[OBSOLETE] Button Controller Plus, HS-WD100+ HS-WS100+
Thanks for your reply above that helps. I think if I understand your issue correctly you should be using only the Button Controller Plus for everything? Two questions:
In Automate Lights & Switches, you didn’t say what you selected for
“Which lights do you want to control?” Is it the same Living Room Lights that is connected to your HS-WD100+ switch? Maybe this is why then in the description to the problem you say each time you “Press and Hold”… that is the 5th/6th buttons so did you want to configure them in Button Controller Plus? You could move the actions of the Automate & Lights into either the 5th or 6th button. There is no need to use the other Smart Lighting Smartapp since you have nothing to gain. Even though this app is local it doesn’t help you because your device handler is not.
If not I am a little confused with why you Press&Hold.
That being said however, if you want to use the HS-WD100+ in the Smart Lighting app then you need to change the way you configured for:
  • “Select Trigger” select Button (not switch)
  • “Which Button?” select Living Room Lights
  • “Button number” select One through Four depending which one you want.
    * Remember the HomeSeer switches 5th and 6th buttons can’t be
    seen by this app. The standard Smart Lighting app that comes
    with the system is unable to distinguish the Press&Hold functions
    only the first four multi-tap buttons.
  • “Button action” select Pushed (not Held)
