Oddly enough the custom presets work today (fixed itself somehow )
Cannot get video to record
I have tried the following
DTH rec button (does not work, however pir and NV controls work)
Invoking vidon, vidoff (does not work, even if I invoke enable local recording first)
please excuse the mess… how does one post “code” without it reading the code (so it doesnt hide things btwn <>), my stupid solution was to replace all < with …
10:15:03 AM: debug Body: ..?xml version="1.0" encoding="UTF-8"?>..config>..result>..code>invalidParameter../code>../result>..record>..enable>0../enable>..profileID>1../profileID>..continuous>0../continuous>..prerecord>0../prerecord>..fileFormat>1../fileFormat>..fileLenMin>1../fileLenMin>..recycle>0../recycle>..recordTo>..toSamba>..enable>0../enable>..user>../user>..password>../password>..server>../server>..shareFolder>../shareFolder>../toSamba>..toSmtp>..smtpEnable1>0../smtpEnable1>..smtpServer1>../smtpServer1>..smtpPort1>25../smtpPort1>..smtpUser1>../smtpUser1>..smtpPass1>../smtpPass1>..receiver1>../receiver1>..sender1>../sender1>..smtpEncrypt>0../smtpEncrypt>../toSmtp>..toFtp>..ftpEnable1>0../ftpEnable1>..ftpServer1>../ftpServer1>..ftpPort1>21../ftpPort1>..ftpUser1>../ftpUser1>..ftpPass1>../ftpPass1>..folder1>../folder1>..passive1>1../passive1>..fixFile1>../fixFile1>../toFtp>..toSD>..enable>1../enable>../toSD>../recordTo>..schedule>..enable>1../enable>..profileName>Normal_Recording../profileName>..item01>0,00,00,0,00,00../item01>..item02>0,00,00,0,00,00../item02>..item03>0,00,00,0,00,00../item03>..item04>0,00,00,0,00,00../item04>..item05>0,00,00,0,00,00../item05>..item06>0,00,00,0,00,00../item06>..item07>0,00,00,0,00,00../item07>..itemSize>0../itemSize>../schedule>..triggerBy>..byMotion>0../byMotion>..byIn1>0../byIn1>..byPIR>0../byPIR>..bySound>0../bySound>../triggerBy>../record>../config>
10:15:01 AM: debug Camera has moved.
10:15:01 AM: debug Body: ..?xml version="1.0" encoding="UTF-8"?>..config>..result>..code>ok../code>../result>../config>
10:15:01 AM: debug Parsing index:17, mac:************, ip:C0A80AC5, port:0050, requestId:******************************, headers:*******************E9LDQpEYXRlOiBUdWUsIDI3IERlYyAyMDE2IDE1OjE1OjAxIEdNVA0KQ29ubmVjdGlvbjogY2xvc2UNCkNvbnRlbnQtdHlwZTogYXBwbGljYXRpb24veG1sDQpQcmFnbWE6IG5vLWNhY2hlDQ*****************************==, body:PD94bWwgdmVyc2lvbj0iMS4wIiBlbmNvZGluZz0iVVRGLTgiPz48Y29uZmlnPjxyZXN1bHQ+PGNvZGU+b2s8L2NvZGU+PC9yZXN1bHQ+PC9jb25maWc+
10:15:00 AM: debug GET /cgi/admin/recorder.cgi?recordEnable=1&continuous=1 HTTP/1.1
Accept: */*
User-Agent: Linux UPnP/1.0 SmartThings
HOST: 192.168.10.197:80
Authorization: Basic *********************=
10:15:00 AM: debug path is: /cgi/admin/recorder.cgi?recordEnable=1&continuous=1
10:15:00 AM: debug The Header is [HOST:192.168.10.197:80, Authorization:Basic QWRtaW46MzAxMTI2cGs=]
10:15:00 AM: debug The device id configured is: c0a80ac5:0050
10:15:00 AM: debug 0050
10:15:00 AM: debug IP address entered is 192.168.10.197 and the converted hex code is c0a80ac5
10:15:00 AM: debug Video Recording On
10:15:00 AM: debug GET /cgi/ptdc.cgi?command=goto_preset_position&index=8 HTTP/1.1
Accept: */*
Authorization: Basic ***********************
10:15:00 AM: debug The Header is [HOST:192.168.10.197:80, Authorization:Basic **********************
10:15:00 AM: debug path is: /cgi/ptdc.cgi?command=goto_preset_position&index=8
10:15:00 AM: debug Moving to Preset position: 9
10:15:00 AM: debug Sensor checked in 15.362 seconds ago
10:15:00 AM: debug PUBLISHED on()
