SmartThings August Smart Lock Pro Z-Wave Device handler with DoorSense
I’m happy to share the first version of this device handler. Feel free to contribute!
- SEE INSTALL INSTRUCTIONS
Z-Wave device handle for August Pro Smart Lock device handler with DoorSense™.
Due to limitations (recognize contact sensor in automation and displaying information using tiles) this device handler creates a child contact sensor (based on new child contact sensor device)
Devices interfaces - New app vs Old App
Why use it?
You should use this device handler if you have a August Lock Pro and you want to use DoorSense™ in automations with no need to have an august connect acting as a bridge (see Validation scenario)
Validation scenario
This device handler was tested using Samsung Connect Home Pro (Smartthings V2 Hub) with Firmware version 000.027.00010 in a set up with +10 z-wave devices.
August Smart Lock Pro was connected to both, Smartthings via Z-wave and August Doorbell as a wifi bridge (Wi-Fi bridge is not necessary to use this device handler). No issues were detected when tests were made from different channels (Bluetooth, Wi-Fi bridge or z-wave commands). All three interfaces are able to update status properly.
August Smart Lock Pro firmware was 1.12.2-1.59.0.
Automation in new app using Lock vs Child contact device
Known issues
- Responsiveness to update child device using new app
- Delays to execute commands using new app (1 to 3 seconds)
- Any update to the device handler makes the DoorSense™ unresponsive during the development phase. The reason for it is unknown. When updating the device handler, delete it and create a new one to avoid this issue. This issue somehow affects new installations using github integration
Install Instructions
Follow Smartthings Git Hub Integration Guide, using user rafaelborja and repository SmartThingsAugustPro.
FIXED: Due to an unknown issue installation using GitHub is making the device handler unresponsive to events. Please create the august-lock-pro-zwave-lock-with-doorsense device handler source code by following the instructions bellow
Developer note: Please feel free to try Smartthings Git Hub Integration and validite if this issue is specific to my installation.
You can also create create a new decive handler from code copying and pasting child-contact-sensor device handler and child-contact-sensor device handler source code
FAQ
Why a child door sensor?
Due to a bug in Smartthings, only a child device can be used on standard automation app.
Contributions
Please feel free to contribute with suggestions forks, and pull requests at GitHub - rafaelborja/SmartthingsAugustPro: Z-Wave device handle for August Pro Smart Lock device handler with door sense
