What is your email address? My reply to service@maisonsecomatiq.com returned the following:
Sorry, it’s services@maisonsecomatiq.com…
Please include any detailed logs about your potential issues to determine if there are any
error messages…
FYI, as I will be on vacation for the next 2 weeks, I won’t be able to respond to you before my return, I strongly recommend to consult the ST community wiki for any troubleshooting or questions about the zoning smartapp. All the use cases are documented under the configuration section along with the most relevant troubleshooting.
https://thingsthataresmart.wiki/index.php?title=EcobeeSetZoneWithSchedule#Configuration
https://thingsthataresmart.wiki/index.php?title=EcobeeSetZoneWithSchedule#Troubleshooting
If you want further assistance than the ST community wiki, you’d need to contribute to one of my support packages at my store. … As I’ve already answered your questions in my previous post above.
Regards.
Can this be ported to Hubitat?
Hi, sorry I don’t have a Hubitat hub, and not planning to get one.
Also, porting such code would require significant work and my professional services would become expensive for you.
Regards.
Hi,
Just to let my contributors know and all ST users who would like to do targeted heating/cooling in their home that I have new versions of my zoned Heating/Cooling smartapps available at my store :
I made some enhancements to ecobeeSetZoneWithSchedule (v8.7.5) and ScheduleTstatZones (v8.7.5) to open all vents when alternative cooling is on. Alternative cooling can trigger any ST connected fan switches (big fan, evaporative cooler, damper) when the right conditions are set at your home based on an (internal) ideal humidity/temp table or a temp threshold.
If you are already a contributor, you can now download the new version at my store using the original sellfy link.
The new code is available at my store.
For more details about supported features & all use cases supported, refer to ST community wiki:
EcobeeSetZoneWithSchedule (for the main ecobee thermostat only)
http://thingsthataresmart.wiki/index.php?title=EcobeeSetZoneWithSchedule#Look_.26_Feel
ScheduleTstatZones (for any ST connected main thermostat like the Nest, Honeywell, etc.)
https://thingsthataresmart.wiki/index.php?title=ScheduleTstatZones#Look_.26_Feel
ScheduleRoomTempControl (for any ST connected main thermostat with smart vents).
https://thingsthataresmart.wiki/index.php?title=ScheduleRoomTempControl#Look_.26_Feel
Here are some video links of the Keen Home Vents review made by one of my contributors (Rick’s Tech talk) which explain why the SmartThings setup is far better than the regular Keen Home setup (with the Keen app). You can find my company name under the reviews…
The zoning smartapps can also work with any ST connected smart vents including the Flair smart vents or the econet.
P.S. For all ST users who have contributed to my support packages, the update has been done for you under your ST account (provided that I have your credentials), you don’t need to do anything: everything has been taken care of.
Regards.
Hi,
I made some significant optimization to ecobeeSetZoneWithSchedule (v8.7.6), and ScheduleTstatZones (v8.7.6):
- When using the alternativecooling settings to control big fan/damper/evaporative cooler switch(es) and the HVAC fan, the new versions will avoid sending the same fanOn() or fanOff() commands if the HVAC fan is already in the correct fan mode.
For more details about the all use cases supported, refer to ST community wiki:
You can download the new version at my store using the original sellfy link.
Regards.
FALL FLASH SALE!
For a limited time, save up to 40%!*
All Ecovent products are 25% OFF
Use code: FALLFLASH25
Keen Home Smart Vents are 30% OFF
Use code: FALLFLASH30
Keen Smart Bridges are 35% OFF
Use code: FALLFLASH35
Keen Smart Filters are 40 % OFF
Use code: FALLFLASH40
Buy Two Keen Home Smart Vents, Get One
Bummed that summer is over?
We’ve got the perfect pick-me-up.
For a limited time, buy two Keen Home Smart Vents and get one on us!*
Use code: BUYTWO19
*Sale valid only on purchases of Keen Home Smart Vents. Sale runs through 11:59PM PT on October 13, 2019.
Hi,
I made some correction to ecobeeSetZoneWithSchedule (v8.7.7), and ScheduleTstatZones (v8.7.6c):
- When using the moreHeat, lessHeat, moreCool, and lessCool thresholds based on an outdoor temp sensor or weather station, the check_if_hold_justified() routine will take into account the null values to revert the adjusted setpoints if needed.
- Added more tracing in the code
Regards.
Hi,
I made some changes to ecobeeSetZoneWithSchedule (v8.7.8):
- When a new climate/comfort setting is set at My Ecobee DTH (temporary hold or permanent), the new program heat & cool setpoints will now be set as new baselines for any further setpoint adjustment (based on indoor or outdoor sensors).
- Please take note that the climate/confort setting changes were already taken into account for vent adjustment, so this change is just for setpoint adjustments.
