I’ve updated the WD100+ device handler to support the latest firmware ramp rate configuration capabilities and also added a preference option to have double-tap up turn on the light to full brightness. Details are in the HomeSeer HS-WD100+ thread
The local ramp rate configuration should now work since that was supported in the old version, but the remote ramp rate will not. I ended up removing the previous workaround for this to reduce the DH complexity for maintainability. The old device handler code is still available if you want remote dim rate control on the old firmware, but I could probably have my arm twisted to add that back to the current code if it causes anyone major grief.
