# \[RELEASE\] Aqara Double Rocker Wall Switch DTH and Discussion (Updated May 26, 2020)
**URL:** <https://community.smartthings.com/t/release-aqara-double-rocker-wall-switch-dth-and-discussion-updated-may-26-2020/192205>\
**Category:** Connected Things\
**Created:** [April 29, 2020, 9:20pm UTC](https://community.smartthings.com/t/release-aqara-double-rocker-wall-switch-dth-and-discussion-updated-may-26-2020/192205 "2020-04-29T21:20:53Z")\
**Posts on this page:** 1\
**Showing post:** 28
<div class="post-metadata">
**Author:** ![johnconstantelo](https://yyz2.discourse-cdn.com/smartthings/user_avatar/community.smartthings.com/johnconstantelo/32/111869_2.png) [@johnconstantelo](https://community.smartthings.com/u/johnconstantelo)\
**Post date:** [August 8, 2022, 4:32pm UTC](https://community.smartthings.com/t/release-aqara-double-rocker-wall-switch-dth-and-discussion-updated-may-26-2020/192205/28 "2022-08-08T16:32:52Z")
</div>
Hi @bornesto,
That’s the right switch for this DTH:
[https://raw.githubusercontent.com/jsconstantelos/SmartThings/master/devicetypes/jsconstantelos/my-aqara-double-rocker-switch.src/my-aqara-double-rocker-switch.groovy](https://raw.githubusercontent.com/jsconstantelos/SmartThings/master/devicetypes/jsconstantelos/my-aqara-double-rocker-switch.src/my-aqara-double-rocker-switch.groovy)
Can you make sure you’re using that DTH please?
Also, I’ve moved over to using Edge drivers for this device provided by another developer. It works great but looks slightly different:
> [@\[Edge\] Driver for Aqara Switches and Remotes](https://community.smartthings.com/t/edge-driver-for-aqara-switches-and-remotes/234576/107):
> Thanks, I’ll get to looking at that after work today. Are the labels something I can change? EDIT. I couldn’t wait. It worked perfectly after I removed and rejoined the device. Thank you!
> [@\[Edge\] Driver for Aqara Switches and Remotes](https://community.smartthings.com/t/edge-driver-for-aqara-switches-and-remotes/234576):
> The Edge driver for Aqara Switches and Remotes started with an attempt to connect my own smart home. I am not an Aqara representative and do not receive any payment for this work. By posting the code [Github](https://github.com/veonua/SmartThingsEdge-Xiaomi), I hope to inspire others to join in and share their fixes and, support for newer devices. Your participation and contributions are welcome. You can use the [channel invitation link](https://api.smartthings.com/invitation-web/accept?id=5e5b1616-90cf-4383-83ea-a323aac0ed5a) to test the current version Device Zigbee ID Device Type Neutral Notes 00000000000000000000000000000000000000000000000000000 [QBKG03LM](https://zigbee.blakadder.com/Aqara_QBKG03LM.html)[[QBKG03LM]](https://camo.githubusercontent.com/12a5d6669ca8106bec12b2f3d8b5044ddd2529d5c94deb9500d9fca7ce7f557b/68747470733a2f2f7a69676265652e626c616b61646465722e636f6d2f6173736574732f696d616765732f646576696365732f41716172615f51424b4730334c4d2e77656270) lumi.ctrl\_neutral2 Wall Switch No Neutral Double Rocker [QBKG04LM](https://zigbee.blakadder.com/Aqara_QBKG04LM.html)[[QBKG04LM]](https://camo.githubusercontent.com/df1587e45670ad131a11872a44ec7da8952fbdc2b894facf4935588ef1346792/68747470733a2f2f7a69676265652e626c616b61646465722e636f6d2f6173736574732f696d616765732f646576696365732f41716172615f51424b4730344c4d2e77656270) lumi.ctrl\_neutral1 Wall Switch With Neutral Single Rocker [QBKG11LM](https://zigbee.blakadder.com/Aqara_QBKG11LM.html)[[QBKG11LM]](https://camo.githubusercontent.com/f6e629d755f301aad94d083a669158bfc9390af0d58a2c9fc6b89a9c16234b9c/68747470733a2f2f7a69676265652e626c616b61646465722e636f6d2f6173736574732f696d616765732f646576696365732f41716172615f51424b4731314c4d2e77656270) lumi.ctrl\_ln1 Wall Switch With Neutral Single Rocker [QBKG12LM](https://zigbee.blakadder.com/Aqara_QBKG12LM.html)[[QBKG12LM]](https://camo.githubusercontent.com/24968eb928a60eae520091ade82afec3eb73c7f3ed335b68da313bc96e53a6b8/68747470733a2f2f7a69676265652e626c616b61646465722e636f6d2f6173736574732f696d616765732f646576696365732f41716172615f51424b4731324c4d2e77656270) lumi.ctrl\_ln2, l…
_[View the full topic](https://community.smartthings.com/t/release-aqara-double-rocker-wall-switch-dth-and-discussion-updated-may-26-2020/192205)._