- After updating the code, one needs to click on the smartapp under Automation/smartapps and save to create the new subscription to enable the change.
Regards.
Hi,
I made some changes to ecobeeSetZoneWithSchedule (v8.7.9):
- Optimized reverting temp adjustment operations (based on outdoor temp thresholds) to avoid unecessary hold commands sent to thermostat
EcobeeSetZoneWithSchedule (for the main ecobee thermostat only - with some optional smart vents)
ScheduleTstatZones (for any ST connected main thermostat like the Nest, Honeywell, etc. - with some optional smart vents)
Regards.
View this email in your browser
Get Up to 60% Off
For the rest of November
No coupon code required
Smart Vents
4x12 – 30% OFF
6x12 – 30% OFF
All other sizes – 25% OFF
Temp Sensors
40% OFF
All Starter Kits
15% OFF
Arbor Faceplates
60% OFF
Smart Bridges
30% OFF
Trim Kits
10% OFF
All Ecovent Products
25% OFF
*Sale cannot be combined with other offers or coupons. Sale ends at 11:59PM PST Nov 30, 2019.
Follow us
Want to change how you receive these emails?
You can update your preferences or unsubscribe from this list
Copyright © 2019 Keen Home Inc. All rights reserved.
You are receiving this email because you opted in on our website or requested to be added by a member of the Keen Home team.
Hi,
I made the following optimization to ecobeeSetZoneWithSchedule (v8.8), ScheduleTstatZones,(v8.8), and ScheduleRoomTempControl (v4.6) :
- Optimized setVentSwitchLevel() to avoid sending multiple setLevel command to the vents if their current level is already within range of the target level in order to reduce noise.
P.S. EcobeeSetZoneWithSchedule has a tight integration with My Ecobee device.
Regards.
Keen Home Sales, last sale of 2019!
Shop The Last Sale of 2019!
Through 12/31/19, get up to 25-35% off all Smart Vents, only while supplies last.
This is your last chance to upgrade your home before our 2019 inventory runs out!
*Sale prices only valid for in-stock inventory. New inventory will arrive early next year.
*Sale prices only valid for in-stock inventory. New inventory will arrive early next year. No code required.
Follow us
ReplyForward
Link to details.
https://us8.campaign-archive.com/?e=8ae273e73c&u=76d0f6f210d77f7d6349c01ac&id=953934371c
I have just done a quick read of the vent management. I already have your My Ecobee device handler. All I want is the vents to follow the Ecobee schedule. When an Ecobee sensor is active, the vent regulates the room temperature. If the sensor is inactive, it closes. When the thermostat is in recovery mode, the appropriate vents are opened. Basically I just want to control everything from the thermostat.
Thanks for any info
Hi,
Just to let my contributors know and all ST users who would like to do targeted heating/cooling in their home that I have new version of my zoned Heating/Cooling smartapp available at my store :
- I made the following optimization to *ecobeeSetZoneWithSchedule (v8.8.1):
- Made minor correction to adjust_tstat_for_more_less_heat_cool() to take into account the right baselines for adjustment*.
Regards.
Hi,
- I corrected the following minor issues in ecobeeSetZoneWithSchedule (v8.8.2), ScheduleTstatZones (v8.8.1) and ScheduleRoomTempControl (v4.6.1):
- Made some changes to the icons path following some security changes in iOS/Android ST classic mobile app*.
Regards
Hi,
- I corrected the following minor issues in ecobeeSetZoneWithSchedule (v8.8.5), ScheduleTstatZones (v8.8.4) and ScheduleRoomTempControl (v4.6.3):
- Made further changes to the icons path in MyVirtualZone v1.2.1 to display them in the latest version of ST classic mobile app (v1.18 and higher).
- Corrected set_fan_mode() in ecobeeSetZoneWithSchedule & ScheduleTstatZones to override fan settings when a condition such as the temp differential in the zone is over a temp delta threshold (ex. 4F) and also when no conditions are applied for the schedule
Regards
I am just getting starting to investigate what I need for adding smart vents to my HVAC system. I have been leaning toward flair since they are less expensive. What do these smartapps do that the flair app does not do?
Hi, please refer to the 1st post of this thread which explains all the features with links to the ST community wiki…
The Flair app can only use the Flair puck or the ecobee remote sensors to control the vents.
With my smartapps, you can leverage any ST connected temp/motion/contact sensors to control the vents…
On top of it, if you have the ecobee tstat, there is a tight integration with My ecobee device which allows you to adjust the setpoints & fan settings based on different indoor/outdoor conditions.
No other ecobee integration exposes so many features under SmartThings. And, you can use My virtual zone devices to control the vents & zones and get information about your zones in near real time.
Regards
