SmartThings Community
[RELEASE] Dome Mouser (Official)
dth_sensors
dth_appliances
project_animals
(Hemant Gupta) #81
Why does mine keep tripping? I bought 4 and they all trip regularly without any mice being caught.
(Kevin) #82
There’s a 2 second delay so try using bait that the mouse can’t quickly grab and run off with.
(David Mellow) #83
Wondering if anyone can help me. I have the smartthings adt hub that I’m trying to us a dome mouser with. I can’t seem to figure out how to get notifications.
(Jimmy) #84
You need to install the custom handler first. Then you can use Smsrt Home Monitor custom in the classic app for an alert.
(David Mellow) #85
dont know how to do that.
(Jimmy) #86
(David Mellow) #87
tried that. I guess Im doing something wrong.
(Kevin) #88
After installing and publishing the code, did you edit the device in the IDE and change the Type field to Dome Mouser?
(David Mellow) #89
yes, I did. Its odd. When I first paired the mouser, two devices came up. A motion and a contact sensor. I removed both and tried again. Still can’t get it to work.
(Kevin) #90
I’ve never seen that happen before with any device…
Are you using the classic mobile app?
(David Mellow) #91
yes I have
(Kevin) #92
You could try removing all instances of the device, rebooting your hub, factory resetting the device (instructions should be manual), and then try joining it again.
(Jimmy) #93
Try re-publishing the device handler too.
(David Mellow) #94
I think my mistake is with the publishing. I am NOT very literate with this stuff.
