*** No longer supported *** [RELEASE] Best Zoned Heating/Cooling smartapps
Hi,
Just to let my contributors know and all ST users who would like to do targeted heating/cooling in their home that I have new versions of my zoned Heating/Cooling smartapps available at my store :
  • I made some changes to ecobeeSetZoneWithSchedule (v8.7.9):
    • Optimized reverting temp adjustment operations (based on outdoor temp thresholds) to avoid unecessary hold commands sent to thermostat
For more details about the all use cases supported, refer to ST community wiki:
EcobeeSetZoneWithSchedule (for the main ecobee thermostat only - with some optional smart vents)
http://thingsthataresmart.wiki/index.php?title=EcobeeSetZoneWithSchedule#Look_.26_Feel
ScheduleTstatZones (for any ST connected main thermostat like the Nest, Honeywell, etc. - with some optional smart vents)
https://thingsthataresmart.wiki/index.php?title=ScheduleTstatZones#Look_.26_Feel
ScheduleRoomTempControl (for any ST connected main thermostat with smart vents).
https://thingsthataresmart.wiki/index.php?title=ScheduleRoomTempControl#Look_.26_Feel
P.S. For all ST users who have contributed to my support packages, the update has been done for you under your ST account (provided that I have your credentials), you don’t need to do anything: everything has been taken care of.
You can download the new version at my store using the original sellfy link.
The new code is available at my store.
www.ecomatiqhomes.com/store
Regards.
View this email in your browser
Get Up to 60% Off
For the rest of November
No coupon code required
SHOP THE SALE
Smart Vents
4x12 – 30% OFF
6x12 – 30% OFF
All other sizes – 25% OFF
Temp Sensors
40% OFF
All Starter Kits
15% OFF
Arbor Faceplates
60% OFF
Smart Bridges
30% OFF
Trim Kits
10% OFF
All Ecovent Products
25% OFF
*Sale cannot be combined with other offers or coupons. Sale ends at 11:59PM PST Nov 30, 2019.
Follow us
\ 24x24
\ 24x24
\ 24x24
\ 24x24
Want to change how you receive these emails?
You can update your preferences or unsubscribe from this list
Copyright © 2019 Keen Home Inc. All rights reserved.
You are receiving this email because you opted in on our website or requested to be added by a member of the Keen Home team.
Hi,
  • I made the following optimization to ecobeeSetZoneWithSchedule (v8.8), ScheduleTstatZones,(v8.8), and ScheduleRoomTempControl (v4.6) :
    • Optimized setVentSwitchLevel() to avoid sending multiple setLevel command to the vents if their current level is already within range of the target level in order to reduce noise.
P.S. EcobeeSetZoneWithSchedule has a tight integration with My Ecobee device.
Regards.
Keen Home Sales, last sale of 2019!
Shop The Last Sale of 2019!
Through 12/31/19, get up to 25-35% off all Smart Vents, only while supplies last.
This is your last chance to upgrade your home before our 2019 inventory runs out!
*Sale prices only valid for in-stock inventory. New inventory will arrive early next year.
Shop Now
*Sale prices only valid for in-stock inventory. New inventory will arrive early next year. No code required.
Keen Home
Follow us
\ 24x24
\ 24x24
\ 24x24
\ 24x24
\ 1x1
ReplyForward
Link to details.
https://us8.campaign-archive.com/?e=8ae273e73c&u=76d0f6f210d77f7d6349c01ac&id=953934371c
I have just done a quick read of the vent management. I already have your My Ecobee device handler. All I want is the vents to follow the Ecobee schedule. When an Ecobee sensor is active, the vent regulates the room temperature. If the sensor is inactive, it closes. When the thermostat is in recovery mode, the appropriate vents are opened. Basically I just want to control everything from the thermostat.
Thanks for any info
Hi,
Just to let my contributors know and all ST users who would like to do targeted heating/cooling in their home that I have new version of my zoned Heating/Cooling smartapp available at my store :
  • I made the following optimization to *ecobeeSetZoneWithSchedule (v8.8.1):
    • Made minor correction to adjust_tstat_for_more_less_heat_cool() to take into account the right baselines for adjustment*.
Regards.
Hi,
  • I corrected the following minor issues in ecobeeSetZoneWithSchedule (v8.8.2), ScheduleTstatZones (v8.8.1) and ScheduleRoomTempControl (v4.6.1):
    • Made some changes to the icons path following some security changes in iOS/Android ST classic mobile app*.
Regards
Hi,
  • I corrected the following minor issues in ecobeeSetZoneWithSchedule (v8.8.5), ScheduleTstatZones (v8.8.4) and ScheduleRoomTempControl (v4.6.3):
    • Made further changes to the icons path in MyVirtualZone v1.2.1 to display them in the latest version of ST classic mobile app (v1.18 and higher).
    • Corrected set_fan_mode() in ecobeeSetZoneWithSchedule & ScheduleTstatZones to override fan settings when a condition such as the temp differential in the zone is over a temp delta threshold (ex. 4F) and also when no conditions are applied for the schedule
Regards
I am just getting starting to investigate what I need for adding smart vents to my HVAC system. I have been leaning toward flair since they are less expensive. What do these smartapps do that the flair app does not do?
