If i set volume in this Smartapp will it overwrite what is in the Google Home App? The Ghome Routines are really bad (I had to setup 4 routines to set the volume at a specific time and it didn’t work).
I am trying to set the volume of the homes to 30% (WAF)
Yes. Google Homes / Chromecasts only have one volume ‘slider’. So if you adjust the volume through cast-web you’re actually sliding the same slider you’d in your Google Home app.
However there is a bug (or maybe intended by Google) for months now that although we’re talking about the same volume ‘slider’, the values can be slightly off. There’s a detailed description here: Volume does not match · Issue #72 · vervallsweg/cast-web-api · GitHub
The Cast-Web api appears in my list of Things… but I can’t access my speakers. It gives me a list of all my discover-able speakers and speaker groups but when I add them nothing else appears in my Things list… is there anything else I have to do? I did have to delete and re-install the device handler as before then I was getting an error notification. Everything else appears to be running ok?
Im having an issue with accessing the device page. The server is set up and working correctly as I can start and stop playback of the GH Mini I added for testing from the My Things list, however whenever I click on the Device I see the loading icon then the I get returned to the list page again. Im also not able to trigger playback on the device from webcore using the following script:
To add to this, after reinstalling the device handlers and smart app I also only see the GH Mini device now as cast-web-device. According to the FAQ found here this is a comms error between my PI and the ST hub, but I can get at the server on port 3000 on the pi via the browser on all the devices I tested from on my network. and there is no firewall between these devices. I have also tried hitting the refresh button under the cast-web-api device and nothing changes.
First of all, thanks for a top solution. I’m from Sweden and get a problem as soon as I use åäö. No tts at all. The assistant language is set to Swedish in the smartapp. I use “device speak text” in webcore. Am I doing something wrong or is there no support?
@vervallsweg Is there anyway to get an mjpeg stream sent to the devices? I’m trying to get the show me the “Security Camera Name Here” to work with unsupported cameras using blue iris. I thought that H264 was supported and Blue Iris has an H264 stream, but I can’t get that to cast via the URL.
Ok I believe I’m pretty close to getting this working. I am able to play an .m3u8 test file from apple via a manually edited preset. @vervallsweg Can you add an option in the preset configurator for application/x-mpegurl and application/dash+xml. That will add the option for HLS streams and DASH streams.
