It should be this:
In the AWS area and put it here in the developer area;
Hi Michael,
Thank you for putting all of this together - I believe iâm at the home stretch here but have hit a bit of a snag.
Iâm having trouble getting to the âsetup variablesâ page.
I opened live logging in the IDE, and through the smart app I went to âSettingsâ but I donât see a âsetup ask alexaâ button. Directly in the settings root, I see a section called âother values / variablesâ and there is a âsetup variablesâ link.
When I click on that iâm brought to 1 single page that references lambda code and Amazon Ask custom slot information - but no buttons or json reference. Am in the correct area?
Thank you again!
Are you using the latest version of the app (i.e. version 2.3.9)? If not, I recommend upgrading to that as the instructions will not match your screens if you donât.
Feature request (once itâs available) to make a great app even more awesome!
I use the âwhisperâ feature a lot⊠but I think this may actually take it to the next level.
I already use the other polly languages in TTS announcements but integration with Alexa would take it to the next level.
This is already implemented in message queues, but YESâŠI have a feeling I could support this as well!
Hi Michael thanks for your reply. It has been a few busy days at work so I didnât manage to really try things out. I will get back to this ASAP so I can finally add a new dimension to my Alexa expedience and get back to you.
I will have to find out if the error message Iâm receiving maybe has something to do with this warning you placed on the wiki: âFor the developer account, please ensure you create the account under the same account you used for your Amazon Alexa Enabled Device setup.â Do you know the best way to check this out?
I indeed already had an AWS Lambda and developer account. But maybe this has nothing to do with this error I was just trying to analyze why I receive an error message when I paste the ARN.
Best regards,
Edward
If you go to developers.amazon.com and your user name and login is the same as alexa.amazon.com you should be goodâŠ
Happy FridayâŠOnce again, no important releases this week. but I did have some entertainment by reading this article:Alexa vs Google Assistant vs HomeKit: Which Smart Home Platform to Choose? | Digital Trends
While I donât get creeped out by technology much (and I am not sure âcreeped outâ is even the right feeling), the Google assistant making a phone call to arrange a haircut was downrightâŠ.well, creepyâŠI KNEW it was a robot so I was listening for the tell-tale signs of inflection difference (which there were some), along with some slightly-longer-than-normal delays in responding, but if I hadnât known this is a robot I would have been convinced it was a human. AgainâŠ.this gives me an âoddâ feelingâŠmaybe I just need to take a Tums
For Alexa, Amazon took another bold step in the routines and now allows for custom responses to the commands.
Speaking of Ask Alea, @pizzinini mentioned this:
I actually looked into this and the work that I have done already done with the whisper mode and such will play into this nicely. In fact, I already have the interfaces pieces doneâŠJust need the voice names (I kinda know what they already are:) Text To Voice, Text To Speech Software - Amazon Polly - AWS ) and for them to activate in every userâs account (later this summer)? Now you can have a MALE voice for Ask Alexa overall, or by virtue of the restrictions that are already in place for when you decide to whisper or not
Finally, I have been modifying Ask Alexa Rooms extension per my last message and can now get status of items within a room instead of a full-on status of the entire room.The entire room status is still available, but now ask about the status of the âfansâ in a room and it will give you just that. I will post a demo when I get an opportunity, but the goal is always to make the interface more intuitive.
Until next timeâŠ.go see Deadpool 2 (if you are in to that).
Does the latest version of Ask Alexa app currently allow you to output an event status as a non-verbal Input to Alexa. Through some logic be able to trigger a custom audio command response from Alexa instead of the typical " Ok "? Triggered by motion sensors, or After speaking audio commands to smart home. More natural AI integration into the smart home.
Thinking Jarvisyyyyy. " Yes Master " or " Welcome home Johny, I hope you had a good day " or " Good Morning Johny, Here is your flash briefing and weather report "⊠ectâŠ
Thank you for your time,
Tim
You basically are asking about a âwake up and talk on its own to an eventâ type of thing? Sort ofâŠ
I did add support for the skill ânotifymeâ that allows the Alexa to âdingâ when something happens, but you still have to ask âwhat did I missâ.
In addition, Ask Alexa has a notification queue which allows ST connected speakers (NOT the Alexa) to wake in real time to events, similarly to what you mentioned about a greeting when you arrive home, or an event in the house.
Amazon has promised this ability for a while, and there are some work arounds I am looking into, but nothing right now.
Micheal,
Thank you for getting back to me so soon! I appreciate your explanation. Yes I am looking for a wake up and talk on itâs own to an event type of thing. Event Driven Wake Input.
That is a bummer that Alexa does not have such capability or a work around. Seems to be a area that could use some improvement for a more natural integration.
I was hoping the new Blue print function would give us this capability, but it still requires a Audio wake word Input.
Have a good weekend,
Tim
Trust me, this is the holy grail and it will come out at some point. I am still investigating different ways of doing this, and if they are reproducible you can be sure I will put it in Ask Alexa!
Hi Michael,
It has been a few days, it has been some busy days at work. But I finally got a moment to try things out again.
Iâm not really sure I have manage to make AskAlexa work.
But if by saying "Alexa ask smart things to turn xx-light ON I donât hear the standard OK, but instead of that I hear âTurning xx-light onâ and when I just say Alexa âTurn xx-light ONâ again I get the OK.
I think itâs working. Thanks a lot for all your help and support.
Best regards
Edward
I would recommend you watch your Live Logging to see if Ask Alexa log entries show up. If they do, then you are working. And the message SOUNDS like mine
HI Michael,
I see some activity. When I say âAlexa ask smart thing to turn kitchen counter ONâ the lights turns on and I receive this kind a log:
23:11:38: info LWA Access and Refresh tokens updated and valid
xxxxxxxxx 23:11:38: debug requestToken
xxxxxxxxxxx 23:11:36: debug [Stringify] Generic Event data successfully posted
xxxxxxxxxxxxxxxxx 23:11:36: info postEventToEndpoint: event successfully posted.
xxxxxxxxxxxxxx 23:11:36: debug Property Change Event switch: off (source: DEVICE)
Iâm not sure, I see some token info. so I changed this with some xxxx in case this can bring the security at risk.
Sorry my mistake. I was on the live logging but not in the Ask Alexa tab:
The info is like this: 23:10:31: debug I am turning the kitchen counter on.
So I think I can yell âYESâ
Thank you very much again!!!
Best Regard
Edward
YeahâŠthose log entries appear to be the native integrationâŠNOT Ask Alexa. The best way to test the installation is simply saying âAlexa, Ask SmartThings About VersionââŠIf it works Ask Alexa is installed fine.
Hi Michael,
Iâm at work right now but tried this suggestion on my phone through reverb and it indeed told my some information like the current version of the AskAlexa and the Lambda, including that you are the âfatherâ of Ask Alexa . Thanks again.
By the way I posted some questions about the installation of Echosistant. unfortunately Iâm having some problem installing this App. But I noticed that there are some development in integrating AskAlexa and Echosistant. Do you advise go through the hassle of trying to find things out for the installation of Echsistant or just wait till AskAlexa and Echosistant are ONE?
Thanks again,
Edward
There is no longer development of Echosistant, and almost all of the features of that app can be accomplished either via the native Amazon functionality now or Ask Alexa.
OK. Thanks in that case I will cancel all this effort in trying to install Echosistant and focus on AskAlexa and other SmartApps.
Best regards,
Edward
