I used a docker container to run the server but it hadn’t been updated since server version 0.2.2. I installed that on the server and assumed (badly) that it was up to date. Then when I installed the DTH and App, there was a version mismatch.
I went back and created my own docker container that keeps itself up to date with the latest code and used that. Now everything works a treat. thanks!!!
I tried installing this today and received the Error - bad state. message in the smart app. everything seems to be running and communicating but I cant add the discovered devices. Any ideas?
@vervallsweg For some reason it detect many devices as duplicate. Is this a known problem? It first add several cast-web-device by ip adress, after that it add the named devices with hashes. Previously no devices were added with generic name cast-web-device and ip adress.
Yep, I installed all three and published. Running the JS node on a Windows computer and the app to detects all six devices. once I select them and click save I get the red banner with the error
Exactly. The mdns-lib I’m using has certain ‘issues’. I guess it’s receiving responses from not Google Cast devices and cannot parse the Cast info then. If it’s annoying I can just filter that message from the logs. I’ll switch mdns-lib soon (again). The new lib shouldn’t have theses issues. Let’s see which one I implement first
It should do neither. Do you mean the name by that or dni?
Like before you installed it there were no devices installed? Don’t what you mean
Normal behavior would be after intstall devices show in the ST app as cast-web-device . After waiting a couple of seconds or doing a manual refresh the correct name is pulled from the API.
Is this still working for everybody else? I installed without much fuss a couple of weeks ago (on Linux), created some automations using webcore. Love this! Noticed over the last few days the automations stopped working. I too get an empty list ([]) when querying the /devices endpoint. None of the devices that had been working in ST update their status or can refresh. Not sure if this offers any clues but physical Chromecast devices show up as Connected (even though they don’t update) while the Audio Groups show up as Disconnected.
My linux server has more than one network interface. Could that be breaking discovery? I can run and bind the API to port 3000, interact with the API but the device list always returns empty. If I run a tcpdump on eth1 (the desired internal interface) I see mDNS from my cast devices. In debug mode I see:
cast-web-api 2018-07-27T12:25:13.219Z createGoogleZones(): discoveredZones: [] +1ms
cast-web-api 2018-07-27T12:25:13.219Z createGoogleZones(): done! zones: [] +0ms
cast-web-api 2018-07-27T12:25:47.009Z getNetworkIp(): addresses: 192.168.1.1,24.5.5.5,192.168.5.1 +34s
cast-web-api 2018-07-27T12:25:52.420Z discover(): updateCounter: 0 +5s
cast-web-api 2018-07-27T12:25:52.420Z discoverTimes(): discover(“googlezone”) done times: 4, zoneResults: , typeof: object +0ms
cast-web-api 2018-07-27T12:25:52.420Z discoverTimes(): newZoneResults: [object Object], new times: 3 +0ms
I have tried setting the server IP explicitly. Is there a way to specify an interface ID?
