I can only do one screenshot per post.
Dan
I just need to see your camera presets within the camera settings. It might be under live view or setup.
Your current configuration should be moving your camera to each of your first 3 presets. Can you tell me if there are any errors in the SmartThings Live Log within IDE when you hit the preset buttons?
Nothing happens when I hit any of the 3 buttons. The log shows nothing. The following is the log showing the START. After hitting all three buttons with nothing happening, I hit the HOME button and quite a bit came up. The camera did go to the Home position. It is kind of a mess below, but I think the interesting messages are the ones about the presets.
Date Source Type Name Value User Displayed Text Changed
2017-04-18 3:00:45.059 PM MST moments ago DEVICE ENTITY_UPDATE DeviceUpdated Device ‘{{ deviceName }}’ updated false
2017-04-18 3:00:44.220 PM MST moments ago DEVICE switch6 home DLink Camera switch6 is home true
2017-04-18 3:00:44.212 PM MST moments ago DEVICE switch6 presetThree DLink Camera switch6 is presetThree true
2017-04-18 3:00:44.205 PM MST moments ago DEVICE switch6 presetTwo DLink Camera switch6 is presetTwo true
2017-04-18 3:00:44.197 PM MST moments ago DEVICE switch6 presetOne DLink Camera switch6 is presetOne true
2017-04-18 3:00:44.190 PM MST moments ago DEVICE switch6 right DLink Camera switch6 is right true
2017-04-18 3:00:44.182 PM MST moments ago DEVICE switch6 left DLink Camera switch6 is left true
2017-04-18 3:00:44.175 PM MST moments ago DEVICE switch6 up DLink Camera switch6 is up true
2017-04-18 3:00:43.165 PM MST moments ago DEVICE switch6 down DLink Camera switch6 is down true
2017-04-18 3:00:41.652 PM MST moments ago COMMAND home home command was sent to DLink Camera true
2017-04-18 3:00:41.623 PM MST moments ago DEVICE ENTITY_UPDATE DeviceUpdated Device ‘{{ deviceName }}’ updated false
2017-04-18 2:59:47.787 PM MST moments ago COMMAND start start command was sent to DLink Camera true
I think I found the issue, it looks like ST changed how valueTiles work so that they can no longer have an action tied to them. I’ll look at updating the code and then let you know when to update.
##DTH Update:
The following DTH have been updated to fix an issue with their preset buttons no longer working:
Please update and publish these DTH within the SmartThings IDE.
Ben,
The presets are now working. Thank you.
Dan
Good to hear, thanks for bringing the issue to my attention
Is the take picture function not working any more?
As long as your device handlers are up to date they should still work.
I’m afraid D-Link DCS-942L v1.0.3 is not working any more for me.
Its working perfectly for me, did your camera get assigned a new internal
IP address maybe?
Many thanks for your reply. I’ll see if the address has changed however the
rest of the device handler is working perfectly.
The IP address has not changed. Not sure if the issue has been generated by the recent firmware upgrades or by my hub being in the UK (I’m just banging my head on the wall as you can see, since I have no clue about the root cause). But please trust me, the take picture function is not working any more. I haven’t changed anything since you released v1.0.3 about 3 months ago.
I just read a thread about the image processing having issues in the UK shard, that might be your issue.
Many thanks for the update. It explains my issues I believe. I’ll wait for them to fix it.
They have resolved the issue. That functionality (take image / image carousel) is working again now.