Hi, please refer to the 1st post of this thread which explains all the features with links to the ST community wiki…
The Flair app can only use the Flair puck or the ecobee remote sensors to control the vents.
With my smartapps, you can leverage any ST connected temp/motion/contact sensors to control the vents…
On top of it, if you have the ecobee tstat, there is a tight integration with My ecobee device which allows you to adjust the setpoints & fan settings based on different indoor/outdoor conditions.
No other ecobee integration exposes so many features under SmartThings. And, you can use My virtual zone devices to control the vents & zones and get information about your zones in near real time.
Regards
Hi,
  • I corrected the following minor issues in ecobeeSetZoneWithSchedule (v8.8.8), & ScheduleTstatZones (v8.8.7) :
    • Made some changes to better control the Flair vents when Switch value=off
    • Removed some logic related to room tstats to avoid conflict with the Virtual Zone’s setpoints
Regards
Hi,
  • I corrected the following minor issues in ecobeeSetZoneWithSchedule (v8.8.9), & ScheduleTstatZones (v8.8.9) :
    • Made some changes in setRoomTstatSettings & turn_off_room_tstats_outside_zones() to avoid any conflicts when the master tstat is also included in the rooms (as a slave thermostat) for the scheduled zones.
Regards
Hi,
Just to let my contributors know and all ST users who would like to do targeted heating/cooling in their home that I have some new versions of my zoned Heating/Cooling smartapp available at my store :
I corrected the following minor issues in ecobeeSetZoneWithSchedule (v8.8.9b), ScheduleTstatZones (v8.8.9b), ScheduleRoomTempControl (v4.6.6a) :*
  • Made some changes to better support the Flair vents
  • Made some minor icon changes in MyVirtualZone device (see pictures below).
As a reminder, my zoning solutions are fully compatible with MyEcobee Device and MyNextTstatV2 (for the Nest tstat). The Device Type Handlers (DTH) are also available at my store.
You can download the new versions at my store:
  1. EcobeeSetZoneWithSchedule (for the main ecobee thermostat only - with some optional smart vents)
  1. ScheduleTstatZones (for any ST connected main thermostat like the Nest, Honeywell, etc. - with some optional smart vents)
  1. ScheduleRoomTempControl (for any ST connected main thermostat with smart vents).
Regards
I bought a few Keen vents during the Memorial Day sale and I wanted to say THANKS for your work on these device handlers and apps! I’ve got the vents tied to my Ecobee thermostat and sensors and they’ve been doing a great job keeping the room temperatures balanced. :grin:
I just received some Keen Smart Vents and I already have an Ecobee3 with some smart sensors setup. ST sees the Ecobee and Smart Sensors. I can even install a Keen vent natively, but there appears to be little I can do with it, aside set the vents manually.
Would I be using EcobeeSetZoneWithSchedule? or ScheduleRoomTempControl? The first mentions ‘with some optional smart vents’…
I’d be looking to set a temperature in each room and have the system open / close vents as needed.
Thanks!
Hi,
It looks like ScheduleRoomTempControl would be a better fit for your use case.
For more details, refer to the ST community wiki :
http://thingsthataresmart.wiki/index.php?title=ScheduleRoomTempControl
P. S. BTW, it’s recommended to use MyEcobee device with my zoning smartapps.
Regards
Hi,
Just want to inform my contributors that new major versions of ecobeeSetZoneWithSchedule(v9.0), ScheduleTstatZones (v9.0) & ScheduleRoomTempControl (v5.0) * can be downloaded at my e-commerce solution provider (sellfy) using the original download link.
  • If you’re a contributor and interested in the new major version (v3), let me know and I can directly send the code to you for beta testing the upgrade. All you need to do is to copy &paste the new code over the existing one for MyVirtualZone DTH (Device Handler Type) and the zonign smartapp.
  • You’d probably need to refresh the Samsung connect app’s cache in order to see the UI changes. There are some instructions to do so in the release notes.
  • The new UI presentation amongst others adds a custom capability (setZoneSetpoint see image below).
You can also refer to the 1st post of this thread for all the use cases supported.
The zoning smartapps (ecobeeSetZoneWithShedule, ScheduleTstatZones, ScheduleRoomTempControl) are available at my store:
Regards
Hi,
Just want to inform my contributors that new version of MyVirtualZone(v2.2) can be downloaded at my e-commerce solution provider (sellfy) using the original download link.*
  • The new version exposes the heatingSetpoint & coolingSetpoint capabilities based on my custom setThermostatSetpoint capability for easier integration with dashboard such as SharpTools & ActionTiles.
  • All you need to do is to copy &paste the new code over the existing one for MyVirtualZone DTH (Device Handler Type), and the corresponding zoning smartapp and save/publish.
The zoning smartapps (ecobeeSetZoneWithSchedulev9.2, ScheduleTstatZonesv9.2, ScheduleRoomTempControlv5.2) are available at my store:
Regards
Hi,
Good news for all my contributors (and users who have keen or flair vents)…
You can now use the custom capabilities (temperature, motion, contact,etc ) for your Automation scenarios, see screenshot below:
Regards.
You’re welcome to come to the Hubitat platform where my solutions are alive and kicking. I have had a Hubitat store for more than a year at my site…
https://www.maisonsecomatiq.com/hubitatstore
