[RELEASE] Dome Door Sensor (Official)
Had one of their motions that stopped working for me as well. Gonna go Xiaomi route next.
Ran into the same issue when installing three door sensors (2 of the 3 work without incident), the third:
  • Paired with smart things hub
  • Properly indicated ‘open’ immediately after pairing
  • Properly indicated ‘closed’ when closing for the first time (although with ~5s of lag)
  • The device stops sending commands when contact is moved
  • Reset a half dozen times, let it think about its life-decisions overnight, etc., with the same results
If 2 out of 3 are working fine then it sounds like a defective device and you should return it.
