I wondered what that play button did. It still shows on mine.
It runs the recover piston method…
def appTouchHandler(evt) {
recoverPistons(true)
same issue
The code for CoRE on Github has been updated, and ST just release v2.2.3 of the Android app. Either one will fix what v2.2.2 broke.
Haven’t updated CoRE yet, but I can confirm that 2.2.3 resolves the issue. Any concerns with using the latest CoRE version with 2.2.3?
Same! Feel a bit daft for not working that one out. - can confirm it’s still on mine iOS/CoRE latest.
Updated both and all seems well!
I did notice that when removing a condition - say I want to change it from presence to switch,- sometimes it will retain the previous attribute. So for instance when I go to tell it, ‘on or off’, it’ll have ‘present or not present’. I have to clear it, then go back far enough to re-add the condition. Though I suspect this is probably not related to ‘outage’, just a coincidence that I noticed it now
Updated CoRE but I am unable to save a piston. Receiving a popup “Error Saving Page”. The runtime statistics page gives me the “you are not authorized” popup.
When I try to save any piston I get a red box “Error saving page”. Anyone else having issues? I have the latest CoRE app and the latest ST app.
Same issue here. Setting the “Then” clause on any piston causes a red “not authorized” overlay.
@ady624 - any comment? I saw the CoRE peer assistance thread had a report or two of this, too.
Yes, I’ve been getting this recently. I just keep hitting done over and over and it eventually saves.
Be certain you are using the latest Smartthings app (2.2.3).
2.2.2 had a flaw fatal to CoRE.
Android v2.2.2 by any chance?
Apparently, even though Android told me that it had updated. Trying to update again. Will let you know.
Edit: Yep, that was it. For some reason my tablet refused to update SmartThings beyond 2.2.2 until I unstalled it.
If I group the following three light bulb actions into one action, will my random color be the same for all three or a different color for each bulb? @ady624
Yes, I have done the same…
Using light1, light2 and light3
Set color blah blah.
Same color
Ok, thanks. I want them each a different color. No combining the actions then for me!
I Uninstalled and installed both smart things and core, still have the same issues.
Don’t suppose you’re using a Windows device? The Windows app can’t run third-party SmartApps very well. I opened a ticket on it, but I never got a response. Someone else in this community told me that it’s a known issue.
I’m a Windows guy (I work for Microsoft) but I pretty much only use the Windows app for the bare necessities, like arming/disarming SMH and running Hello Home routines. For CoRE and many other SmartApps, you gotta have Android or iOS, so I use my wife’s tablet for those.
