zigbee Siren’ results in a device which responds but obviously doesn’t have the bells and whistles so to speak of this module.
And I’ve just realised this is listed as a z-wave handler, my siren is Zigbee.
I chose Zigbee as Australia uses different z-wave channels to the US and even AU online retailers seem to incorrectly supply US hub models sometimes, let alone trying to find out or ensure end devices are the correct region.
Hey @krlaframboise – I followed all of the directions, but when I view my device it’s showing the broken cloud icon for all setting items. Any thoughts on what to try next?
Do you think I need to buy a new one like the others have?
It sounds like SmartThings recently added the siren’s fingerprint to one of the built-in Edge Drivers so you’ll you’ll need to install the Custom Edge Driver instead of using the old Groovy handler.
I just added instructions for installing the driver to the top of the first post in this topic.
