[RELEASE] cast-web v1.2.1 - Chromecast Device Handler & SmartApp
See the updated instruction in the original post.
Hubitat has a chromecast integration BUILT IN.
Just saying.
This post was flagged by the community and is temporarily hidden.
I just updated the node version to the last one (10.15.1) using the steps mention in “Dory - node.js” Play Store app.
“Upgrade node.js : ‘download file’ menu → check ‘appfiles’ → check ‘executable’
v10.15.1 arm(only for android 5.0 above)”
Then, install the package again and it will work without problems.
I have two questions.
Is there an update on the device handler so it works correctly in the new ST app?
For some reason I can’t get TTS voice to work (e.g. in Danish)
When this TTS switch is on the speaker only beeps and no voice but when I switch is off the voice is back (in English)
What should I do to make this work?
I do just that but within an LXC :ok_hand:
Hi, new to smartthings. This API looks very useful so thank you for your hard work. I have an old Android device, but sadly following the Android instructions on the official instructions doesn’t work for me (and seems a few users above).
I’m still keen on this so happy to get (my first!) Raspberry pi to get this to work. Anyone able to help with which raspberry pi could use this? For example could a raspberry pi pico run this API? Or a raspberry pi zero? Or what gen raspberry pi should I start with (gen 3, gen 4 etc?) Thanks in advance!
