Yea, I let it run in discovery for a really long time. No luck.
Like I said before, the wemo native app on my device finds them no problem and they all work just fine.
@ule - I donât know if the logs would be useful, if so let me know how you would like me to get them exactlyâŠ
HI @Scott_Chapman, some times the router or the st hub are locked, just disconnect and reconnect the power source, and try again.
could you find the devices with the âBrowse UPnPâ app?
Hi there, to the ones using this program, how is this working so far? I have too many wemo devices (30) to experiment with, is it working without problem? Has there been any update?
It hasnât been updated in 6 months. I donât use it. I am wondering the same thing you are.
HI @Swordfishunter, I have 10 wemo devices and its working fine, just remember to use some triggers to update the timer, I use my power motinor and works great, maybe 30 devices are a lot to 1 connect, you can use 2 connect apps if you have problems to update all the 30 devices in just 1 connect.
Is there a repo for github on this so I can install that way?
I am having the same issue. It finds 3 out of 5 wemos and not the ones I want. I completely uninstalled Wemo Connect and all wemo things before I ran discovery.
Hi @ule
Just to say thanks for the app; anecdotal evidence so far points to it being more reliable than the native ST one⊠I have successfully install the Connect app & Switch device handler & it found all 3 my switch devices. So far so good!
J
Iâm glad you like it, you can check my other apps in https://community.smartthings.com/users/ule/activity/topics , If you want to support this kind of development, you can donate a cup of coffee in https://www.paypal.com/cgi-bin/webscr?cmd=_s-xclick&hosted_button_id=A6XBY99S5FECL , thanks
Wow, man you are a live saver. Official app could not find my wemos. Your did instantly.
thanks a lot
Thank you so much for this, testing it now. Can I please have the IDE GitHub settings, I have tried but canât get it correct.
The settings I need are for this:
I had it working fine, but I took a WeMo switch and moved it to another room and it works within WeMo app but went offline in Advanced WeMo Connect. any ideas how to restore it again?
I tried removing the device from ST then running discovery. It finds it installs it, it says on. It works for one on and off then goes offline again.
Is there any way to get this to work with the Wemo Air Purifier?
Here what I have tried so far, to no avail.
It seems like the air purifier is stuck on the Wemo Connect SmartApp because it said, âDevice was already found in stateâŠâ when I tried to run the WeMo AirPurifier (Connect).
If the wemo device its already installed in ST , you must to remove it to allow the other connect to install it.
You can remove it from IDE in my devices if you cann not found it in the smart app.
Hi.
I think you must to ask to AirPurifier Connect developer, To fix the error.
